Killer Rob Posted January 30, 2009 Author Share Posted January 30, 2009 okay, maybe this might be a little hard to explain, but let's say I have ten similar images all at 600x400 opened up in Paint.Net. Now let's say on the first image, I take the lasso and make a circle in the middle of the image. Now, how can I ONLY copy the selected lasso circle and paste it directly to the other 9 pics, but NOT the actual colored pixels in the circle?? See what I mean? I want to use the same lasso circle design that I made in the 1st image and apply it to the other images, but I don't want to paste the colored pixels from the 1st image to the other 9 images. I just want to post the actual lasso circle to all the images that way I can crop every pic to the same exact lasso coordinates while at the same time all the pics will still remain with their original colored pixels, instead of all ten images being exactly like the 1st image in terms of the exact same colored pixels inside the lasso circle. See what I mean? It's kind of hard to explain, but I know someone understands what I'm trying to say. Any help would be much appreciated! Link to comment Share on other sites More sharing options...
Killer Rob Posted January 30, 2009 Share Posted January 30, 2009 okay, maybe this might be a little hard to explain, but let's say I have ten similar images all at 600x400 opened up in Paint.Net. Now let's say on the first image, I take the lasso and make a circle in the middle of the image. Now, how can I ONLY copy the selected lasso circle and paste it directly to the other 9 pics, but NOT the actual colored pixels in the circle?? See what I mean? I want to use the same lasso circle design that I made in the 1st image and apply it to the other images, but I don't want to paste the colored pixels from the 1st image to the other 9 images. I just want to post the actual lasso circle to all the images that way I can crop every pic to the same exact lasso coordinates while at the same time all the pics will still remain with their original colored pixels, instead of all ten images being exactly like the 1st image in terms of the exact same colored pixels inside the lasso circle. See what I mean? It's kind of hard to explain, but I know someone understands what I'm trying to say. Any help would be much appreciated! Link to comment Share on other sites More sharing options...
Simon Brown Posted January 30, 2009 Share Posted January 30, 2009 Do it on a new layer and copy that. Link to comment Share on other sites More sharing options...
Killer Rob Posted January 30, 2009 Author Share Posted January 30, 2009 ok Simon, thanks for the tip. I think I'm on the right path as far as copying the lasso shape design and being able to paste that onto the other images, but when I do, it pastes the design and while there are no colored pixels from the original image (which is good), the lasso circle pastes itself as the white and gray checkerboard. So how can I copy the design off a new layer and paste it to all the other images so that it stays translucent so I can still see the images behind the translucent lasso circle in each of the images? Link to comment Share on other sites More sharing options...
Myrddin Posted February 1, 2009 Share Posted February 1, 2009 Killer Rob, you should brush up on the Rules where you'll read that [rule=6]topic titles must be descriptive[/rule]. This in order for both the right user to see your problem and help more efficiently, and more importantly, for a clean and organised Forum; imagine if the Forum was littered with 'Question!' and 'request!!!!', searching would become difficult to say the least. You have until after your next visit before I will have to lock your topic. How to Use Images in Your Posts, Signatures, and AvatarsHow to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 3, 2009 Share Posted February 3, 2009 [rule=6]Rule #6.[/rule] Thread Closed The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
