Magic wand and deleting what was done
Say I take a picture of my glasses, due to the reflection and whatnot the magic wand won't select the lenses with one click right? But I can just make a border around them and then just use the magic wand to select what I bordered. Though the border would be in a color, is it possible for me to remove the border in the history without undoing everything done after the border?
This can be done easily, and without the need for messing with the history, by putting your border on a separate layer and then deleting the layer after you're done using the border.
I've often wondered, though, if it would be feasible to do a history which you could remove and add single items to at will, but I think it would be a major undertaking due to the effects of any given action on all the actions after it. Seems like it would be one heck of a coding job, anyway.
Photobucket Sucks!
