Sign in to follow this
Timbo1
How to add cool motion effects to images
Welcome to my first Paint.NET tutorial.
I will be showing you how to put cool motion effects into photos.
Original Image
Tutorialss#5286759201560513554
New Image
Tutorialss#5286759198877607234
First open your picture in Paint.NET.
Tutorialss#5286657113221491714
Then create a new layer and carefuly with the line tool draw around your image.
Tutorialss#5286657126175235618
Then select inside the lines with the magic wand tool.
Tutorialss#5286657125151824594
Now delete the layer with the lines on it and the selection should be left on the biker ( or whatever image you choose ).
Tutorialss#5286657114366357058
Copy the new selection and then deselect it. Then motion blur the image in the opposite direction that the subject is travelling at about 25.
Tutorialss#5286657123510243154
Then paste the copied image that should align itself and there you are
Tutorialss#5286759197151242930
Share this post
Link to post
Here is a fixed version:
Hidden Content:
Original Image
New Image
Final%20Image.jpg[reason]The fixed tutorial[/reason]
And here's the text/code to put in the first post to make it work:
Hidden Content:
[reason]text/code[/reason]
Original Image
[img=http://lh6.ggpht.com/_8c3knZVOPkQ/SV5Xex4g5UI/AAAAAAAAAJY/rctTt8x4fd4/s640/Boring%20Image.jpg]
New Image
[img=http://lh4.ggpht.com/_8c3knZVOPkQ/SV5Xe74KzBI/AAAAAAAAAJQ/OKdgg3mHZrA/s640/Cool%20Image.jpg]
[img=http://lh3.ggpht.com/_8c3knZVOPkQ/SV36onLb7AI/AAAAAAAAAII/nbFPMyxnLpY/s720/Original%20Image.jpg]
[img=http://lh5.ggpht.com/_8c3knZVOPkQ/SV36pXb2XiI/AAAAAAAAAIo/y4maeVh6KlE/s720/Lined%20Image.jpg]
[img=http://lh5.ggpht.com/_8c3knZVOPkQ/SV36pTn2WtI/AAAAAAAAAIg/iUJMRmewG0I/s720/Magic%20Wand.jpg]
[img=http://lh5.ggpht.com/_8c3knZVOPkQ/SV36orcZLkI/AAAAAAAAAIQ/qtRDKNpJZG4/s720/New%20Selection.jpg]
[img=http://lh3.ggpht.com/_8c3knZVOPkQ/SV36pNgdz1I/AAAAAAAAAIY/No-GQZIv8yY/s720/Motion%20blurred.jpg]
[img=http://lh3.ggpht.com/_8c3knZVOPkQ/SV5Xerc6qrI/AAAAAAAAAJI/2DEUDKfSWBU/s720/Final%20Image.jpg]
Hopefully a moderator, an admin or Timbo1 will edit it.
Share this post
Link to post
