cannonwill Posted May 27, 2009 Share Posted May 27, 2009 I am following the directions the best I can and have tried a couple of ways. I have made the background transparent (supposedly) but when it is used it still shows the background as white. See attached example. What am I doing wrong... or not doing right!?? Quote Link to comment Share on other sites More sharing options...
Simon Brown Posted May 27, 2009 Share Posted May 27, 2009 JPEG doesn't support transparency, only PNG and GIF. Although i'm not sure whether the desktop will turn transparent images to the colour used anyway, so my advice is to simply add a new layer below the logo that is filled with black. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted May 28, 2009 Share Posted May 28, 2009 I doubt the desktop background renderer supports the transparency either. This is not a Paint.NET issue. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Leonte Posted May 28, 2009 Share Posted May 28, 2009 the desktop should support it just fine. mine dose. it's probably the wrong file type Quote Link to comment Share on other sites More sharing options...
Benji2 Posted May 28, 2009 Share Posted May 28, 2009 Vista doesnt support PNGs, its very lame Quote Link to comment Share on other sites More sharing options...
Ouchy_S Posted May 28, 2009 Share Posted May 28, 2009 Vista doesnt support PNGs, its very lame Then it's a good thing he isn't using vista. Since you are setting the background colour of your desktop black, why not use the paint bucket and make what would be transparent black too? Quote My deviantART | My Gallery Link to comment Share on other sites More sharing options...
edmond Posted May 28, 2009 Share Posted May 28, 2009 i'm not sure if vista itself supports png, but if i download a png picture and then open it using ACDSee Quick View, it works.(i tried it out) Absolutely no problems as long as u have the software. Quote I'm a newbie to Paint.NET. I need lots of advice on usage! Link to comment Share on other sites More sharing options...
Benji2 Posted May 30, 2009 Share Posted May 30, 2009 sorry, vista does not support pngs on wallpapers. not in general >.< Quote Link to comment Share on other sites More sharing options...
Ouchy_S Posted May 30, 2009 Share Posted May 30, 2009 Are you saving at is 32-bit .PNG? Quote My deviantART | My Gallery Link to comment Share on other sites More sharing options...
