janbo Posted December 24, 2008 Share Posted December 24, 2008 Why is the below so?? I have taken a screenshot of what the same right click thumbnail viewer can 'see' , could this be a bug in PDN that may have been fixed in the latest build... lemme know Quote Link to comment Share on other sites More sharing options...
Kemaru Posted December 24, 2008 Share Posted December 24, 2008 Do you have the version 3.36? Quote Hatred does not cease by hatred, but only by love; this is the eternal rule. |fb(page)|portfolio|blog| Link to comment Share on other sites More sharing options...
Crazy Man Dan Posted December 24, 2008 Share Posted December 24, 2008 Yeah, one thing: Make sure you're keeping up-to-date with PDN releases. T'is in [rule=7]The Rules[/rule], after all. Does the image itself have proper transparency when you actually open it in something? Quote I am not a mechanism, I am part of the resistance; I am an organism, an animal, a creature, I am a beast. ~ Becoming the Archetype Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 24, 2008 Share Posted December 24, 2008 There's most likely a bug in the thumbnail generator that you are using for that screenshot. Photofilter is probably saving transparency as 0,255,255,255 whereas Paint.NET uses (as the math dictates) 0,0,0,0. All color values with an alpha values of zero are equivalent (they are transparent after all). Ergo, the bug is in whatever is creating the thumbnail. I can't see enough from your screenshot to know what's actually going on. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
janbo Posted December 28, 2008 Author Share Posted December 28, 2008 There's most likely a bug in the thumbnail generator that you are using for that screenshot. Photofilter is probably saving transparency as 0,255,255,255 whereas Paint.NET uses (as the math dictates) 0,0,0,0. All color values with an alpha values of zero are equivalent (they are transparent after all). Ergo, the bug is in whatever is creating the thumbnail. I can't see enough from your screenshot to know what's actually going on. Nice to hear from you Rick I dont think it is a bug in the Image generator as the same white background for transparently saved images is still shown when created by other image applications like Ulead PhotoImpact (in the preview test). To me, the black background does not look at all nice when previewing my PDN transparent images in the thumbnail preview.... SO I was wondering if, as you mentioned, when saving transparency images if the values can be configured from from the black 0,0 etc to the white 255, 255 (the white prefered) Would this currently be possible otherwise for the next version? My other reqesut Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 29, 2008 Share Posted December 29, 2008 I didn't say the problem was with the image generator. I said the thumbnail generator. This discussion has been had on this forum before -- transparent pixels are all mathematically equivalent. If your other software doesn't treat them as such, then it has a bug. I'm not going to add weird and arbitrary hacks into Paint.NET for this. You should report this bug to them. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
