Graffiti on a wall
Hi guys i love giving all your tuts a try heres my go at this not amazing but haven't has paint long:
What I guess I did was reduct the layer strength to 80 like you said but i added a little but of faded gradient to give it that spray can finish of a grafiti tag then bended it to go over the object as they dont care if they go over stuff and well thats it I guess.
42057_4c7a3c80db4e38020232fd6ebbef124f
[attachment=0]graf1.jpg[/attachment]
Awesome outcome, but I didn't understand half of what you said xD
Ah ok well:
To start I changed the grafiti layer Opacity to 80 to give it the wash effect.
For the gradient I used red as the primary and secondary I used white but in the more section I made it completely transparent then brushed the red gradient over a little bit on each one maybe 2 times to give it a semi finished colouring look.
Then I used the rotate to place it over the object behind to make it look like it has been sprayed over giving it that town worn effect.
Hope this translation helps I was in a rush when i posted was working at the same time.
Ah ok well:
Lol, nice one :lol:
Guys this thread is getting bogged down with so many quotes that include the same image.
Please consider carefully if you need to repeat the image in your quote. Especially if the image is in the post immediately above your reply.
If you are quoting - whip out the IMG tags to remove the image if it is not required.
  • 4 weeks later...
