silverhammer 0 Report post Posted January 16, 2009 (edited) This plugin is like a more useful version of the color replacement tool. Whereas the standard tool merely paints over pixels if they're close enough to the secondary color, this plugin recolors every pixel a different amount based on how similar it is to the secondary color. For example I'll use this colorful image: Here's the built in tool replacing pink with cyan at about 30%: Notice the ugly, harsh edges and how some pinkish parts of the image are entirely untouched. Now my plugin replacing pink with cyan: No more ugly edges! My plugin changes all pixels of the image based on how similar each is to the secondary color. *Threshold changes how strongly pixels are recolored based on how similar they are to the secondary color *Roughness changes how quickly the recolor effect falls off after the threshold is passed when continuous replacement is selected. Lower values look 'nicer' but tend to give the image an overall tint *Continuous replacement recolors all pixels different amounts and looks really nice. Cutoff works similar to the normal tool as pixels over the threshold are not recolored at all - recolored pixels however are colored more 'accurately' than with the built-in tool. Note that this plugin works like the built-in tool inasmuch as the color used and the color replaced are the primary and secondary colors in the palette, respectively. advcolorrep.zip Edited July 10, 2018 by toe_head2001 Reattached Zip Quote Share this post Link to post Share on other sites
ragingsuns 0 Report post Posted February 12, 2009 Mm, very useful. It's certainly a lot softer than when you use the Colour Replacement tool. Good job! Quote Share this post Link to post Share on other sites
Svengali 0 Report post Posted February 12, 2018 That is not a "ZIP" file. What I supposed to do with the junk named "12635_2955e8ebabf0b67a6ffc3280a689423a"? Quote Share this post Link to post Share on other sites
null54 400 Report post Posted February 12, 2018 10 minutes ago, Svengali said: What I supposed to do with the junk named "12635_2955e8ebabf0b67a6ffc3280a689423a"? Some older attachments got scrambled during the forum upgrades, you need to rename the "12635_2955e8ebabf0b67a6ffc3280a689423a" file and add a .zip extension. 1 Quote Share this post Link to post Share on other sites
Svengali 0 Report post Posted February 12, 2018 26 minutes ago, null54 said: Thanks! Quote Share this post Link to post Share on other sites
Ego Eram Reputo 2,192 Report post Posted February 13, 2018 Images rehosted thanks to @ReMake Quote Share this post Link to post Share on other sites
doughty 300 Report post Posted July 10, 2018 On 1/16/2009 at 2:26 PM, silverhammer said: advcolorrep.zip This plugin is not in its proper wrapper. Quote Share this post Link to post Share on other sites
toe_head2001 1,282 Report post Posted July 10, 2018 3 hours ago, doughty said: This plugin is not in its proper wrapper. Fixed. Quote Share this post Link to post Share on other sites
