Text Feature Problem
any active selections? try the deselect button. then type
when you have your color wheel open is it showing white as primary color
text uses primary color always.
also best to add a transparent layer to type your text on. make sure that layer is not hidden by your black layer. If you open your layers window it should be in the layer above the black one.
hope that helps if not post a screen shot. might be just something tiny you need to adjust. and we can judge better from screen shot.
ciao
OMA
ciao
OMA
Where's the deselect button? Boy, would that help!
ciao
OMA
Nevermind, but I made a circle, how do I adjust the size of the circle? This is really nothing like photoshop, lol.
ciao
OMA
I also had some text, but I can't edit that?!?!?
sorry no can do that. not a text editor. that's why I recommend doing text on separate transparent layer. you can go back in and delete the layer or erase out a portion.
saying that some pictures can be salvaged. it its just plain black (any color) behind the word just paint over the text with background color and retype
ciao
OMA
