yellowman 277 Posted July 21, 2009 Author Share Posted July 21, 2009 I don't have Shape3D. I already have installed it from another site.. but I don't know how to put that in Paint.net!Can you help me? Because I wanna make things with Shape3D. Thanx :wink: Download the plugin, and save it in the Effect folder of the Paint.NET, usually this path (C:\Program Files\Paint.NET\Effects) Or for more help, visit this site, everything is explained with clear details: http://boltbait.googlepages.com/install "Thanks BoltBait for the site" And you can read this too: http://paintdotnet.forumer.com/viewtopic.php?f=16&t=2023 You are welcome. Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to post Share on other sites
InteractiveBuddy 0 Posted August 1, 2009 Share Posted August 1, 2009 very nice effect and a well written tut. I noticed the rays when they werecoming out in front of the text that if i could transform that into a disco ball it would look really cool so thats what im trying right now. Quote Link to post Share on other sites
yellowman 277 Posted August 1, 2009 Author Share Posted August 1, 2009 Thanks for stopping by and leaving a comment, I guess you have a good idea and looking forward to see what you can make, you can also check the Exploding Planets tutorial, it is something similar to what you want to try. Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to post Share on other sites
InteractiveBuddy 0 Posted August 2, 2009 Share Posted August 2, 2009 Sorry, i cant make it. I havent gotten off the computer since i posted that reply and i cant make it. I thought if i filled the canvas with black and then made colored circles all around it then use the shape 3D sphere effect and then make the glass or chrome or whatever plates but it didnt work. I also tried about 5 other other methods but none of them worked either. But im sure one of the more experienced pdn users like Oma could make one. Im not sure if hed want to but im sure if he did it would turn out great. Quote Link to post Share on other sites
yellowman 277 Posted August 2, 2009 Author Share Posted August 2, 2009 Don't give up, you almost there, make sure your canvas is: -square shape not rectangle, -and fill it with black(as you did), -then add a new layer (keep it transparent) and put the colored circles on this layer, -then run Shape 3D on the black layer, -and then run it also on the layer with circles with same stetting but make sure to use Half Sphere Map on this time on this layer, -duplicate circled layer and Zoom blur only one layer once or twice and you're done. EDIT/ I posed the method then I used it to make the image, check how much time I spent..? About 10 minutes and this is first time with no additional effects. Good luck. Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to post Share on other sites
uvah 0 Posted August 23, 2010 Share Posted August 23, 2010 This one was a real pain in the rear end. I moved it so much and adjusted the zoom that it left artifacts behind. Let me know what you think. Resized to 600x600. Quote Link to post Share on other sites
uvah 0 Posted August 23, 2010 Share Posted August 23, 2010 Try again...This one is without the grid to show you the artifacts I mentioned. If you want to know the font it is called yaki goma from dafont.com. Quote Link to post Share on other sites
dharmin007 0 Posted December 25, 2010 Share Posted December 25, 2010 Thanks for the easy the awesome tutorial!! Quote Link to post Share on other sites
mtpkader 0 Posted January 2, 2011 Share Posted January 2, 2011 Here is my try Bullet for my valentine is a band! My favorite band :twisted: please tell me how to install the 'shape 3D'? from where i can download it? if i download a zip file what i will do? Quote Link to post Share on other sites
mtpkader 0 Posted January 2, 2011 Share Posted January 2, 2011 please help me, how to install 'shape 3D' for paint.net? from where i can download it? if i download a zip file how how i can use it for paint.net? Quote Link to post Share on other sites
Ego Eram Reputo 2,838 Posted January 2, 2011 Share Posted January 2, 2011 For help with installing plugins, read this: BoltBait's Plugin Installation guide You can find plugins by name in the Plugin Index (link in my signature). Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to post Share on other sites
mountnman 11 Posted August 17, 2011 Share Posted August 17, 2011 (edited) when you hit the button to add a layer, in the layer window, the layer added is automaticaly transparent. when adding text to thyis layer, the words will be visible. do not confuse transparent with hidden/invisible transparent means there is nothing added to the layer and you can see thru it, hidden(when you have unchecked the visibility box) means you cant see the layer at all as far as the multicolour gradient-he mentioned it but didnt provide instructions- i guess becuase you dont have to use it--- anyway, once your text is on a transparent layer, using the magic wand tool set to 0 tollerance, hold shift and select anywhere outside your text, the press Ctrl-I , which will invert your selection, run the gradient, after which you will need to hit Ctrl-d or hit enter, to deselect Edited August 17, 2011 by mountnman Quote SARCASM- Just one of the many services I offer free to the public. Link to post Share on other sites
yellowman 277 Posted August 18, 2011 Author Share Posted August 18, 2011 @mountnman, thank you very much for the explanation, couldn't explain it better than you. @jackpelter, sorry for the confusion, try to be creative and apply your own effects, I think this Tutorials rule is applying here in this case,"10. By and large, you should lean toward publishing tutorials that depict concepts and procedures well, and not just a specific result. We don't want to lead people by the hand; we want to help them become better. You know the old adage, "If you give a man a fish, he'll eat for a day. If you teach a man to fish, he'll eat for the rest of his life." Let's teach, not just show" However, if you have any question, please post it here, it doesn't matter how easy or difficult you think the question is, Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to post Share on other sites
minners71 48 Posted August 18, 2011 Share Posted August 18, 2011 Nice tut Yellowman. Quote Link to post Share on other sites
mountnman 11 Posted August 18, 2011 Share Posted August 18, 2011 . You know the old adage, "If you give a man a fish, he'll eat for a day. If you teach a man to fish, he'll eat for the rest of his life." and i thought it was.. "If you give a man a fish, he'll eat for a day. If you teach a man to fish, he'll sit in a boat and drink beer for the rest of his life." Quote SARCASM- Just one of the many services I offer free to the public. Link to post Share on other sites
yellowman 277 Posted August 19, 2011 Author Share Posted August 19, 2011 I am sorry guys, I didn't mean that, I just referred to that point, and didn't know it may have another meaning. Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to post Share on other sites
danielbleazard 0 Posted September 2, 2011 Share Posted September 2, 2011 Here is my try Bullet for my valentine is a band! My favorite band :twisted: That's really cool, but it kind of looks like Bullet for my Valentinf lol Quote Link to post Share on other sites
mickysaaz11 0 Posted February 6, 2012 Share Posted February 6, 2012 When i first saw the pic i was like AWESOME! I'm going to try it and post again with the result Quote Link to post Share on other sites
nitenurse79 720 Posted February 7, 2012 Share Posted February 7, 2012 Just stumbled upon this tut, well written, easy to follow :star: :star: heres mine; Quote Link to post Share on other sites
doughty 326 Posted June 8, 2012 Share Posted June 8, 2012 (edited) I clicked on polygonal transparency and got a quite different effect. Edited June 8, 2012 by doughty Quote Link to post Share on other sites
AGJM 13 Posted October 3, 2012 Share Posted October 3, 2012 (edited) Look who saw your tutorial: Actually, the text looks very nice in that image. It's absolutely everything else that makes me want to flee for my life and innocence. Edited October 3, 2012 by AGJM Quote The hardest part of ending is starting again. Link to post Share on other sites
Brazos 0 Posted April 25, 2014 Share Posted April 25, 2014 Great tutorial yellowman! I was curious how you made the ring. I tried using your method and it did not come out like yours. What image did you start with? I realize it has been a long time since the original post was made. So I hope you are still around and can respond. Thanks Yours: Mine: Quote Great things are done by a series of small things brought together. -Vincent Van Gogh Link to post Share on other sites
yellowman 277 Posted April 26, 2014 Author Share Posted April 26, 2014 @ Brazos, as I remember, here I used two halves for the ring when rendering it in the Shape-3D plugin. This quick video will help you, the quality of the resulted shape is not that good, but I am sure you will understand the concepts. Please let me know if have any question. http://youtu.be/TGTcRjB7Cnc Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to post Share on other sites
Brazos 0 Posted May 11, 2014 Share Posted May 11, 2014 Thank you for your response and the video. Quote Great things are done by a series of small things brought together. -Vincent Van Gogh Link to post Share on other sites
Maximilian 1,927 Posted August 9, 2018 Share Posted August 9, 2018 I've found this nice tutorial by chance the other day. Short, entertaining and effective A quick first test (I now realize I should have polished a few text borders before posting ?) And I used the technique to make a birthday greeting for a friend: I hope @yellowman returns sometime. 3 Quote Link to post Share on other sites
