imnopyrowinkwink Posted June 10, 2009 Author Share Posted June 10, 2009 Its happened to me two times now i don't know why it occurs but it does. I go to text, start typing and nothing appears. Even after changing the color, the fonts, and everything i don't know why it doesn't work. I just put a picture in on my 2nd layer. Do i have to put text on a different one? Thanks for the help in Advance. -Anthony Quote Link to comment Share on other sites More sharing options...
imnopyrowinkwink Posted June 10, 2009 Share Posted June 10, 2009 Its happened to me two times now i don't know why it occurs but it does. I go to text, start typing and nothing appears. Even after changing the color, the fonts, and everything i don't know why it doesn't work. I just put a picture in on my 2nd layer. Do i have to put text on a different one? Thanks for the help in Advance. -Anthony Quote Link to comment Share on other sites More sharing options...
Datruel3gend Posted June 10, 2009 Share Posted June 10, 2009 Do you have an area outside of where you're trying to type selected? Make sure you don't, that could screw you over real fast. Quote Link to comment Share on other sites More sharing options...
Benji2 Posted June 10, 2009 Share Posted June 10, 2009 I think the 1st responder is correct. (and I love his sig) But I would recommend putting it on a new layer anyway. Then you can add effects to it/ rotate it withought screwing up your entire image. Quote Link to comment Share on other sites More sharing options...
