Ab§olute_Z3R0 Posted March 19, 2009 Share Posted March 19, 2009 So I'm new; I'm sure you can see that. I've tried to find some topics to help me, but I cannot seem to find any. So I have this very small image I would like to have the corners transparent. I know I have to slide the Alpha thing to 0, but when I put the image where I'm using it, the color does not appear transparent; I've tried a bright cyan color and a pink-purple color, but no cigar. If anyone wants to see the image, here it is: Picture (on BrickShelf) Quote Proud (and happy!) Paint.NET user since March, 2009. HOW TO USE .ABR BRUSH FILES IN PAINT.NET Link to comment Share on other sites More sharing options...
Juraiko1324 Posted March 19, 2009 Share Posted March 19, 2009 To get it transparent, you can select a portion with the select tool and cut, or ctrl+x, it out. Quote -I may have not been here when you passed away, but you will be missed.- Link to comment Share on other sites More sharing options...
Ab§olute_Z3R0 Posted March 19, 2009 Author Share Posted March 19, 2009 Did you look at the image? It's working now; thanks. Quote Proud (and happy!) Paint.NET user since March, 2009. HOW TO USE .ABR BRUSH FILES IN PAINT.NET Link to comment Share on other sites More sharing options...
