Embossing and shadowing fonts
  • 3 months later...
One way to make a bevel, is
-select(magic wand) the area around the text
-create new layer
-fill in the selected area with the colour you want the beveling
-blur this layer
-duplicate this layer, and then merge, to make shading stronger(well that's what I do)
-go back to text layer, and magic wand select outside the text again.
-go back to the shaded layer and then use the cut, to remove the unwanted area.
-then merge the bevel shade with the text
and you should get something like this
