preventec47 Posted September 15, 2012 Share Posted September 15, 2012 For those seeking the very smallest file size due to reduction of color pallete, you should know that the TIFF-IV ( specifically -IV ) has a single bit ( black or white ) color pallette that is used by the Smithsonian and the US Patent office for the digital storage of all documents. So if you are interested in reduced file size for documents or drawings, the TIFF-IV is the solution. BTW, this is also a standard in the engineering and construction industry and was not surprisingly invented for FAX transmissions long long time ago. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted September 15, 2012 Share Posted September 15, 2012 The major drawback with TIFF is that there is a serious lack of support from modern browsers because it is such an old format. The format is therefore a poor choice for web graphics. TIFF is minimally supported in Paint.NET and the developer (Rick Brewster) has made it clear in numerous forum posts and blog entries that this situation is not about to change. Where possible the use of PNG is encouraged. You should also know that Paint.NET does not support 1-bit (monochrome) TIFF images (or layering or multiple images in TIFF files). Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Grafello Posted November 20, 2012 Share Posted November 20, 2012 How I can save picture in 8-bit palette format? Is it possible with this plugin or some other? Anyone help? Thank you! Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted November 21, 2012 Share Posted November 21, 2012 Save it as a GIF. GIF's have a 256 slot palette. Alternatively, this plugin has options to save in different formats - I think all of them have a 256 (8-bit) option. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Grafello Posted November 21, 2012 Share Posted November 21, 2012 Thank you for answer, but for some reason such way saved file can not be open in programs as packed 8-bit palette bitmap file. The error is: "Bitmap file size check failed". When file is converted with Corel Draw for example it can be used without any problems. I am not familiar with picture formats. May be I need to check what bitmap file consists after Paint.net converting and compare with file converted by Corel Draw. Quote Link to comment Share on other sites More sharing options...
Bissen Posted January 25, 2013 Share Posted January 25, 2013 Thanks for the plugin! I have a question though: How would one save an animated gif or png-file in layers, without flattening it? Is it possible? Quote Link to comment Share on other sites More sharing options...
CakeMaster Posted August 31, 2018 Share Posted August 31, 2018 I can see that you haven't been active for a while, jxp, but if you ever see this message, I just wanted to say thanks for making a solid plugin. Quote Link to comment Share on other sites More sharing options...
n.m.p. Posted April 14, 2020 Share Posted April 14, 2020 I know this thread hasn't been active in a while, but I wanted to check if anyone else has a problem with this plugin not working? I have placed it in the filetypes folder and checked that security hasn't blocked it and my program is updated, but the plugin simply does not show up in paint.net, no error message whatsoever. Could this maybe be because the plugin is out-of-date, or something else? I can't find any comparable option so I really want this to work! Quote Link to comment Share on other sites More sharing options...
ReMake Posted April 14, 2020 Share Posted April 14, 2020 (edited) 3 hours ago, n.m.p. said: I can't find any comparable option so I really want this to work! This plugin is designed for saving files. The result of this plugin you can find under File -> Save As... -> Bitmap (Low color) (*.bmp) (or GIF (Low color) (*.gif), or PNG (Low color) (*.png), or Tiff (Low color) (*.tif; *.tiff)) Edited April 14, 2020 by ReMake Modified the text. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted April 14, 2020 Share Posted April 14, 2020 You can also check to see if there was an error while loading the plugin. Go to Settings -> Plugin Errors. 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Tcheluskin Posted May 27, 2020 Share Posted May 27, 2020 (edited) Hello. I got an issue: when saving images to 16-bit BMP or TIFF, they always become dithered, despite of setting Dither = 0 in the save dialogue. Can it be fixed, please. I'm using Paint.NET 4.1.6, Windows 7 32bit. Attaching the sample original and converted-to-16bit image. BMP_to_16bit_sample.zip Edited May 27, 2020 by Tcheluskin Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted May 27, 2020 Share Posted May 27, 2020 I'm only able to replicate the dithering effect in your second image when the transparency of the layer is reduced. Is it possible you had the layer transparency at less than 255? Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Tcheluskin Posted May 27, 2020 Share Posted May 27, 2020 (edited) Ego Eram Reputo I tried saving to 16-bit BMP and TIFF with different settings of Transparency from 0 to 255 in the save dialogue, the result does not change. The dithering appears constantly only for 16-bit, not for 256 or 16 color. UPD: Tried on the other PC with Windows 7 64-bit, Paint.NET 4.0.19, downloaded the LowColor plugin just now — the same dithering always present. UPD2: Pardon, probably you've meant the Transparency property of the layer in the Paint.NET itself. It was always 255 (not transparent). Edited June 1, 2020 by Tcheluskin Quote Link to comment Share on other sites More sharing options...
romanance Posted May 20, 2023 Share Posted May 20, 2023 This plugin doesn't seem to work, and I have checked to see if there was any plugin errors Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted May 20, 2023 Share Posted May 20, 2023 @romanance, the last update for the plugin was posted about 13 years ago. It may have been abandoned. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
