rj2 Posted January 24, 2009 Share Posted January 24, 2009 Recently downloaded "Majik's Photo Fill" plugin and just can't understand exactly how to use it. Could someone please give me some instuction? Quote Link to comment Share on other sites More sharing options...
PineappleQc Posted January 24, 2009 Share Posted January 24, 2009 first highlight the selection you want to fill (or select nothing for the whole layer to be filled), then run the plugin, click "browse" and select the picture you want to fill with. Effects are usually better with a seamless texture. Quote "Ah, i love it when huge pineapples try to take over the world, it makes me sentimental :')" -Stephan Link to comment Share on other sites More sharing options...
rj2 Posted January 24, 2009 Author Share Posted January 24, 2009 Thanks, PineapplQc. Was starting to go nuts. Just tried it and all is good now. ) thx, again. Quote Link to comment Share on other sites More sharing options...
Curmudgeon Posted January 24, 2009 Share Posted January 24, 2009 although, I crash everytime while using it when the image used is a .tga file Quote Link to comment Share on other sites More sharing options...
