Posted
Hi everyone,
I'm having a frustrating issue since updating to version 5.1. Anytime I load in high-texture graphics, my entire PC shuts down without warning. This has never happened before, and I’ve worked with much higher resolution graphics in the past without any problems.
Here’s what happens: I’ll paste a graphic into paint.net, and then as soon as I take any further action (like resizing, applying an effect, or saving), the PC powers off completely. It’s not a crash or freeze – the whole system just shuts down.
Has anyone else encountered this? I’m wondering if it could be related to paint.net settings or something in my PC configuration (GPU, power supply, etc.) that’s incompatible with the new update.
Any advice or fixes would be greatly appreciated!
Thanks in advance!
Posted
So this can be investigated, please start Paint.NET, then:
Click the Settings gear icon :Settings: (top right)
Click Diagnostics
Click Copy to clipboard
Ctrl+V paste the diagnostics text in a reply here (preferably in a Spoiler section; click the eye icon above)
Posted
I've been getting something similar, not a full shut down but it's like my GPU briefly resets. Both monitors go black and whatever windows were open reload when they come back on. Also when Paint.net reloads the Minimise/close icons on the top corner just aren't there anymore and I have to alt+f4 to close it.
Posted
Nothing can be investigated unless you post your Paint.NET Diagnostics.  Instructions are in the comment above yours.
Posted
Anytime I try this, I get a 'banned' message on this forum when trying to post?
Posted
Spoiler
Application                                                Paint.NET 5.1 (Stable 5.100.9082.35298)
Build Date                                                 12 November 2024
Current Date and Time                                      21/11/2024 12:30:30
System uptime                                              3.22:53:37.9210000
Process uptime                                             00:00:11.4870000
Application state                                          Running
Install type                                               Classic
Install directory                                          C:\Program Files\paint.net
Application directory                                      C:\Program Files\paint.net
Current directory                                          C:\Program Files\paint.net
OS                                                         Windows 11 Pro x64 (10.0.22631.0)
Runtime                                                    .NET 9.0.0 x64
Physical Memory                                            28,411 MB (20,077 MB free)
Paging File                                                30,203 MB (19,398 MB free)
Working Set                                                417,476 KB
Handles                                                    6309
Threads                                                    180
GDI objects                                                183
User objects                                               266
Language                                                   en-US
UI Scaling                                                 1.00x (96 DPI)
Cursor Scaling                                             1.00x
UI/Canvas GPU                                              True
Rendering GPU                                              🚀 Performance (AMD Radeon Graphics)
Advanced Color                                             True
Windows Ink                                                True
Animations                                                 False
Translucent Windows                                        True
Remote Session                                             False
Battery Saver                                              False
Theme                                                      Aero (Aero.msstyles), Dark
Updates                                                    Enabled
    Last Checked                                           21/11/2024
    Journal                                                ShouldCheckForUpdate, CheckedForUpdate
CPU                                                        AMD Ryzen 9 6900HX with Radeon Graphics
    Speed                                                  ~3294 MHz
    Cores / Threads                                        8 / 16
    Features                                               SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2
Display                                                    Generic PnP Monitor
    Connected to                                           AMD Radeon(TM) Graphics
    Resolution                                             1920 x 1080, 8-bit, 75 Hz
    DPI                                                    96 (1.00x scale)
    Coordinates                                            (L=0, T=0, R=1920, B=1080)
    Advanced Color                                         StandardDynamicRange
    SDR white level                                        80 nits
    Color space                                            RgbFullGamma22NoneP709
    Composition Support                                    None
    Resolution                                             1920 x 1080, 8-bit, 60 Hz
    Coordinates                                            (L=1920, T=-183, R=3840, B=897)
Video Card                                                 AMD Radeon(TM) Graphics
    Hardware Acceleration                                  Supported
    Performance Class                                      Good
    Dedicated Video RAM                                    4,069 MB
    Dedicated System RAM                                   0 MB
    Shared System RAM                                      14,205 MB
    Driver Version                                         32.0.11027.1003
    Vendor ID                                              0x1002
    Device ID                                              0x1681
    Subsystem ID                                           0x01241002
    Revision                                               199
    LUID                                                   0x00010928
    Flags                                                  AcgCompatible, SupportMonitoredFences, KeyedMutexConformance
    Graphics Preemption                                    PrimitiveBoundary
    Compute Preemption                                     DmaBufferBoundary
    Outputs                                                2
    Feature Level                                          Level_12_1
    Features                                               Doubles, ComputeShadersEtc
    Maximum Bitmap Size                                    16384
Video Card                                                 Microsoft Basic Render Driver
    Hardware Acceleration                                  N/A
    Performance Class                                      VeryLow
    Dedicated Video RAM                                    0 MB
    Driver Version                                         10.0.22621.4249
    Vendor ID                                              0x1414
    Device ID                                              0x008C
    Subsystem ID                                           0x00000000
    Revision                                               0
    LUID                                                   0x000122A3
    Flags                                                  Software, AcgCompatible, SupportMonitoredFences, KeyedMutexConformance
    Graphics Preemption                                    InstructionBoundary
    Compute Preemption                                     InstructionBoundary
    Outputs                                                0
    Maximum Bitmap Size                                    8388608
Managed assemblies                                         311
    System.Private.CoreLib                                 .\System.Private.CoreLib.dll, Version=9.0.0.0, PublicKeyToken=7cec85d7bea7798e
    paintdotnet                                            .\paintdotnet.dll, Version=5.100.9082.35298
    System.Runtime                                         .\System.Runtime.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Windows.Core                               .\PaintDotNet.Windows.Core.dll, Version=5.100.9082.35298
    PaintDotNet.Windows                                    .\PaintDotNet.Windows.dll, Version=5.100.9082.35298
    PaintDotNet.ComponentModel                             .\PaintDotNet.ComponentModel.dll, Version=5.100.9082.35298
    PaintDotNet.Primitives                                 .\PaintDotNet.Primitives.dll, Version=5.100.9082.35298
    PaintDotNet.Fundamentals                               .\PaintDotNet.Fundamentals.dll, Version=5.100.9082.35298
    System.Windows.Forms                                   .\System.Windows.Forms.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Diagnostics.Tracing                             .\System.Diagnostics.Tracing.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Thread                                .\System.Threading.Thread.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Base                                       .\PaintDotNet.Base.dll, Version=5.100.9082.35298
    PaintDotNet.Collections                                .\PaintDotNet.Collections.dll, Version=5.100.9082.35298
    TerraFX.Interop.Windows                                .\TerraFX.Interop.Windows.dll, Version=10.0.26100.0, PublicKeyToken=35b01b53313a6f7e
    PaintDotNet.Runtime                                    .\PaintDotNet.Runtime.dll, Version=5.100.9082.35298
    System.Collections.Concurrent                          .\System.Collections.Concurrent.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PointerToolkit                                         .\PointerToolkit.dll, Version=1.0.1.0
    PaintDotNet.Systrace                                   .\PaintDotNet.Systrace.dll, Version=5.100.9082.35298
    System.Private.Uri                                     .\System.Private.Uri.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.UI                                         .\PaintDotNet.UI.dll, Version=5.100.9082.35298
    PaintDotNet.Windows.Framework                          .\PaintDotNet.Windows.Framework.dll, Version=5.100.9082.35298
    WindowsBase                                            .\WindowsBase.dll, Version=9.0.0.0, PublicKeyToken=31bf3856ad364e35
    Microsoft.Windows.SDK.NET                              .\Microsoft.Windows.SDK.NET.dll, Version=10.0.26100.38, PublicKeyToken=31bf3856ad364e35
    PaintDotNet.ObjectModel                                .\PaintDotNet.ObjectModel.dll, Version=5.100.9082.35298
    WinRT.Runtime                                          .\WinRT.Runtime.dll, Version=2.1.0.0, PublicKeyToken=99ea127f02d97709
    PresentationFramework                                  .\PresentationFramework.dll, Version=9.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.Runtime.InteropServices                         .\System.Runtime.InteropServices.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Xaml                                            .\System.Xaml.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089
    System.ComponentModel                                  .\System.ComponentModel.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel.Primitives                       .\System.ComponentModel.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ObjectModel                                     .\System.ObjectModel.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections                                     .\System.Collections.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading                                       .\System.Threading.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Windows.Forms.Primitives                        .\System.Windows.Forms.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089
    Microsoft.Win32.Primitives                             .\Microsoft.Win32.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Private.Windows.Core                            .\System.Private.Windows.Core.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Drawing.Primitives                              .\System.Drawing.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Text.Encoding.CodePages                         .\System.Text.Encoding.CodePages.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Core                                       .\PaintDotNet.Core.dll, Version=5.100.9082.35298
    System.Configuration.ConfigurationManager              .\System.Configuration.ConfigurationManager.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    PaintDotNet.SystemLayer                                .\PaintDotNet.SystemLayer.dll, Version=5.100.9082.35298
    System.Collections.Specialized                         .\System.Collections.Specialized.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Resources                                  .\PaintDotNet.Resources.dll, Version=5.100.9082.35298
    System.Xml.ReaderWriter                                .\System.Xml.ReaderWriter.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Private.Xml                                     .\System.Private.Xml.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Drawing.Common                                  .\System.Drawing.Common.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Net.WebClient                                   .\System.Net.WebClient.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Linq                                            .\System.Linq.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Memory                                          .\System.Memory.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Text.Encoding.Extensions                        .\System.Text.Encoding.Extensions.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Data                                       .\PaintDotNet.Data.dll, Version=5.100.9082.35298
    Microsoft.Win32.Registry                               .\Microsoft.Win32.Registry.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Framework                                  .\PaintDotNet.Framework.dll, Version=5.100.9082.35298
    CommunityToolkit.HighPerformance                       .\CommunityToolkit.HighPerformance.dll, Version=8.3.0.0, PublicKeyToken=4aff67a105548ee2
    System.Numerics.Vectors                                .\System.Numerics.Vectors.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.ThreadPool                            .\System.Threading.ThreadPool.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    ComputeSharp.D2D1                                      .\ComputeSharp.D2D1.dll, Version=3.0.1.0, PublicKeyToken=dc35fa229f6881d8
    Microsoft.Win32.SystemEvents                           .\Microsoft.Win32.SystemEvents.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Collections.Immutable                           .\System.Collections.Immutable.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PointerToolkit.TerraFX.Interop.Windows                 .\PointerToolkit.TerraFX.Interop.Windows.dll, Version=10.0.26100.0
    System.ComponentModel.TypeConverter                    .\System.ComponentModel.TypeConverter.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel.EventBasedAsync                  .\System.ComponentModel.EventBasedAsync.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Principal.Windows                      .\System.Security.Principal.Windows.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Claims                                 .\System.Security.Claims.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PresentationCore                                       .\PresentationCore.dll, Version=9.0.0.0, PublicKeyToken=31bf3856ad364e35
    DirectWriteForwarder                                   .\DirectWriteForwarder.dll, Version=9.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.Runtime.Extensions                              .\System.Runtime.Extensions.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.Debug                               .\System.Diagnostics.Debug.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.CompilerServices.VisualC                .\System.Runtime.CompilerServices.VisualC.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.NonGeneric                          .\System.Collections.NonGeneric.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.TraceSource                         .\System.Diagnostics.TraceSource.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.PropertySystem                             .\PaintDotNet.PropertySystem.dll, Version=5.100.9082.35298
    System.IO.Packaging                                    .\System.IO.Packaging.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Effects.Core                               .\PaintDotNet.Effects.Core.dll, Version=5.100.9082.35298
    Accessibility                                          .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.IO.Hashing                                      .\System.IO.Hashing.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    SauceControl.Blake2Fast                                .\SauceControl.Blake2Fast.dll, Version=2.0.0.0, PublicKeyToken=deebe556222e40dc
    PaintDotNet.Effects.Gpu                                .\PaintDotNet.Effects.Gpu.dll, Version=5.100.9082.35298
    System.Threading.Tasks.Parallel                        .\System.Threading.Tasks.Parallel.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Reflection.Metadata                             .\System.Reflection.Metadata.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.MemoryMappedFiles                            .\System.IO.MemoryMappedFiles.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Net.Http                                        .\System.Net.Http.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Net.Primitives                                  .\System.Net.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.DiagnosticSource                    .\System.Diagnostics.DiagnosticSource.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Net.Security                                    .\System.Net.Security.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Cryptography                           .\System.Security.Cryptography.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    ComputeSharp.Core                                      .\ComputeSharp.Core.dll, Version=3.0.1.0, PublicKeyToken=dc35fa229f6881d8
    PhotoSauce.MagicScaler                                 .\PhotoSauce.MagicScaler.dll, Version=0.15.0.0, PublicKeyToken=fc6b9b7b06809481
    System.Linq.Expressions                                .\System.Linq.Expressions.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Text.RegularExpressions                         .\System.Text.RegularExpressions.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Newtonsoft.Json                                        .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed
    System.Runtime.Numerics                                .\System.Runtime.Numerics.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Intrinsics                              .\System.Runtime.Intrinsics.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Runtime.Loader                                  .\System.Runtime.Loader.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Reflection.MetadataLoadContext                  .\System.Reflection.MetadataLoadContext.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Diagnostics.Process                             .\System.Diagnostics.Process.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Console                                         .\System.Console.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PhotoShop                                              .\FileTypes\PhotoShop.dll, Version=2.5.0.40665
    ImPS,EPS,AI.Open.FileType                              .\FileTypes\ImPS,EPS,AI.Open.FileType.dll, Version=1.0.0.0
    ImPDF.Open.FileType                                    .\FileTypes\ImPDF.Open.FileType.dll, Version=1.1.0.0
    ImAGIF.FileType                                        .\FileTypes\ImAGIF.FileType.dll, Version=0.12.0.1084
    ImPDF.Save.FileType                                    .\FileTypes\ImPDF.Save.FileType.dll, Version=1.4.5187.23557
    System.Windows.Forms.Legacy                            .\System.Windows.Forms.Legacy.dll, Version=1.0.0.0
    PaintDotNet.Plugins.Compatibility                      .\PaintDotNet.Plugins.Compatibility.dll, Version=5.100.9082.35298
    mscorlib                                               .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Drawing                                         .\System.Drawing.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System                                                 .\System.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Diagnostics.FileVersionInfo                     .\System.Diagnostics.FileVersionInfo.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    DdsFileTypePlus                                        .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.12.11.0
    WebPFileType                                           .\Bundled\WebPFileType\WebPFileType.dll, Version=1.4.0.0
    OptionBasedLibrary v0.6                                .\FileTypes\OptionBasedLibrary v0.6.dll, Version=0.5.0.0
    System.Core                                            .\System.Core.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    AvifFileType                                           .\Bundled\AvifFileType\AvifFileType.dll, Version=3.10.0.0
    System.Runtime.Serialization.Formatters                .\System.Runtime.Serialization.Formatters.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Effects                                    .\PaintDotNet.Effects.dll, Version=5.100.9082.35298
    PaintDotNet.Effects.Legacy                             .\PaintDotNet.Effects.Legacy.dll, Version=5.100.9082.35298
    Mono.Cecil                                             .\Mono.Cecil.dll, Version=0.11.6.0, PublicKeyToken=50cebf1cceb9d05e
    netstandard                                            .\netstandard.dll, Version=2.1.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.IO.Compression                                  .\System.IO.Compression.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Net.Sockets                                     .\System.Net.Sockets.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Overlapped                            .\System.Threading.Overlapped.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Net.NameResolution                              .\System.Net.NameResolution.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Vandermotten.PaintDotNetEffects.ObjectAlign            C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, Version=5.0.0.0
    Vandermotten.PaintDotNetEffects                        C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.dll, Version=5.0.0.0
    AA's_Assistant                                         .\Effects\AA_s_Assistant.dll, Version=1.1.4329.33034
    Anti-Alias by jsonchiu                                 .\Effects\Anti-Alias by jsonchiu.dll, Version=1.0.4348.36767
    Animal                                                 .\Effects\Animal.dll, Version=2.2.5.20384
    Alpha2Gray                                             .\Effects\Alpha2Gray.dll, Version=6.0.8407.21872
    ApplyMask                                              .\Effects\ApplyMask.dll, Version=6.0.8609.2294
    Outline Object                                         .\Effects\Outline Object.dll, Version=4.0.4642.26954
    ArtyThing                                              .\Effects\ArtyThing.dll, Version=1.0.5.0
    AutoChromeNoise                                        .\Effects\AutoChromeNoise.dll, Version=1.2.5.23331
    BandWPlus                                              .\Effects\BandWPlus.dll, Version=6.0.8407.21940
    AutoChrome                                             .\Effects\AutoChrome.dll, Version=1.2.5.19669
    System.Resources.Extensions                            .\System.Resources.Extensions.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    Bars                                                   .\Effects\Bars.dll, Version=1.2.5.23704
    Borders N' Shapes                                      .\Effects\Borders N_ Shapes.dll, Version=4.0.4642.26476
    BBOutlinedGradientText                                 .\Effects\BBOutlinedGradientText.dll, Version=6.0.8426.37652
    BBChart                                                .\Effects\BBChart.dll, Version=1.1.0.0
    Burninate                                              .\Effects\Burninate.dll, Version=6.0.8407.22069
    System.Windows.Forms.DataVisualization                 .\Effects\System.Windows.Forms.DataVisualization.dll, Version=1.0.0.0, PublicKeyToken=31bf3856ad364e35
    ChangeExtremeColors                                    .\Effects\ChangeExtremeColors.dll, Version=1.2.6.30674
    Calendar                                               .\Effects\Calendar.dll, Version=6.0.8478.32276
    Boutons                                                .\Effects\Boutons.dll, Version=1.2.5.23747
    CircleText                                             .\Effects\CircleText.dll, Version=1.4.4415.32488
    coloraberation                                         .\Effects\coloraberation.dll, Version=1.2.5.15647
    Color Match                                            .\Effects\Color Match.dll, Version=4.0.4642.26532
    ColorBalance                                           .\Effects\ColorBalance.dll, Version=6.0.8407.22111
    ColorModulo                                            .\Effects\ColorModulo.dll, Version=1.2.5.25136
    Vandermotten.PaintDotNetEffects.Monochromes            C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll, Version=5.0.0.0
    ColorZoomBlur                                          .\Effects\ColorZoomBlur.dll, Version=1.2.5.17431
    ColorToAlpha                                           .\Effects\ColorToAlpha.dll, Version=2.3.0.0
    CombinedAdjustments                                    .\Effects\CombinedAdjustments.dll, Version=6.0.8407.22130
    ComplementaryColors                                    .\Effects\ComplementaryColors.dll, Version=6.0.8407.23961
    ContentAwareFill                                       .\Effects\ContentAwareFill.dll, Version=1.5.1.0
    CreativeTextPro                                        .\Effects\CreativeTextPro.dll, Version=6.0.8407.22165
    Dimensions                                             .\Effects\Dimensions.dll, Version=1.3.6826.38472
    Curves+                                                .\Effects\Curves+.dll, Version=4.0.6119.31044
    Displacement                                           .\Effects\Displacement.dll, Version=1.3.5.15773
    DistortingMirror                                       .\Effects\DistortingMirror.dll, Version=1.2.5.15788
    Donut                                                  .\Effects\Donut.dll, Version=1.2.5.15739
    Dream                                                  .\Effects\Dream.dll, Version=6.0.8414.36727
    ExpandColor                                            .\Effects\ExpandColor.dll, Version=1.2.5.15745
    EdgeDetectClassic                                      .\Effects\EdgeDetectClassic.dll, Version=1.0.8424.19432
    FillFromClipboard                                      .\Effects\FillFromClipboard.dll, Version=6.0.8407.22397
    FillFromFile                                           .\Effects\FillFromFile.dll, Version=6.0.8407.22418
    FillPalette                                            .\Effects\FillPalette.dll, Version=1.2.5.32012
    Film                                                   .\Effects\Film.dll, Version=4.0.4642.26607
    Flip                                                   .\Effects\Flip.dll, Version=4.6.7358.36953
    FractalAttractor                                       .\Effects\FractalAttractor.dll, Version=1.3.5.27448
    Vandermotten.PaintDotNetEffects.MakeTransparent        C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.MakeTransparent.dll, Version=5.0.0.0
    Frames                                                 .\Effects\Frames.dll, Version=1.2.5.27903
    FractalFern                                            .\Effects\FractalFern.dll, Version=1.2.0.28378
    GaussianBlurPlus                                       .\Effects\GaussianBlurPlus.dll, Version=4.2.5691.27401
    FloydSteinbergDithering                                .\Effects\FloydSteinbergDithering.dll, Version=5.2.8174.39918
    FractalTree                                            .\Effects\FractalTree.dll, Version=1.2.0.38806
    Gen96Colors                                            .\Effects\Gen96Colors.dll, Version=1.2.0.15608
    Gradient Bars                                          .\Effects\Gradient Bars.dll, Version=4.0.5152.23084
    Gradient Blocks                                        .\Effects\Gradient Blocks.dll, Version=4.0.4642.26658
    Gradient Grid                                          .\Effects\Gradient Grid.dll, Version=4.0.6436.36068
    Vandermotten.PaintDotNetEffects.Grid                   C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.Grid.dll, Version=5.0.0.0
    GradientBlur                                           .\Effects\GradientBlur.dll, Version=1.2.5.28179
    Gravity                                                .\Effects\Gravity.dll, Version=1.2.5.29548
    Grain                                                  .\Effects\Grain.dll, Version=1.0.3854.25523
    Gray2Alpha                                             .\Effects\Gray2Alpha.dll, Version=6.0.8407.22439
    Grid Warp                                              .\Effects\Grid Warp.dll, Version=4.0.6544.34496
    GridMaker                                              .\Effects\GridMaker.dll, Version=5.2.5.29827
    GridCheckerboard                                       .\Effects\GridCheckerboard.dll, Version=5.2.8141.24786
    HilbertCurve                                           .\Effects\HilbertCurve.dll, Version=1.2.0.32151
    HexaGrid                                               .\Effects\HexaGrid.dll, Version=4.1.0.40699
    HueSatPlus                                             .\Effects\HueSatPlus.dll, Version=5.2.8174.40274
    Jitter                                                 .\Effects\Jitter.dll, Version=4.0.4642.26986
    JuliaPlus                                              .\Effects\JuliaPlus.dll, Version=1.2.5.13821
    KaleidoGen                                             .\Effects\KaleidoGen.dll, Version=1.3.5.30504
    Kaleidoscope                                           .\Effects\Kaleidoscope.dll, Version=1.6.1.27167
    Landscape                                              .\Effects\Landscape.dll, Version=5.2.8174.40347
    LensFlare                                              .\Effects\LensFlare.dll, Version=2.2.12.35124
    Vandermotten.PaintDotNetEffects.Gradient               C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, Version=5.0.0.0
    LevelHorizon                                           .\Effects\LevelHorizon.dll, Version=6.0.8407.22459
    LightRays                                              .\Effects\LightRays.dll, Version=2.1.5.14276
    Liquify                                                .\Effects\Liquify.dll, Version=4.0.5873.25113
    ListOfPalettes                                         .\Effects\ListOfPalettes.dll, Version=1.0.0.32564
    Magnifier                                              .\Effects\Magnifier.dll, Version=1.3.5.14308
    Majority                                               .\Effects\Majority.dll, Version=1.2.5.14328
    MemeMaker                                              .\Effects\MemeMaker.dll, Version=6.0.8407.22476
    Melting                                                .\Effects\Melting.dll, Version=1.3.6550.31783
    LookAtIt.Effect                                        .\Effects\LookAtIt.Effect.dll, Version=0.6.0.779
    Metallize                                              .\Effects\Metallize.dll, Version=1.2.4415.32969
    Moire                                                  .\Effects\Moire.dll, Version=1.2.5.14350
    Vandermotten.PaintDotNetEffects.FadeEdge               C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll, Version=5.0.0.0
    Nebulous                                               .\Effects\Nebulous.dll, Version=1.2.5.19527
    NewtonFractal                                          .\Effects\NewtonFractal.dll, Version=2.2.5.19770
    OilPaintingPlus                                        .\Effects\OilPaintingPlus.dll, Version=5.2.8141.27893
    Feather                                                .\Effects\OldFeather.dll, Version=2.3.4315.37038
    Oblique                                                .\Effects\Oblique.dll, Version=1.2.5.15730
    Overliner                                              .\Effects\Overliner.dll, Version=1.2.5.25545
    Vandermotten.PaintDotNetEffects.Duotones               C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll, Version=5.0.0.0
    PageCurl                                               .\Effects\PageCurl.dll, Version=1.5.5.23162
    Paneling                                               .\Effects\Paneling.dll, Version=1.2.5.23448
    PasteAlpha                                             .\Effects\PasteAlpha.dll, Version=5.2.8174.40450
    Pastel                                                 .\Effects\Pastel.dll, Version=5.2.8174.40506
    ObjectTools                                            .\Effects\ObjectTools.dll, Version=6.0.8482.2565
    MotionSharpen                                          .\Effects\MotionSharpen.dll, Version=1.2.5.19059
    PerlinTexture                                          .\Effects\PerlinTexture.dll, Version=2.2.5.23710
    Perspective                                            .\Effects\Perspective.dll, Version=2.1.4415.36116
    PhotoAdjustments                                       .\Effects\PhotoAdjustments.dll, Version=6.0.8416.38377
    Pixelate+                                              .\Effects\Pixelate+.dll, Version=4.0.4642.26940
    Polar                                                  .\Effects\Polar.dll, Version=1.2.5.24467
    PlugInData                                             .\Effects\PlugInData.dll, Version=1.4.0.0
    Radialcolors                                           .\Effects\Radialcolors.dll, Version=1.2.5.21672
    Polygones                                              .\Effects\Polygones.dll, Version=1.3.5.31866
    Vandermotten.PaintDotNetEffects.DropShadow             C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, Version=5.0.0.0
    RainbowTwist                                           .\Effects\RainbowTwist.dll, Version=1.2.5.25218
    Random Shape Fill                                      .\Effects\Random Shape Fill.dll, Version=4.0.4642.26910
    RandomMaze1                                            .\Effects\RandomMaze1.dll, Version=1.2.5.26409
    Random Effect                                          .\Effects\Random Effect.dll, Version=4.0.4642.26928
    Vandermotten.PaintDotNetEffects.ColorAccent            C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll, Version=5.0.0.0
    RecolorGray                                            .\Effects\RecolorGray.dll, Version=1.2.5.27251
    RandomMaze2                                            .\Effects\RandomMaze2.dll, Version=1.2.5.26820
    RegularNoise                                           .\Effects\RegularNoise.dll, Version=1.2.5.29080
    RemoveDust                                             .\Effects\RemoveDust.dll, Version=6.0.8407.22513
    ReverseColors                                          .\Effects\ReverseColors.dll, Version=1.2.5.29336
    Rosaces                                                .\Effects\Rosaces.dll, Version=1.2.5.29635
    RotateText                                             .\Effects\RotateText.dll, Version=1.1.4415.32628
    RandomLines                                            .\Effects\RandomLines.dll, Version=1.2.5.25981
    Vandermotten.PaintDotNetEffects.Blurs                  C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, Version=5.0.0.0
    SeamCarving                                            .\Effects\SeamCarving.dll, Version=5.2.8176.39366
    ScriptLab                                              .\Effects\ScriptLab.dll, Version=4.0.6107.18914
    SeamlessTextureMaker                                   .\Effects\SeamlessTextureMaker.dll, Version=1.2.5.29984
    Shapes                                                 .\Effects\Shapes.dll, Version=1.6.5.30197
    SelectionTools                                         .\Effects\SelectionTools.dll, Version=6.0.8412.38725
    SharpenClassic                                         .\Effects\SharpenClassic.dll, Version=1.0.8420.39106
    Sharpen+                                               .\Effects\Sharpen+.dll, Version=4.0.0.0
    Signature                                              .\Effects\Signature.dll, Version=1.5.6617.21474
    SinWaves                                               .\Effects\SinWaves.dll, Version=1.2.5.30582
    SmoothNoise                                            .\Effects\SmoothNoise.dll, Version=1.0.0.28227
    Smudge                                                 .\Effects\Smudge.dll, Version=4.0.5873.25097
    Sparkles                                               .\Effects\Sparkles.dll, Version=1.2.5.12788
    Spiral                                                 .\Effects\Spiral.dll, Version=1.2.5.12809
    SpiroShapes                                            .\Effects\SpiroShapes.dll, Version=2.2.5.16659
    Splashes                                               .\Effects\Splashes.dll, Version=1.2.5.13040
    SpiroGraph                                             .\Effects\SpiroGraph.dll, Version=1.2.5.12972
    Splatter                                               .\Effects\Splatter.dll, Version=4.0.5873.25083
    XYCoords                                               .\Effects\XYCoords.dll, Version=1.2.6.20985
    SpotCenter                                             .\Effects\SpotCenter.dll, Version=1.2.0.17265
    StarGlow                                               .\Effects\StarGlow.dll, Version=1.3.5.17930
    Stars                                                  .\Effects\Stars.dll, Version=2.0.0.25701
    Stipple                                                .\Effects\Stipple.dll, Version=1.0.0.0
    WetFloor                                               .\Effects\WetFloor.dll, Version=1.2.5.14166
    Stitch                                                 .\Effects\Stitch.dll, Version=4.0.4642.26808
    Tiles                                                  .\Effects\Tiles.dll, Version=1.2.5.13094
    TextPlus                                               .\Effects\Textplus.dll, Version=1.0.0.0
    TJacksonEffects                                        .\Effects\TJacksonEffects.dll, Version=1.0.0.0
    Tournesol                                              .\Effects\Tournesol.dll, Version=1.2.5.13128
    WaveTextSUI                                            .\Effects\WaveTextSUI.dll, Version=1.2.4415.33440
    Trail                                                  .\Effects\Trail.dll, Version=4.0.4642.26791
    Transparency                                           .\Effects\Transparency.dll, Version=6.0.8407.22532
    TRs Scatter                                            .\Effects\TRs Scatter.dll, Version=1.3.4949.23250
    TRsAlphaCutter                                         .\Effects\TRsAlphaCutter.dll, Version=3.0.4.0
    TRsFilmStock                                           .\Effects\TRsFilmStock.dll, Version=1.2.0.0
    TRsStr8Edge                                            .\Effects\TRsStr8Edge.dll, Version=1.1.5045.31905
    WaveText                                               .\Effects\WaveText.dll, Version=1.2.4415.32811
    TRsKeyFrame                                            .\Effects\TRsKeyFrame.dll, Version=1.2.5693.38036
    TubeOblique                                            .\Effects\TubeOblique.dll, Version=1.2.5.15697
    Twist                                                  .\Effects\Twist.dll, Version=4.0.5873.25056
    TwistZ                                                 .\Effects\TwistZ.dll, Version=1.2.5.13350
    Waves                                                  .\Effects\Waves.dll, Version=1.2.5.14072
    Vibrato                                                .\Effects\Vibrato.dll, Version=2.0.5.13530
    VignettePlus                                           .\Effects\VignettePlus.dll, Version=6.0.8407.22549
    Volutes                                                .\Effects\Volutes.dll, Version=1.3.5.13753
    WaterReflection                                        .\Effects\WaterReflection.dll, Version=1.2.5.15754
    EdHarvey.Effects                                       .\Effects\EdHarvey.Effects.dll, Version=4.0.5120.42730
    System.Design                                          .\System.Design.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Windows.Forms.Design                            .\System.Windows.Forms.Design.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089
    Temperature                                            .\Effects\Temperature.dll, Version=1.4.6255.42224
    Polygon                                                .\Effects\Polygon.dll, Version=4.5.6828.38648
    HSVGradients                                           .\Effects\HSVGradients.dll, Version=4.5.6832.41864
    Sierpinski                                             .\Effects\Sierpinski.dll, Version=2.2.5.30414
    EditableText                                           .\Effects\EditableText.dll, Version=1.0.1.0
    CustomBrushesMini                                      .\Effects\CustomBrushesMini.dll, Version=2.2.5286.39584
    Gradient Mapping                                       .\Effects\Gradient Mapping.dll, Version=4.0.6547.33963
Native modules                                             411
    paintdotnet.exe                                        .\paintdotnet.exe, version=5.100.9082.35298
    ntdll.dll                                              C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.22621.4249 (WinBuild.160101.0800)
    KERNEL32.DLL                                           C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.22621.4391 (WinBuild.160101.0800)
    KERNELBASE.dll                                         C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.22621.4391 (WinBuild.160101.0800)
    SHELL32.dll                                            C:\WINDOWS\System32\SHELL32.dll, version=10.0.22621.4249 (WinBuild.160101.0800)
    msvcp_win.dll                                          C:\WINDOWS\System32\msvcp_win.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    ucrtbase.dll                                           C:\WINDOWS\System32\ucrtbase.dll, version=10.0.22621.3593 (WinBuild.160101.0800)
    USER32.dll                                             C:\WINDOWS\System32\USER32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    win32u.dll                                             C:\WINDOWS\System32\win32u.dll, version=10.0.22621.4460 (WinBuild.160101.0800)
    GDI32.dll                                              C:\WINDOWS\System32\GDI32.dll, version=10.0.22621.4036 (WinBuild.160101.0800)
    gdi32full.dll                                          C:\WINDOWS\System32\gdi32full.dll, version=10.0.22621.4391 (WinBuild.160101.0800)
    ole32.dll                                              C:\WINDOWS\System32\ole32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    combase.dll                                            C:\WINDOWS\System32\combase.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    RPCRT4.dll                                             C:\WINDOWS\System32\RPCRT4.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    OLEAUT32.dll                                           C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.22621.3672 (WinBuild.160101.0800)
    SHLWAPI.dll                                            C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    msvcrt.dll                                             C:\WINDOWS\System32\msvcrt.dll, version=7.0.22621.2506 (WinBuild.160101.0800)
    VCRUNTIME140.dll                                       .\VCRUNTIME140.dll, version=14.42.34433.0
    VCRUNTIME140_1.dll                                     .\VCRUNTIME140_1.dll, version=14.42.34433.0
    IMM32.DLL                                              C:\WINDOWS\System32\IMM32.DLL, version=10.0.22621.3374 (WinBuild.160101.0800)
    shcore.dll                                             C:\WINDOWS\System32\shcore.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    hostfxr.dll                                            .\hostfxr.dll, version=9,0,24,52809 @Commit: 9d5a6a9aa463d6d10b0b0ba6d5982cc82f363dc3
    ADVAPI32.dll                                           C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    sechost.dll                                            C:\WINDOWS\System32\sechost.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    bcrypt.dll                                             C:\WINDOWS\System32\bcrypt.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    hostpolicy.dll                                         .\hostpolicy.dll, version=9,0,24,52809 @Commit: 9d5a6a9aa463d6d10b0b0ba6d5982cc82f363dc3
    coreclr.dll                                            .\coreclr.dll, version=9,0,24,52809 @Commit: 9d5a6a9aa463d6d10b0b0ba6d5982cc82f363dc3
    bcryptPrimitives.dll                                   C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.22621.4317 (WinBuild.160101.0800)
    System.Private.CoreLib.dll                             .\System.Private.CoreLib.dll, version=9.0.24.52809
    kernel.appcore.dll                                     C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.22621.3958 (WinBuild.160101.0800)
    paintdotnet.dll                                        .\paintdotnet.dll, version=5.100.9082.35298
    System.Runtime.dll                                     .\System.Runtime.dll, version=9.0.24.52809
    uxtheme.dll                                            C:\WINDOWS\system32\uxtheme.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    PaintDotNet.Windows.Core.dll                           .\PaintDotNet.Windows.Core.dll, version=5.100.9082.35298
    PaintDotNet.Windows.dll                                .\PaintDotNet.Windows.dll, version=5.100.9082.35298
    PaintDotNet.ComponentModel.dll                         .\PaintDotNet.ComponentModel.dll, version=5.100.9082.35298
    PaintDotNet.Primitives.dll                             .\PaintDotNet.Primitives.dll, version=5.100.9082.35298
    PaintDotNet.Fundamentals.dll                           .\PaintDotNet.Fundamentals.dll, version=5.100.9082.35298
    System.Windows.Forms.dll                               .\System.Windows.Forms.dll, version=9.0.24.52901
    System.Diagnostics.Tracing.dll                         .\System.Diagnostics.Tracing.dll, version=9.0.24.52809
    clrjit.dll                                             .\clrjit.dll, version=9,0,24,52809 @Commit: 9d5a6a9aa463d6d10b0b0ba6d5982cc82f363dc3
    icu.dll                                                C:\WINDOWS\SYSTEM32\icu.dll, version=68, 2, 0, 10 (WinBuild.160101.0800)
    System.Threading.Thread.dll                            .\System.Threading.Thread.dll, version=9.0.24.52809
    PaintDotNet.Base.dll                                   .\PaintDotNet.Base.dll, version=5.100.9082.35298
    PaintDotNet.Collections.dll                            .\PaintDotNet.Collections.dll, version=5.100.9082.35298
    TerraFX.Interop.Windows.dll                            .\TerraFX.Interop.Windows.dll, version=10.0.26100.0
    dxgi.DLL                                               C:\WINDOWS\SYSTEM32\dxgi.DLL, version=10.0.22621.4036 (WinBuild.160101.0800)
    dxcore.dll                                             C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.22621.4391 (WinBuild.160101.0800)
    PaintDotNet.Runtime.dll                                .\PaintDotNet.Runtime.dll, version=5.100.9082.35298
    System.Collections.Concurrent.dll                      .\System.Collections.Concurrent.dll, version=9.0.24.52809
    PointerToolkit.dll                                     .\PointerToolkit.dll, version=1.0.1.0
    PaintDotNet.Systrace.dll                               .\PaintDotNet.Systrace.dll, version=5.100.9082.35298
    windows.storage.dll                                    C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.22621.3527 (WinBuild.160101.0800)
    wintypes.dll                                           C:\WINDOWS\SYSTEM32\wintypes.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Private.Uri.dll                                 .\System.Private.Uri.dll, version=9.0.24.52809
    PaintDotNet.UI.dll                                     .\PaintDotNet.UI.dll, version=5.100.9082.35298
    PaintDotNet.Windows.Framework.dll                      .\PaintDotNet.Windows.Framework.dll, version=5.100.9082.35298
    WindowsBase.dll                                        .\WindowsBase.dll, version=9.0.24.52902
    Microsoft.Windows.SDK.NET.dll                          .\Microsoft.Windows.SDK.NET.dll, version=10.0.26100.52
    PaintDotNet.ObjectModel.dll                            .\PaintDotNet.ObjectModel.dll, version=5.100.9082.35298
    WinRT.Runtime.dll                                      .\WinRT.Runtime.dll, version=2.1.6.47881
    PresentationFramework.dll                              .\PresentationFramework.dll, version=9.0.24.52902
    System.Runtime.InteropServices.dll                     .\System.Runtime.InteropServices.dll, version=9.0.24.52809
    System.Xaml.dll                                        .\System.Xaml.dll, version=9.0.24.52902
    System.ComponentModel.dll                              .\System.ComponentModel.dll, version=9.0.24.52809
    coremessaging.DLL                                      C:\WINDOWS\SYSTEM32\coremessaging.DLL, version=10.0.22621.4391 (WinBuild.160101.0800)
    System.ComponentModel.Primitives.dll                   .\System.ComponentModel.Primitives.dll, version=9.0.24.52809
    System.ObjectModel.dll                                 .\System.ObjectModel.dll, version=9.0.24.52809
    System.Collections.dll                                 .\System.Collections.dll, version=9.0.24.52809
    System.Threading.dll                                   .\System.Threading.dll, version=9.0.24.52809
    System.Windows.Forms.Primitives.dll                    .\System.Windows.Forms.Primitives.dll, version=9.0.24.52901
    Microsoft.Win32.Primitives.dll                         .\Microsoft.Win32.Primitives.dll, version=9.0.24.52809
    System.Private.Windows.Core.dll                        .\System.Private.Windows.Core.dll, version=9.0.24.52901
    System.Drawing.Primitives.dll                          .\System.Drawing.Primitives.dll, version=9.0.24.52809
    System.Text.Encoding.CodePages.dll                     .\System.Text.Encoding.CodePages.dll, version=9.0.24.52809
    PresentationNative_cor3.dll                            .\PresentationNative_cor3.dll, version=9,0,24,47404 @Commit: c7dea8ec4c32ed09d3cedbdd1f967a276b3f75c0
    PaintDotNet.Core.dll                                   .\PaintDotNet.Core.dll, version=5.100.9082.35298
    System.Configuration.ConfigurationManager.dll          .\System.Configuration.ConfigurationManager.dll, version=9.0.24.52809
    PaintDotNet.SystemLayer.dll                            .\PaintDotNet.SystemLayer.dll, version=5.100.9082.35298
    System.Collections.Specialized.dll                     .\System.Collections.Specialized.dll, version=9.0.24.52809
    PaintDotNet.Resources.dll                              .\PaintDotNet.Resources.dll, version=5.100.9082.35298
    System.Xml.ReaderWriter.dll                            .\System.Xml.ReaderWriter.dll, version=9.0.24.52809
    System.Private.Xml.dll                                 .\System.Private.Xml.dll, version=9.0.24.52809
    System.Drawing.Common.dll                              .\System.Drawing.Common.dll, version=9.0.24.52901
    System.Net.WebClient.dll                               .\System.Net.WebClient.dll, version=9.0.24.52809
    System.Linq.dll                                        .\System.Linq.dll, version=9.0.24.52809
    System.Memory.dll                                      .\System.Memory.dll, version=9.0.24.52809
    System.Text.Encoding.Extensions.dll                    .\System.Text.Encoding.Extensions.dll, version=9.0.24.52809
    PaintDotNet.Data.dll                                   .\PaintDotNet.Data.dll, version=5.100.9082.35298
    Microsoft.Win32.Registry.dll                           .\Microsoft.Win32.Registry.dll, version=9.0.24.52809
    PaintDotNet.Framework.dll                              .\PaintDotNet.Framework.dll, version=5.100.9082.35298
    CommunityToolkit.HighPerformance.dll                   .\CommunityToolkit.HighPerformance.dll, version=8.3.2.1
    System.Numerics.Vectors.dll                            .\System.Numerics.Vectors.dll, version=9.0.24.52809
    System.Threading.ThreadPool.dll                        .\System.Threading.ThreadPool.dll, version=9.0.24.52809
    directxdatabasehelper.dll                              C:\WINDOWS\SYSTEM32\directxdatabasehelper.dll, version=10.0.22621.4391 (WinBuild.160101.0800)
    ComputeSharp.D2D1.dll                                  .\ComputeSharp.D2D1.dll, version=3.0.1.0
    Microsoft.Win32.SystemEvents.dll                       .\Microsoft.Win32.SystemEvents.dll, version=9.0.24.52809
    System.Collections.Immutable.dll                       .\System.Collections.Immutable.dll, version=9.0.24.52809
    MSCTF.dll                                              C:\WINDOWS\System32\MSCTF.dll, version=10.0.22621.4317 (WinBuild.160101.0800)
    PointerToolkit.TerraFX.Interop.Windows.dll             .\PointerToolkit.TerraFX.Interop.Windows.dll, version=10.0.26100.0
    System.ComponentModel.TypeConverter.dll                .\System.ComponentModel.TypeConverter.dll, version=9.0.24.52809
    System.ComponentModel.EventBasedAsync.dll              .\System.ComponentModel.EventBasedAsync.dll, version=9.0.24.52809
    System.Security.Principal.Windows.dll                  .\System.Security.Principal.Windows.dll, version=9.0.24.52809
    profapi.dll                                            C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.22621.4391 (WinBuild.160101.0800)
    System.Security.Claims.dll                             .\System.Security.Claims.dll, version=9.0.24.52809
    PresentationCore.dll                                   .\PresentationCore.dll, version=9.0.24.52902
    dwrite.dll                                             C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    DirectWriteForwarder.dll                               .\DirectWriteForwarder.dll, version=9,0,24,52902 @Commit: a04736acb8edb533756131d3d5fc55f15cd03d6a
    System.Runtime.Extensions.dll                          .\System.Runtime.Extensions.dll, version=9.0.24.52809
    System.Diagnostics.Debug.dll                           .\System.Diagnostics.Debug.dll, version=9.0.24.52809
    System.Runtime.CompilerServices.VisualC.dll            .\System.Runtime.CompilerServices.VisualC.dll, version=9.0.24.52809
    System.Collections.NonGeneric.dll                      .\System.Collections.NonGeneric.dll, version=9.0.24.52809
    d2d1.DLL                                               C:\WINDOWS\SYSTEM32\d2d1.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Diagnostics.TraceSource.dll                     .\System.Diagnostics.TraceSource.dll, version=9.0.24.52809
    d3d11.DLL                                              C:\WINDOWS\SYSTEM32\d3d11.DLL, version=10.0.22621.4391 (WinBuild.160101.0800)
    amdxx64.dll                                            C:\WINDOWS\System32\DriverStore\FileRepository\u0407412.inf_amd64_101d3d4e34955a9f\B407018\amdxx64.dll, version=9.17.11.0069
    SETUPAPI.dll                                           C:\WINDOWS\System32\SETUPAPI.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    WINMM.dll                                              C:\WINDOWS\SYSTEM32\WINMM.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    clbcatq.dll                                            C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800)
    UIAnimation.dll                                        C:\WINDOWS\System32\UIAnimation.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    atidxx64.dll                                           C:\WINDOWS\system32\atidxx64.dll, version=9.17.11.0069
    apphelp.dll                                            C:\WINDOWS\SYSTEM32\apphelp.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    amdenc64.dll                                           C:\WINDOWS\System32\DriverStore\FileRepository\u0407412.inf_amd64_101d3d4e34955a9f\B407018\amdenc64.dll, version=
    XmlLite.dll                                            C:\WINDOWS\SYSTEM32\XmlLite.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    amdihk64.dll                                           C:\WINDOWS\System32\DriverStore\FileRepository\u0407412.inf_amd64_101d3d4e34955a9f\B407018\amdihk64.dll, version=2,00,00,1788
    PaintDotNet.PropertySystem.dll                         .\PaintDotNet.PropertySystem.dll, version=5.100.9082.35298
    System.IO.Packaging.dll                                .\System.IO.Packaging.dll, version=9.0.24.52809
    gdiplus.dll                                            C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.22621.4455_none_57fc69f8ce16b9dd\gdiplus.dll, version=10.0.22621.4455 (WinBuild.160101.0800)
    WindowsCodecs.dll                                      C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.22621.4455 (WinBuild.160101.0800)
    PaintDotNet.Effects.Core.dll                           .\PaintDotNet.Effects.Core.dll, version=5.100.9082.35298
    wtsapi32.dll                                           C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    WINSTA.dll                                             C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.22621.4391 (WinBuild.160101.0800)
    Accessibility.dll                                      .\Accessibility.dll, version=9.0.24.52901
    comctl32.dll                                           C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.22621.4391_none_2715d37f73803e96\comctl32.dll, version=6.10 (WinBuild.160101.0800)
    System.IO.Hashing.dll                                  .\System.IO.Hashing.dll, version=9.0.24.52809
    SauceControl.Blake2Fast.dll                            .\SauceControl.Blake2Fast.dll, version=2.0.0.0
    PaintDotNet.Effects.Gpu.dll                            .\PaintDotNet.Effects.Gpu.dll, version=5.100.9082.35298
    System.Threading.Tasks.Parallel.dll                    .\System.Threading.Tasks.Parallel.dll, version=9.0.24.52809
    System.Reflection.Metadata.dll                         .\System.Reflection.Metadata.dll, version=9.0.24.52809
    System.IO.MemoryMappedFiles.dll                        .\System.IO.MemoryMappedFiles.dll, version=9.0.24.52809
    System.Net.Http.dll                                    .\System.Net.Http.dll, version=9.0.24.52809
    System.Net.Primitives.dll                              .\System.Net.Primitives.dll, version=9.0.24.52809
    System.Diagnostics.DiagnosticSource.dll                .\System.Diagnostics.DiagnosticSource.dll, version=9.0.24.52809
    System.Net.Security.dll                                .\System.Net.Security.dll, version=9.0.24.52809
    System.Security.Cryptography.dll                       .\System.Security.Cryptography.dll, version=9.0.24.52809
    ComputeSharp.Core.dll                                  .\ComputeSharp.Core.dll, version=3.0.1.0
    PhotoSauce.MagicScaler.dll                             .\PhotoSauce.MagicScaler.dll, version=0.15.0.0
    System.Linq.Expressions.dll                            .\System.Linq.Expressions.dll, version=9.0.24.52809
    System.Text.RegularExpressions.dll                     .\System.Text.RegularExpressions.dll, version=9.0.24.52809
    Newtonsoft.Json.dll                                    .\Newtonsoft.Json.dll, version=13.0.3.27908
    System.Runtime.Numerics.dll                            .\System.Runtime.Numerics.dll, version=9.0.24.52809
    System.Runtime.Intrinsics.dll                          .\System.Runtime.Intrinsics.dll, version=9.0.24.52809
    TextShaping.dll                                        C:\WINDOWS\SYSTEM32\TextShaping.dll, version=10.0.22621.4391 (WinBuild.160101.0800)
    System.Runtime.Loader.dll                              .\System.Runtime.Loader.dll, version=9.0.24.52809
    D3D10Warp.dll                                          C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.22621.4249 (WinBuild.160101.0800)
    UIAutomationCore.dll                                   C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.22621.1 (WinBuild.160101.0800)
    d3dcompiler_47.DLL                                     C:\WINDOWS\SYSTEM32\d3dcompiler_47.DLL, version=10.0.22621.2506 (WinBuild.160101.0800)
    CRYPTSP.dll                                            C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.22621.3672 (WinBuild.160101.0800)
    mscms.DLL                                              C:\WINDOWS\SYSTEM32\mscms.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    icm32.dll                                              C:\WINDOWS\SYSTEM32\icm32.dll, version=10.0.22621.4455 (WinBuild.160101.0800)
    Cabinet.dll                                            C:\WINDOWS\SYSTEM32\Cabinet.dll, version=5.00 (WinBuild.160101.0800)
    dwmapi.DLL                                             C:\WINDOWS\SYSTEM32\dwmapi.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    Windows.Graphics.dll                                   C:\Windows\System32\Windows.Graphics.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    cfgmgr32.dll                                           C:\WINDOWS\SYSTEM32\cfgmgr32.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    dataexchange.dll                                       C:\WINDOWS\system32\dataexchange.dll, version=10.0.22621.3672 (WinBuild.160101.0800)
    twinapi.appcore.dll                                    C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    powrprof.dll                                           C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    UMPDC.dll                                              C:\WINDOWS\SYSTEM32\UMPDC.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    textinputframework.dll                                 C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.22621.4391 (WinBuild.160101.0800)
    windowscodecsext.dll                                   C:\WINDOWS\system32\windowscodecsext.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    PaintDotNet.SystemLayer.Native.x64.dll                 .\PaintDotNet.SystemLayer.Native.x64.dll, version=5.100.9082.35298
    dcomp.dll                                              C:\Windows\System32\dcomp.dll, version=10.0.22621.4249 (WinBuild.160101.0800)
    CRYPTBASE.DLL                                          C:\WINDOWS\SYSTEM32\CRYPTBASE.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Reflection.MetadataLoadContext.dll              .\System.Reflection.MetadataLoadContext.dll, version=9.0.24.52809
    System.Diagnostics.Process.dll                         .\System.Diagnostics.Process.dll, version=9.0.24.52809
    System.Console.dll                                     .\System.Console.dll, version=9.0.24.52809
    PhotoShop.dll                                          .\FileTypes\PhotoShop.dll, version=2.5.0.0
    ImPS,EPS,AI.Open.FileType.dll                          .\FileTypes\ImPS,EPS,AI.Open.FileType.dll, version=1.0.0.0
    ImPDF.Open.FileType.dll                                .\FileTypes\ImPDF.Open.FileType.dll, version=1.1.0.0
    ImAGIF.FileType.dll                                    .\FileTypes\ImAGIF.FileType.dll, version=0.12.0.1084
    ImPDF.Save.FileType.dll                                .\FileTypes\ImPDF.Save.FileType.dll, version=1.4.5187.23557
    System.Windows.Forms.Legacy.dll                        .\System.Windows.Forms.Legacy.dll, version=1.0.0.0
    PaintDotNet.Plugins.Compatibility.dll                  .\PaintDotNet.Plugins.Compatibility.dll, version=5.100.9082.35298
    mscorlib.dll                                           .\mscorlib.dll, version=9.0.24.52809
    System.Drawing.dll                                     .\System.Drawing.dll, version=9.0.24.52901
    mfplat.dll                                             C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    RTWorkQ.DLL                                            C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    System.dll                                             .\System.dll, version=9.0.24.52809
    amsi.dll                                               C:\WINDOWS\SYSTEM32\amsi.dll, version=10.0.22621.3527 (WinBuild.160101.0800)
    CompPkgSup.DLL                                         C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.22621.3527 (WinBuild.160101.0800)
    System.Diagnostics.FileVersionInfo.dll                 .\System.Diagnostics.FileVersionInfo.dll, version=9.0.24.52809
    USERENV.dll                                            C:\WINDOWS\SYSTEM32\USERENV.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    version.dll                                            C:\WINDOWS\SYSTEM32\version.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    MpOav.dll                                              C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24090.11-0\MpOav.dll, version=4.18.24090.11 (26d75470953920f90fd0438874501e9d9a31e621)
    MPCLIENT.DLL                                           C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24090.11-0\MPCLIENT.DLL, version=4.18.24090.11 (26d75470953920f90fd0438874501e9d9a31e621)
    CRYPT32.dll                                            C:\WINDOWS\System32\CRYPT32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    WINTRUST.dll                                           C:\WINDOWS\System32\WINTRUST.dll, version=10.0.22621.4391 (WinBuild.160101.0800)
    MSASN1.dll                                             C:\WINDOWS\System32\MSASN1.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    Windows.StateRepositoryPS.dll                          C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.22621.4036 (WinBuild.160101.0800)
    gpapi.dll                                              C:\WINDOWS\SYSTEM32\gpapi.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    windows.staterepositoryclient.dll                      C:\WINDOWS\SYSTEM32\windows.staterepositoryclient.dll, version=10.0.22621.4036 (WinBuild.160101.0800)
    windows.staterepositorycore.dll                        C:\WINDOWS\SYSTEM32\windows.staterepositorycore.dll, version=10.0.22621.4036 (WinBuild.160101.0800)
    DdsFileTypePlus.dll                                    .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.12.11.0
    WebPFileType.dll                                       .\Bundled\WebPFileType\WebPFileType.dll, version=1.4.0.0
    System.Core.dll                                        .\System.Core.dll, version=9.0.24.52809
    AvifFileType.dll                                       .\Bundled\AvifFileType\AvifFileType.dll, version=3.10.0.0
    System.Runtime.Serialization.Formatters.dll            .\System.Runtime.Serialization.Formatters.dll, version=9.0.24.52809
    PaintDotNet.Effects.dll                                .\PaintDotNet.Effects.dll, version=5.100.9082.35298
    PaintDotNet.Effects.Legacy.dll                         .\PaintDotNet.Effects.Legacy.dll, version=5.100.9082.35298
    iphlpapi.dll                                           C:\WINDOWS\SYSTEM32\iphlpapi.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    DNSAPI.dll                                             C:\WINDOWS\SYSTEM32\DNSAPI.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    NSI.dll                                                C:\WINDOWS\System32\NSI.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    dhcpcsvc6.DLL                                          C:\WINDOWS\SYSTEM32\dhcpcsvc6.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    dhcpcsvc.DLL                                           C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    WINNSI.DLL                                             C:\WINDOWS\SYSTEM32\WINNSI.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    winhttp.dll                                            C:\WINDOWS\SYSTEM32\winhttp.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    WS2_32.dll                                             C:\WINDOWS\System32\WS2_32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    Mono.Cecil.dll                                         .\Mono.Cecil.dll, version=0.11.6.0
    netstandard.dll                                        .\netstandard.dll, version=9.0.24.52809
    CoreUIComponents.dll                                   C:\WINDOWS\SYSTEM32\CoreUIComponents.dll, version=10.0.22621.4391
    System.IO.Compression.dll                              .\System.IO.Compression.dll, version=9.0.24.52809
    System.Net.Sockets.dll                                 .\System.Net.Sockets.dll, version=9.0.24.52809
    mswsock.dll                                            C:\WINDOWS\system32\mswsock.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    wshunix.dll                                            C:\WINDOWS\system32\wshunix.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Threading.Overlapped.dll                        .\System.Threading.Overlapped.dll, version=9.0.24.52809
    System.Net.NameResolution.dll                          .\System.Net.NameResolution.dll, version=9.0.24.52809
    Vandermotten.PaintDotNetEffects.ObjectAlign.dll        C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, version=5.0.3.0
    Vandermotten.PaintDotNetEffects.dll                    C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.dll, version=5.0.3.0
    AA_s_Assistant.dll                                     .\Effects\AA_s_Assistant.dll, version=1.1.4329.33034
    Anti-Alias by jsonchiu.dll                             .\Effects\Anti-Alias by jsonchiu.dll, version=1.0.4348.36767
    Animal.dll                                             .\Effects\Animal.dll, version=2.2.5.0
    Alpha2Gray.dll                                         .\Effects\Alpha2Gray.dll, version=6.0.8407.21872
    ApplyMask.dll                                          .\Effects\ApplyMask.dll, version=6.0.8609.2294
    AnimationEffect.dll                                    .\Effects\AnimationEffect.dll, version=1.0.0.96
    ArtyThing.dll                                          .\Effects\ArtyThing.dll, version=1.0.5.0
    nlansp_c.dll                                           C:\WINDOWS\system32\nlansp_c.dll, version=10.0.22621.4391 (WinBuild.160101.0800)
    rasadhlp.dll                                           C:\Windows\System32\rasadhlp.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    napinsp.dll                                            C:\WINDOWS\system32\napinsp.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    winrnr.dll                                             C:\WINDOWS\System32\winrnr.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    pnrpnsp.dll                                            C:\WINDOWS\system32\pnrpnsp.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    wshbth.dll                                             C:\WINDOWS\system32\wshbth.dll, version=10.0.22621.3958 (WinBuild.160101.0800)
    DEVOBJ.dll                                             C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    AutoChromeNoise.dll                                    .\Effects\AutoChromeNoise.dll, version=1.2.5.0
    BandWPlus.dll                                          .\Effects\BandWPlus.dll, version=6.0.8407.21940
    AutoChrome.dll                                         .\Effects\AutoChrome.dll, version=1.2.5.0
    System.Resources.Extensions.dll                        .\System.Resources.Extensions.dll, version=9.0.24.52809
    Bars.dll                                               .\Effects\Bars.dll, version=1.2.5.0
    Borders N_ Shapes.dll                                  .\Effects\Borders N_ Shapes.dll, version=4.0.4642.26476
    BBOutlinedGradientText.dll                             .\Effects\BBOutlinedGradientText.dll, version=6.0.8426.37652
    BBChart.dll                                            .\Effects\BBChart.dll, version=1.1.0.0
    Burninate.dll                                          .\Effects\Burninate.dll, version=6.0.8407.22069
    System.Windows.Forms.DataVisualization.dll             .\Effects\System.Windows.Forms.DataVisualization.dll, version=1.0.20.11001
    ChangeExtremeColors.dll                                .\Effects\ChangeExtremeColors.dll, version=1.2.6.0
    Calendar.dll                                           .\Effects\Calendar.dll, version=6.0.8478.32276
    Boutons.dll                                            .\Effects\Boutons.dll, version=1.2.5.0
    CircleText.dll                                         .\Effects\CircleText.dll, version=1.4.4415.32488
    coloraberation.dll                                     .\Effects\coloraberation.dll, version=1.2.5.0
    Color Match.dll                                        .\Effects\Color Match.dll, version=4.0.4642.26532
    ColorBalance.dll                                       .\Effects\ColorBalance.dll, version=6.0.8407.22111
    ColorModulo.dll                                        .\Effects\ColorModulo.dll, version=1.2.5.0
    Vandermotten.PaintDotNetEffects.Monochromes.dll        C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll, version=5.0.3.0
    ColorZoomBlur.dll                                      .\Effects\ColorZoomBlur.dll, version=1.2.5.0
    ColorToAlpha.dll                                       .\Effects\ColorToAlpha.dll, version=2.3.0.0
    CombinedAdjustments.dll                                .\Effects\CombinedAdjustments.dll, version=6.0.8407.22130
    ComplementaryColors.dll                                .\Effects\ComplementaryColors.dll, version=6.0.8407.23961
    ContentAwareFill.dll                                   .\Effects\ContentAwareFill.dll, version=1.5.1.0
    CreativeTextPro.dll                                    .\Effects\CreativeTextPro.dll, version=6.0.8407.22165
    Dimensions.dll                                         .\Effects\Dimensions.dll, version=1.3.6826.38472
    Curves+.dll                                            .\Effects\Curves+.dll, version=4.0.6119.31044
    Displacement.dll                                       .\Effects\Displacement.dll, version=1.3.5.0
    DistortingMirror.dll                                   .\Effects\DistortingMirror.dll, version=1.2.5.0
    Donut.dll                                              .\Effects\Donut.dll, version=1.2.5.0
    Dream.dll                                              .\Effects\Dream.dll, version=6.0.8414.36727
    ExpandColor.dll                                        .\Effects\ExpandColor.dll, version=1.2.5.0
    EdgeDetectClassic.dll                                  .\Effects\EdgeDetectClassic.dll, version=1.0.8424.19432
    FillFromClipboard.dll                                  .\Effects\FillFromClipboard.dll, version=6.0.8407.22397
    FillFromFile.dll                                       .\Effects\FillFromFile.dll, version=6.0.8407.22418
    FillPalette.dll                                        .\Effects\FillPalette.dll, version=1.2.5.0
    Film.dll                                               .\Effects\Film.dll, version=4.0.4642.26607
    Flip.dll                                               .\Effects\Flip.dll, version=4.6.7358.36953
    FractalAttractor.dll                                   .\Effects\FractalAttractor.dll, version=1.3.5.0
    Vandermotten.PaintDotNetEffects.MakeTransparent.dll    C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.MakeTransparent.dll, version=5.0.3.0
    Frames.dll                                             .\Effects\Frames.dll, version=1.2.5.0
    FractalFern.dll                                        .\Effects\FractalFern.dll, version=1.2.0.0
    GaussianBlurPlus.dll                                   .\Effects\GaussianBlurPlus.dll, version=4.2.5691.27401
    FloydSteinbergDithering.dll                            .\Effects\FloydSteinbergDithering.dll, version=5.2.8174.39918
    FractalTree.dll                                        .\Effects\FractalTree.dll, version=1.2.0.0
    Gen96Colors.dll                                        .\Effects\Gen96Colors.dll, version=1.2.0.0
    fwpuclnt.dll                                           C:\WINDOWS\System32\fwpuclnt.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    Gradient Bars.dll                                      .\Effects\Gradient Bars.dll, version=4.0.5152.23084
    Gradient Blocks.dll                                    .\Effects\Gradient Blocks.dll, version=4.0.4642.26658
    Gradient Grid.dll                                      .\Effects\Gradient Grid.dll, version=4.0.6436.36068
    Vandermotten.PaintDotNetEffects.Grid.dll               C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.Grid.dll, version=5.0.3.0
    GradientBlur.dll                                       .\Effects\GradientBlur.dll, version=1.2.5.0
    Gravity.dll                                            .\Effects\Gravity.dll, version=1.2.5.0
    Grain.dll                                              .\Effects\Grain.dll, version=1.0.3854.25523
    Gray2Alpha.dll                                         .\Effects\Gray2Alpha.dll, version=6.0.8407.22439
    Grid Warp.dll                                          .\Effects\Grid Warp.dll, version=4.0.6544.34496
    GridMaker.dll                                          .\Effects\GridMaker.dll, version=5.2.5.0
    GridCheckerboard.dll                                   .\Effects\GridCheckerboard.dll, version=5.2.8141.24786
    HilbertCurve.dll                                       .\Effects\HilbertCurve.dll, version=1.2.0.0
    HexaGrid.dll                                           .\Effects\HexaGrid.dll, version=4.1.0.0
    HueSatPlus.dll                                         .\Effects\HueSatPlus.dll, version=5.2.8174.40274
    Jitter.dll                                             .\Effects\Jitter.dll, version=4.0.4642.26986
    JuliaPlus.dll                                          .\Effects\JuliaPlus.dll, version=1.2.5.0
    KaleidoGen.dll                                         .\Effects\KaleidoGen.dll, version=1.3.5.0
    Kaleidoscope.dll                                       .\Effects\Kaleidoscope.dll, version=1.6.1.0
    Landscape.dll                                          .\Effects\Landscape.dll, version=5.2.8174.40347
    LensFlare.dll                                          .\Effects\LensFlare.dll, version=2.2.12.0
    Vandermotten.PaintDotNetEffects.Gradient.dll           C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, version=5.0.3.0
    LevelHorizon.dll                                       .\Effects\LevelHorizon.dll, version=6.0.8407.22459
    LightRays.dll                                          .\Effects\LightRays.dll, version=2.1.5.0
    Liquify.dll                                            .\Effects\Liquify.dll, version=4.0.5873.25113
    ListOfPalettes.dll                                     .\Effects\ListOfPalettes.dll, version=1.0.0.0
    Magnifier.dll                                          .\Effects\Magnifier.dll, version=1.3.5.0
    Majority.dll                                           .\Effects\Majority.dll, version=1.2.5.0
    MemeMaker.dll                                          .\Effects\MemeMaker.dll, version=6.0.8407.22476
    Melting.dll                                            .\Effects\Melting.dll, version=1.3.0.0
    LookAtIt.Effect.dll                                    .\Effects\LookAtIt.Effect.dll, version=0.6.0.779
    Metallize.dll                                          .\Effects\Metallize.dll, version=1.2.4415.32969
    Moire.dll                                              .\Effects\Moire.dll, version=1.2.5.0
    Vandermotten.PaintDotNetEffects.FadeEdge.dll           C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll, version=5.0.3.0
    Nebulous.dll                                           .\Effects\Nebulous.dll, version=1.2.5.0
    NewtonFractal.dll                                      .\Effects\NewtonFractal.dll, version=2.2.5.0
    Outline Object.dll                                     .\Effects\Outline Object.dll, version=4.0.4642.26954
    OilPaintingPlus.dll                                    .\Effects\OilPaintingPlus.dll, version=5.2.8141.27893
    OldFeather.dll                                         .\Effects\OldFeather.dll, version=2.3.4315.37038
    Oblique.dll                                            .\Effects\Oblique.dll, version=1.2.5.0
    Overliner.dll                                          .\Effects\Overliner.dll, version=1.2.5.0
    Vandermotten.PaintDotNetEffects.Duotones.dll           C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll, version=5.0.3.0
    PageCurl.dll                                           .\Effects\PageCurl.dll, version=1.5.5.0
    Paneling.dll                                           .\Effects\Paneling.dll, version=1.2.5.0
    PasteAlpha.dll                                         .\Effects\PasteAlpha.dll, version=5.2.8174.40450
    Pastel.dll                                             .\Effects\Pastel.dll, version=5.2.8174.40506
    ObjectTools.dll                                        .\Effects\ObjectTools.dll, version=6.0.8482.2565
    MotionSharpen.dll                                      .\Effects\MotionSharpen.dll, version=1.2.5.0
    PerlinTexture.dll                                      .\Effects\PerlinTexture.dll, version=2.2.5.0
    Perspective.dll                                        .\Effects\Perspective.dll, version=2.1.4415.36116
    PhotoAdjustments.dll                                   .\Effects\PhotoAdjustments.dll, version=6.0.8416.38377
    Pixelate+.dll                                          .\Effects\Pixelate+.dll, version=4.0.4642.26940
    Polar.dll                                              .\Effects\Polar.dll, version=1.2.5.0
    PlugInData.dll                                         .\Effects\PlugInData.dll, version=1.4.0.0
    Radialcolors.dll                                       .\Effects\Radialcolors.dll, version=1.2.5.0
    Polygones.dll                                          .\Effects\Polygones.dll, version=1.3.5.0
    Vandermotten.PaintDotNetEffects.DropShadow.dll         C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, version=5.0.3.0
    RainbowTwist.dll                                       .\Effects\RainbowTwist.dll, version=1.2.5.0
    Random Shape Fill.dll                                  .\Effects\Random Shape Fill.dll, version=4.0.4642.26910
    RandomMaze1.dll                                        .\Effects\RandomMaze1.dll, version=1.2.5.0
    Random Effect.dll                                      .\Effects\Random Effect.dll, version=4.0.4642.26928
    Vandermotten.PaintDotNetEffects.ColorAccent.dll        C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll, version=5.0.3.0
    RecolorGray.dll                                        .\Effects\RecolorGray.dll, version=1.2.5.0
    RandomMaze2.dll                                        .\Effects\RandomMaze2.dll, version=1.2.5.0
    RegularNoise.dll                                       .\Effects\RegularNoise.dll, version=1.2.5.0
    RemoveDust.dll                                         .\Effects\RemoveDust.dll, version=6.0.8407.22513
    ReverseColors.dll                                      .\Effects\ReverseColors.dll, version=1.2.5.0
    Rosaces.dll                                            .\Effects\Rosaces.dll, version=1.2.5.0
    RandomLines.dll                                        .\Effects\RandomLines.dll, version=1.2.5.0
    RotateText.dll                                         .\Effects\RotateText.dll, version=1.1.4415.32628
    Vandermotten.PaintDotNetEffects.Blurs.dll              C:\Users\daniy\Documents\Paint.NET App Files\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, version=5.0.3.0
    SeamCarving.dll                                        .\Effects\SeamCarving.dll, version=5.2.8176.39366
    ScriptLab.dll                                          .\Effects\ScriptLab.dll, version=4.0.6107.18914
    SeamlessTextureMaker.dll                               .\Effects\SeamlessTextureMaker.dll, version=1.2.5.0
    Shapes.dll                                             .\Effects\Shapes.dll, version=1.6.5.0
    SelectionTools.dll                                     .\Effects\SelectionTools.dll, version=6.0.8412.38725
    SharpenClassic.dll                                     .\Effects\SharpenClassic.dll, version=1.0.8420.39106
    Sharpen+.dll                                           .\Effects\Sharpen+.dll, version=4.0.0.0
    Signature.dll                                          .\Effects\Signature.dll, version=1.5.6617.21474
    SinWaves.dll                                           .\Effects\SinWaves.dll, version=1.2.5.0
    SmoothNoise.dll                                        .\Effects\SmoothNoise.dll, version=1.0.0.0
    Smudge.dll                                             .\Effects\Smudge.dll, version=4.0.5873.25097
    Sparkles.dll                                           .\Effects\Sparkles.dll, version=1.2.5.0
    Spiral.dll                                             .\Effects\Spiral.dll, version=1.2.5.0
    SpiroShapes.dll                                        .\Effects\SpiroShapes.dll, version=2.2.5.0
    Splashes.dll                                           .\Effects\Splashes.dll, version=1.2.5.0
    SpiroGraph.dll                                         .\Effects\SpiroGraph.dll, version=1.2.5.0
    Splatter.dll                                           .\Effects\Splatter.dll, version=4.0.5873.25083
    XYCoords.dll                                           .\Effects\XYCoords.dll, version=1.2.6.0
    SpotCenter.dll                                         .\Effects\SpotCenter.dll, version=1.2.0.0
    StarGlow.dll                                           .\Effects\StarGlow.dll, version=1.3.5.0
    Stars.dll                                              .\Effects\Stars.dll, version=2.0.0.0
    Stipple.dll                                            .\Effects\Stipple.dll, version=1.0.0.0
    WetFloor.dll                                           .\Effects\WetFloor.dll, version=1.2.5.0
    Stitch.dll                                             .\Effects\Stitch.dll, version=4.0.4642.26808
    Tiles.dll                                              .\Effects\Tiles.dll, version=1.2.5.0
    Textplus.dll                                           .\Effects\Textplus.dll, version=1.0.0.0
    TJacksonEffects.dll                                    .\Effects\TJacksonEffects.dll, version=1.0.0.0
    Tournesol.dll                                          .\Effects\Tournesol.dll, version=1.2.5.0
    WaveTextSUI.dll                                        .\Effects\WaveTextSUI.dll, version=1.2.4415.33440
    Trail.dll                                              .\Effects\Trail.dll, version=4.0.4642.26791
    Transparency.dll                                       .\Effects\Transparency.dll, version=6.0.8407.22532
    TRs Scatter.dll                                        .\Effects\TRs Scatter.dll, version=1.3.4949.23250
    TRsAlphaCutter.dll                                     .\Effects\TRsAlphaCutter.dll, version=3.0.4.0
    TRsFilmStock.dll                                       .\Effects\TRsFilmStock.dll, version=1.2.0.0
    TRsStr8Edge.dll                                        .\Effects\TRsStr8Edge.dll, version=1.1.5045.31905
    WaveText.dll                                           .\Effects\WaveText.dll, version=1.2.4415.32811
    TRsKeyFrame.dll                                        .\Effects\TRsKeyFrame.dll, version=1.2.5693.38036
    TubeOblique.dll                                        .\Effects\TubeOblique.dll, version=1.2.5.0
    Twist.dll                                              .\Effects\Twist.dll, version=4.0.5873.25056
    TwistZ.dll                                             .\Effects\TwistZ.dll, version=1.2.5.0
    Waves.dll                                              .\Effects\Waves.dll, version=1.2.5.0
    Vibrato.dll                                            .\Effects\Vibrato.dll, version=2.0.5.0
    VignettePlus.dll                                       .\Effects\VignettePlus.dll, version=6.0.8407.22549
    Volutes.dll                                            .\Effects\Volutes.dll, version=1.3.5.0
    WaterReflection.dll                                    .\Effects\WaterReflection.dll, version=1.2.5.0
    sspicli.dll                                            C:\WINDOWS\SYSTEM32\sspicli.dll, version=10.0.22621.3810 (WinBuild.160101.0800)
    schannel.DLL                                           C:\WINDOWS\system32\schannel.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Design.dll                                      .\System.Design.dll, version=9.0.24.52901
    System.Windows.Forms.Design.dll                        .\System.Windows.Forms.Design.dll, version=9.0.24.52901
    ncrypt.dll                                             C:\WINDOWS\SYSTEM32\ncrypt.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    NTASN1.dll                                             C:\WINDOWS\SYSTEM32\NTASN1.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    ncryptsslp.dll                                         C:\WINDOWS\system32\ncryptsslp.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
Posted
Can't see anything obviously wrong in your diagnostics.
On 11/17/2024 at 1:56 PM, Taliban2 said:
Here’s what happens: I’ll paste a graphic into paint.net, and then as soon as I take any further action (like resizing, applying an effect, or saving), the PC powers off completely. It’s not a crash or freeze – the whole system just shuts down.
When you say "the PC powers off completely" and "the whole system just shuts down", do you mean:
1. Windows goes through a normal shutdown?
or
2. Windows crashes and displays its Blue Screen error message?
or
3. The PC instantly powers off with no error indication at all?  i.e Paint.NET and everything else is running OK and then when you resize the image (for example), the screen instantly goes black and the PC is now dead?
Posted
or
or
The third! No indication whatsoever, no other major programs running, so don't think it's a memory issue.
