Posted
Here am I. Brain the size of a planet. And you accuse me of quoting HHGttG? Hateful isn't it....:mrviolet:
Watched the movie again recently. Fabulous.
Posted
November Update
Here's an interesting mix of new plugins for you to try!
Dragan Effect ReMake Simulates the photographic effect made famous by Polish physicist and photographer Andrzej Dragan. The effect enhances the depth of the person and their character by enhancing facial features.
Plugin Browser (updated) toe_head2001 Official re-release of the Dwarf Horde's Plugin Browser following a significant rewrite by toe_head2001. Locate, search and run effects from within the Plugin Browser. List installed plugins by Menu, Author, Alphabetically or by Keyword(s). Bookmark and add comments to your favourite plugins. Find information on plugins and see an effect preview image (where available).
Poster Red Ochre Analyzes the BGR values within a selection, sorts them into bands by Hue, saturation and Tone. Averages these values, then recolors the image.
Render Sphere Height Map MJW Renders a configurable 24-bit height map for a sphere.
Scratch Art ReMake Mimics scratching lines through black paint overlaying colored paper.
Texture Merger MJW Combines two height maps, one on the canvas and the other in the clipboard. Each height map consists of an 8-bit alpha channel and a 24-bit depth, formed by combining the RGB channels into a single 24-bit unsigned integer.
  • Upvote 4
Posted
December Update
Five new plugins this month.
Angled Gradient MJW Draws a gradient in the active layer / selection at the specified angle
BoxFitting NomBot Recomposes an image by reassembling it from squares in many sizes which take their color from the original image.
Compo Grids Red Ochre Renders a range of geometrical grids as an optical aid in design and proportion.
Unselected Rectangle Keeper MJW Erases the background surrounding an unselected region, but keeps the rectangular area which minimally bounds the unselected area. NB: no user interface.
Vanishing point Red Ochre Renders a pair of triangles as an optical aid to determining the vanishing point in a composition.
  • Upvote 3
  • 3 weeks later...
Posted
Its a list of every plugin created for paint.net. Think of it like an encyclopedia or dictionary. You can look up a plugin by name or author. The downloadable listings are free and include more information than the forum lists.
Posted
Dear ERR!  <3
Sorry!  :(   I'm late. Thank you so much. :cake: :cake:  :coffee: :coffee:   :)
Gandhi
Posted
January Update
Happy New Year!!!
Brush Factory AnthonyScoffler Import and use dynamic brushes with custom shapes as drawing tools.
DotMatrix NomBot Reinterpret an image as if it was composed from colored dots with highlighting and shadowing.
Modify Channels v1.0.0 LWChris Create and configure multiple channel modifications. Each modification manipulates one image channel, using one or more arguments to calculate the new value for the target channel.
Organigram Ego Eram Reputo Renders simple relationship diagrams or organizational charts. Part of EER's Plugin Pack EER's Plugin Pack
ShapeMaker v1.3+ The Dwarf Horde ShapeMaker is a tool which uses a WYSIWYG interface to allow the creation of SVG (Scalable Vector Graphics) Shapes, Lines and Curves. paint.net Shapes can be created and manipulated using just the mouse. Extensive documentation in two PDF files supplied in the download. The Dwarf Horde are @toe_head2001, @TechnoRobbo, @Red ochre, @Ego Eram Reputo and @BoltBait.
Tesserae v1.0 NomBot A mosaic effect which uses path brushes to apply a tiled texture to an existing image.
  • Upvote 3
Posted
February Update
Seven new plugins this month, including one each from first time authors xod and Rapido.
Enjoy!
Average Object Color MJW Averages the colors of objects.
Black and White+ MJW Adjustment which converts an image to black and white with the option of specifying the weight of each color channel.
Clock Plugin xod Render a circular clock face. Many configurable options in very tall dialog.
HIS Filetype Rapido Load and save HIS His image format (used for X-Ray flatpanels from PerkinElmer).
Mandala NomBot Renders and rotate cardinal splines in color and with various brush settings.
Texture Scaler MJW Utility to rescale height maps.
TileWorld Ego Eram Reputo Uses a point & click interface to tiles square regions of a loaded image onto the active layer.
  • Upvote 5
Posted
Dear ERR!  <3
Gandhi
  • 4 weeks later...
Posted
29 minutes ago, AlexdoesMC said:
Hey Scott! Just asking, how often is this updated?  :mtdew: :pizza:
On 15.08.2010 at 6:20 AM, Ego Eram Reputo said:
Updates are done around the first of each month. ...
Posted
@ReMake
has answered for me :) I update the Index monthly, usually on the first day of the month. Sometimes I'm a day early or late depending on my workload.
Posted
March Update
Yeah, I know. I'm a day late :(
Just as well we have these neat new plugins to make us happy again :mrgreen:
DICOM FileType Rapido Adds loading support for DICOM image files (Digital Imaging and Communications in Medicine). The format is used for medical imagery. NB: place both *.dll files into /Filetypes/
Flourish Red Ochre Create calligraphy-like spirals, swirls, flourishes and tendrils. Possibly mustaches too. Many options to control the shape.
MyCreaLogo roro69 NB: French language plugin. Creates wordart syle text transformations. Many options.
Paste Warp + MJW  An enhanced version of TechnoRobbo's Paste Warp plugin (all new code, same algorithm as the original). New features include the ability to move and scale the clipboard image, antialiasing and a number of clipboard tiling modes.
Temperature / Tint Adjustment BoltBait Adjusts photos to tune the image temperature (blue through orange) and tinting (green through magenta).
  • Upvote 4
Posted
April update
A single plugin to add to the list this month. Spaced Text is a neat little word processing plugin which includes kerning (the space between characters).
Welcome to the list @simmetric!
Spaced Text simmetric Text rendering plugin which supports kerning & line spacing as well as a slew of basic word processing effects. Does not support OTF fonts.
  • Upvote 5
