HELP ME!!! Can't figure out how to change format for website
Change your topic name first.
But to change it to a png, there is a very useful tool. It's called search and it can be found at the top right hand corner
of the website. How come no1 uses it?
Also, be sure to read this
We should all be... Alive...
|Lightning|My Dome|Pokemon sig tut|
does not tinypic accept only .jpg .png or .gif ? I'm asboultley sure they don't accept pdn files. so you need to change to one of the other formats. this is the link
to read how to do that.
viewtopic.php?f=34&t=26975
just a suggestion ....try to use the search button up right top of the forum screen. I know this one question has been answered numerous times. That's why its stickied in the tut section. using the search button might answer you question when there isn't anyone else on the board to help you out.
by the way welcome to the forum and good luck on the contest.
ciao
OMA
