quibop Posted November 15 Posted November 15 basically after a while of having paint.net the screen glitches out a bit, and then a bit after that it glitches out a lot and makes my whole screen turn black (not just paint.net), i have to restart my computer with the power button whenever this happens and if i didn't save my work in the little amount of time in between the first glitch and black screen i have to lose it from the restart i tried fixing this by updating my nvidia drivers and not using the nvidia gpu in the rendering device thingy but neither of those worked, it still happens can't attach a crash log since the application doesn't technically crash from this Quote
quibop Posted November 15 Author Posted November 15 i should add if i close paint.net before the screen goes black it prevents that from happening but i'd still have to save my things quickly also it seems to only happen if i pan the camera after the first glitch so it might not actually require fast reaction time Quote
toe_head2001 Posted November 15 Posted November 15 Hi @quibop, Please post the diagnostic information found within paint.net. Settings -> Diagnostics -> Copy to clipboard. 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab
quibop Posted November 15 Author Posted November 15 boy i sure hope none of this information is sensitive! Spoiler Application Paint.NET 5.1 (Stable 5.100.9082.35298) Build Date Tuesday, November 12, 2024 Current Date and Time 11/14/2024 10:14:29 PM System uptime 05:59:28.1710000 Process uptime 01:48:21.4630000 Application state Running Install type Classic Install directory C:\Program Files\paint.net Application directory C:\Program Files\paint.net Current directory C:\Program Files\paint.net OS Windows 10 Home x64 (10.0.19045.0) Runtime .NET 9.0.0 x64 Physical Memory 16,085 MB (6,103 MB free) Paging File 25,813 MB (10,716 MB free) Working Set 448,640 KB Handles 2115 Threads 62 GDI objects 300 User objects 284 Language en-US UI Scaling 1.25x (120 DPI) Cursor Scaling 1.00x UI/Canvas GPU False Rendering GPU Intel UHD Graphics Advanced Color True Windows Ink True Animations True Translucent Windows True Remote Session False Battery Saver False Theme Aero (Aero.msstyles), Dark Updates Enabled Last Checked 11/14/2024 CPU 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz Speed ~2304 MHz Cores / Threads 8 / 16 Features SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2, AVX512BW, AVX512CD, AVX512DQ, AVX512F, AVX512_VBMI Display Generic PnP Monitor Connected to Intel(R) UHD Graphics Resolution 1920 x 1080, 8-bit, 144 Hz DPI 120 (1.25x scale) Coordinates (L=0, T=0, R=1920, B=1080) Advanced Color StandardDynamicRange SDR white level 80 nits Color space RgbFullGamma22NoneP709 Composition Support Fullscreen, Windowed Video Card Intel(R) UHD Graphics Hardware Acceleration Supported Performance Class Low Dedicated Video RAM 128 MB Dedicated System RAM 0 MB Shared System RAM 8,042 MB Driver Version 30.0.101.2079 Vendor ID 0x8086 Device ID 0x9A60 Subsystem ID 0x12EC1462 Revision 1 LUID 0x0000E047 Flags AcgCompatible, SupportMonitoredFences, KeyedMutexConformance Graphics Preemption PrimitiveBoundary Compute Preemption ThreadGroupBoundary Outputs 1 Feature Level Level_12_1 Features ComputeShadersEtc Maximum Bitmap Size 16384 Video Card NVIDIA GeForce RTX 3050 Laptop GPU Hardware Acceleration Supported Performance Class Good Dedicated Video RAM 3,964 MB Dedicated System RAM 0 MB Shared System RAM 8,042 MB Driver Version 32.0.15.6614 Vendor ID 0x10DE Device ID 0x25A5 Subsystem ID 0x12EC1462 Revision 161 LUID 0x0000E39B Flags AcgCompatible, SupportMonitoredFences, KeyedMutexConformance Graphics Preemption PixelBoundary Compute Preemption DispatchBoundary Outputs 0 Feature Level Level_12_1 Features Doubles, ComputeShadersEtc Maximum Bitmap Size 16384 Video Card Microsoft Basic Render Driver Hardware Acceleration N/A Performance Class VeryLow Dedicated Video RAM 0 MB Dedicated System RAM 0 MB Shared System RAM 8,042 MB Driver Version 10.0.19041.4355 Vendor ID 0x1414 Device ID 0x008C Subsystem ID 0x00000000 Revision 0 LUID 0x0000E31D Flags Software, AcgCompatible, SupportMonitoredFences, KeyedMutexConformance Graphics Preemption InstructionBoundary Compute Preemption InstructionBoundary Outputs 0 Feature Level Level_12_1 Features Doubles, ComputeShadersEtc Maximum Bitmap Size 8388608 Managed assemblies 180 System.Private.CoreLib .\System.Private.CoreLib.dll, Version=9.0.0.0, PublicKeyToken=7cec85d7bea7798e paintdotnet .\paintdotnet.dll, Version=5.100.9082.35298 System.Runtime .\System.Runtime.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Windows.Core .\PaintDotNet.Windows.Core.dll, Version=5.100.9082.35298 PaintDotNet.Windows .\PaintDotNet.Windows.dll, Version=5.100.9082.35298 PaintDotNet.ComponentModel .\PaintDotNet.ComponentModel.dll, Version=5.100.9082.35298 PaintDotNet.Primitives .\PaintDotNet.Primitives.dll, Version=5.100.9082.35298 PaintDotNet.Fundamentals .\PaintDotNet.Fundamentals.dll, Version=5.100.9082.35298 System.Windows.Forms .\System.Windows.Forms.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089 System.Diagnostics.Tracing .\System.Diagnostics.Tracing.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Thread .\System.Threading.Thread.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Base .\PaintDotNet.Base.dll, Version=5.100.9082.35298 PaintDotNet.Collections .\PaintDotNet.Collections.dll, Version=5.100.9082.35298 TerraFX.Interop.Windows .\TerraFX.Interop.Windows.dll, Version=10.0.26100.0, PublicKeyToken=35b01b53313a6f7e PaintDotNet.Runtime .\PaintDotNet.Runtime.dll, Version=5.100.9082.35298 System.Collections.Concurrent .\System.Collections.Concurrent.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PointerToolkit .\PointerToolkit.dll, Version=1.0.1.0 PaintDotNet.Systrace .\PaintDotNet.Systrace.dll, Version=5.100.9082.35298 System.Private.Uri .\System.Private.Uri.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.UI .\PaintDotNet.UI.dll, Version=5.100.9082.35298 PaintDotNet.Windows.Framework .\PaintDotNet.Windows.Framework.dll, Version=5.100.9082.35298 WindowsBase .\WindowsBase.dll, Version=9.0.0.0, PublicKeyToken=31bf3856ad364e35 Microsoft.Windows.SDK.NET .\Microsoft.Windows.SDK.NET.dll, Version=10.0.26100.38, PublicKeyToken=31bf3856ad364e35 PaintDotNet.ObjectModel .\PaintDotNet.ObjectModel.dll, Version=5.100.9082.35298 PresentationFramework .\PresentationFramework.dll, Version=9.0.0.0, PublicKeyToken=31bf3856ad364e35 WinRT.Runtime .\WinRT.Runtime.dll, Version=2.1.0.0, PublicKeyToken=99ea127f02d97709 System.Xaml .\System.Xaml.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089 System.Runtime.InteropServices .\System.Runtime.InteropServices.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel .\System.ComponentModel.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.Primitives .\System.ComponentModel.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections .\System.Collections.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading .\System.Threading.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ObjectModel .\System.ObjectModel.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.Primitives .\Microsoft.Win32.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Windows.Forms.Primitives .\System.Windows.Forms.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089 System.Private.Windows.Core .\System.Private.Windows.Core.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089 System.Drawing.Primitives .\System.Drawing.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Configuration.ConfigurationManager .\System.Configuration.ConfigurationManager.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Collections.Specialized .\System.Collections.Specialized.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Private.Xml .\System.Private.Xml.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Text.Encoding.CodePages .\System.Text.Encoding.CodePages.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Core .\PaintDotNet.Core.dll, Version=5.100.9082.35298 System.Xml.ReaderWriter .\System.Xml.ReaderWriter.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.SystemLayer .\PaintDotNet.SystemLayer.dll, Version=5.100.9082.35298 System.Net.WebClient .\System.Net.WebClient.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 PaintDotNet.Resources .\PaintDotNet.Resources.dll, Version=5.100.9082.35298 System.Memory .\System.Memory.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Drawing.Common .\System.Drawing.Common.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Text.Encoding.Extensions .\System.Text.Encoding.Extensions.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Linq .\System.Linq.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Data .\PaintDotNet.Data.dll, Version=5.100.9082.35298 PaintDotNet.Framework .\PaintDotNet.Framework.dll, Version=5.100.9082.35298 System.Threading.ThreadPool .\System.Threading.ThreadPool.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a CommunityToolkit.HighPerformance .\CommunityToolkit.HighPerformance.dll, Version=8.3.0.0, PublicKeyToken=4aff67a105548ee2 Microsoft.Win32.Registry .\Microsoft.Win32.Registry.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a ComputeSharp.D2D1 .\ComputeSharp.D2D1.dll, Version=3.0.1.0, PublicKeyToken=dc35fa229f6881d8 System.Collections.Immutable .\System.Collections.Immutable.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PointerToolkit.TerraFX.Interop.Windows .\PointerToolkit.TerraFX.Interop.Windows.dll, Version=10.0.26100.0 Microsoft.Win32.SystemEvents .\Microsoft.Win32.SystemEvents.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Numerics.Vectors .\System.Numerics.Vectors.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.TypeConverter .\System.ComponentModel.TypeConverter.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.EventBasedAsync .\System.ComponentModel.EventBasedAsync.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PresentationCore .\PresentationCore.dll, Version=9.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Security.Principal.Windows .\System.Security.Principal.Windows.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a DirectWriteForwarder .\DirectWriteForwarder.dll, Version=9.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Security.Claims .\System.Security.Claims.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Extensions .\System.Runtime.Extensions.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.Debug .\System.Diagnostics.Debug.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.CompilerServices.VisualC .\System.Runtime.CompilerServices.VisualC.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.NonGeneric .\System.Collections.NonGeneric.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.TraceSource .\System.Diagnostics.TraceSource.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.PropertySystem .\PaintDotNet.PropertySystem.dll, Version=5.100.9082.35298 System.IO.Packaging .\System.IO.Packaging.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Effects.Core .\PaintDotNet.Effects.Core.dll, Version=5.100.9082.35298 Accessibility .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35 System.IO.Hashing .\System.IO.Hashing.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 SauceControl.Blake2Fast .\SauceControl.Blake2Fast.dll, Version=2.0.0.0, PublicKeyToken=deebe556222e40dc PaintDotNet.Effects.Gpu .\PaintDotNet.Effects.Gpu.dll, Version=5.100.9082.35298 System.Threading.Tasks.Parallel .\System.Threading.Tasks.Parallel.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.FileVersionInfo .\System.Diagnostics.FileVersionInfo.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Loader .\System.Runtime.Loader.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a DdsFileTypePlus .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.12.11.0 WebPFileType .\Bundled\WebPFileType\WebPFileType.dll, Version=1.4.0.0 AvifFileType .\Bundled\AvifFileType\AvifFileType.dll, Version=3.10.0.0 PaintDotNet.Effects .\PaintDotNet.Effects.dll, Version=5.100.9082.35298 System.Reflection.Metadata .\System.Reflection.Metadata.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.IO.MemoryMappedFiles .\System.IO.MemoryMappedFiles.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Mono.Cecil .\Mono.Cecil.dll, Version=0.11.6.0, PublicKeyToken=50cebf1cceb9d05e netstandard .\netstandard.dll, Version=2.1.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Reflection.MetadataLoadContext .\System.Reflection.MetadataLoadContext.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 PaintDotNet.Effects.Legacy .\PaintDotNet.Effects.Legacy.dll, Version=5.100.9082.35298 PaintDotNet.Plugins.Compatibility .\PaintDotNet.Plugins.Compatibility.dll, Version=5.100.9082.35298 System.Diagnostics.Process .\System.Diagnostics.Process.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Console .\System.Console.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a ComplementaryColors .\Effects\ComplementaryColors.dll, Version=6.0.8407.23961 BBChart .\Effects\BBChart.dll, Version=1.1.0.0 BBOutlinedGradientText .\Effects\BBOutlinedGradientText.dll, Version=6.0.8407.21976 BandWPlus .\Effects\BandWPlus.dll, Version=6.0.8407.21940 Calendar .\Effects\Calendar.dll, Version=6.0.8407.22090 CombinedAdjustments .\Effects\CombinedAdjustments.dll, Version=6.0.8407.22130 Alpha2Gray .\Effects\Alpha2Gray.dll, Version=6.0.8407.21872 ApplyMask .\Effects\ApplyMask.dll, Version=6.0.8407.21905 ColorBalance .\Effects\ColorBalance.dll, Version=6.0.8407.22111 Burninate .\Effects\Burninate.dll, Version=6.0.8407.22069 System.Windows.Forms.DataVisualization .\Effects\System.Windows.Forms.DataVisualization.dll, Version=1.0.0.0, PublicKeyToken=31bf3856ad364e35 CreativeTextPro .\Effects\CreativeTextPro.dll, Version=6.0.8407.22165 System.Resources.Extensions .\System.Resources.Extensions.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 Dream .\Effects\Dream.dll, Version=6.0.8407.22379 FillFromClipboard .\Effects\FillFromClipboard.dll, Version=6.0.8407.22397 Dimensions .\Effects\Dimensions.dll, Version=1.3.6826.38472 FillFromFile .\Effects\FillFromFile.dll, Version=6.0.8407.22418 mscorlib .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 EOEffects .\Effects\EOEffects.dll, Version=1.10.16.12 System.Drawing .\System.Drawing.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System .\System.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 Twist C:\Users\wainp\Documents\Paint.NET App Files\Effects\Twist.dll, Version=4.0.5873.25056 Flip .\Effects\Flip.dll, Version=4.6.7358.36953 FloydSteinbergDithering .\Effects\FloydSteinbergDithering.dll, Version=5.2.8174.39918 GaussianBlurPlus .\Effects\GaussianBlurPlus.dll, Version=4.2.5691.27401 Gray2Alpha .\Effects\Gray2Alpha.dll, Version=6.0.8407.22439 GridCheckerboard .\Effects\GridCheckerboard.dll, Version=5.2.8141.24786 Gradient Mapping C:\Users\wainp\Documents\Paint.NET App Files\Effects\Gradient Mapping.dll, Version=4.0.6547.33963 HueSatPlus .\Effects\HueSatPlus.dll, Version=5.2.8174.40274 PhotoSauce.MagicScaler .\PhotoSauce.MagicScaler.dll, Version=0.15.0.0, PublicKeyToken=fc6b9b7b06809481 MemeMaker .\Effects\MemeMaker.dll, Version=6.0.8407.22476 Feather .\Effects\OldFeather.dll, Version=2.3.4315.37038 LevelHorizon .\Effects\LevelHorizon.dll, Version=6.0.8407.22459 ObjectTools .\Effects\ObjectTools.dll, Version=6.0.8407.28625 PasteAlpha .\Effects\PasteAlpha.dll, Version=5.2.8174.40450 Landscape .\Effects\Landscape.dll, Version=5.2.8174.40347 PhotoAdjustments .\Effects\PhotoAdjustments.dll, Version=6.0.8407.22495 Pastel .\Effects\Pastel.dll, Version=5.2.8174.40506 OilPaintingPlus .\Effects\OilPaintingPlus.dll, Version=5.2.8141.27893 System.Runtime.Serialization.Formatters .\System.Runtime.Serialization.Formatters.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Trail C:\Users\wainp\Documents\Paint.NET App Files\Effects\Trail.dll, Version=4.0.4642.26791 RemoveDust .\Effects\RemoveDust.dll, Version=6.0.8407.22513 SelectionTools .\Effects\SelectionTools.dll, Version=6.0.8407.22045 SeamCarving .\Effects\SeamCarving.dll, Version=5.2.8176.39366 Transparency .\Effects\Transparency.dll, Version=6.0.8407.22532 Stitch C:\Users\wainp\Documents\Paint.NET App Files\Effects\Stitch.dll, Version=4.0.4642.26808 TubeOblique .\Effects\TubeOblique.dll, Version=1.2.5.15697 VignettePlus .\Effects\VignettePlus.dll, Version=6.0.8407.22549 Borders N' Shapes C:\Users\wainp\Documents\Paint.NET App Files\Effects\Borders N' Shapes.dll, Version=4.0.4642.26476 Color Match C:\Users\wainp\Documents\Paint.NET App Files\Effects\Color Match.dll, Version=4.2.7630.21216 Splatter C:\Users\wainp\Documents\Paint.NET App Files\Effects\Splatter.dll, Version=4.0.5873.25083 Film C:\Users\wainp\Documents\Paint.NET App Files\Effects\Film.dll, Version=4.0.4642.26607 Gradient Bars C:\Users\wainp\Documents\Paint.NET App Files\Effects\Gradient Bars.dll, Version=4.0.5152.23084 Gradient Blocks C:\Users\wainp\Documents\Paint.NET App Files\Effects\Gradient Blocks.dll, Version=4.0.4642.26658 Curves+ C:\Users\wainp\Documents\Paint.NET App Files\Effects\Curves+.dll, Version=4.0.6119.31044 Gradient Grid C:\Users\wainp\Documents\Paint.NET App Files\Effects\Gradient Grid.dll, Version=4.0.6436.36068 Jitter C:\Users\wainp\Documents\Paint.NET App Files\Effects\Jitter.dll, Version=4.0.4642.26986 Liquify C:\Users\wainp\Documents\Paint.NET App Files\Effects\Liquify.dll, Version=4.0.5873.25113 Pixelate+ C:\Users\wainp\Documents\Paint.NET App Files\Effects\Pixelate+.dll, Version=4.0.4642.26940 Outline Object C:\Users\wainp\Documents\Paint.NET App Files\Effects\Outline Object.dll, Version=4.0.4642.26954 System.Core .\System.Core.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 Random Effect C:\Users\wainp\Documents\Paint.NET App Files\Effects\Random Effect.dll, Version=4.0.4642.26928 Random Shape Fill C:\Users\wainp\Documents\Paint.NET App Files\Effects\Random Shape Fill.dll, Version=4.0.4642.26910 Grid Warp C:\Users\wainp\Documents\Paint.NET App Files\Effects\Grid Warp.dll, Version=4.0.6544.34496 Smudge C:\Users\wainp\Documents\Paint.NET App Files\Effects\Smudge.dll, Version=4.0.5873.25097 System.Runtime.Intrinsics .\System.Runtime.Intrinsics.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Net.Http .\System.Net.Http.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Net.Primitives .\System.Net.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.DiagnosticSource .\System.Diagnostics.DiagnosticSource.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Net.Security .\System.Net.Security.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Security.Cryptography .\System.Security.Cryptography.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a ComputeSharp.Core .\ComputeSharp.Core.dll, Version=3.0.1.0, PublicKeyToken=dc35fa229f6881d8 Polygon .\Effects\Polygon.dll, Version=4.5.6828.38648 System.IO.Compression .\System.IO.Compression.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089 PremultiplyAlpha .\Effects\PremultiplyAlpha.dll, Version=1.0.6868.37601 HSVGradients .\Effects\HSVGradients.dll, Version=4.5.6832.41864 Newtonsoft.Json .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed System.Linq.Expressions .\System.Linq.Expressions.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.RegularExpressions .\System.Text.RegularExpressions.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Numerics .\System.Runtime.Numerics.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.CodeDom .\System.CodeDom.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Private.Xml.Linq .\System.Private.Xml.Linq.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Xml.XDocument .\System.Xml.XDocument.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a K4os.Compression.LZ4 .\K4os.Compression.LZ4.dll, Version=1.3.8.0, PublicKeyToken=2186fa9121ef231d PresentationFramework-SystemXmlLinq .\PresentationFramework-SystemXmlLinq.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089 System.Xml.Linq .\System.Xml.Linq.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 Native modules 335 paintdotnet.exe .\paintdotnet.exe, version=5.100.9082.35298 ntdll.dll C:\Windows\SYSTEM32\ntdll.dll, version=10.0.19041.4842 (WinBuild.160101.0800) KERNEL32.DLL C:\Windows\System32\KERNEL32.DLL, version=10.0.19041.5072 (WinBuild.160101.0800) KERNELBASE.dll C:\Windows\System32\KERNELBASE.dll, version=10.0.19041.5072 (WinBuild.160101.0800) SHELL32.dll C:\Windows\System32\SHELL32.dll, version=10.0.19041.4957 (WinBuild.160101.0800) msvcp_win.dll C:\Windows\System32\msvcp_win.dll, version=10.0.19041.3636 (WinBuild.160101.0800) ucrtbase.dll C:\Windows\System32\ucrtbase.dll, version=10.0.19041.3636 (WinBuild.160101.0800) USER32.dll C:\Windows\System32\USER32.dll, version=10.0.19041.1 (WinBuild.160101.0800) win32u.dll C:\Windows\System32\win32u.dll, version=10.0.19041.5129 (WinBuild.160101.0800) GDI32.dll C:\Windows\System32\GDI32.dll, version=10.0.19041.4474 (WinBuild.160101.0800) gdi32full.dll C:\Windows\System32\gdi32full.dll, version=10.0.19041.4957 (WinBuild.160101.0800) ole32.dll C:\Windows\System32\ole32.dll, version=10.0.19041.3636 (WinBuild.160101.0800) RPCRT4.dll C:\Windows\System32\RPCRT4.dll, version=10.0.19041.3636 (WinBuild.160101.0800) combase.dll C:\Windows\System32\combase.dll, version=10.0.19041.3636 (WinBuild.160101.0800) OLEAUT32.dll C:\Windows\System32\OLEAUT32.dll, version=10.0.19041.3636 (WinBuild.160101.0800) SHLWAPI.dll C:\Windows\System32\SHLWAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800) msvcrt.dll C:\Windows\System32\msvcrt.dll, version=7.0.19041.3636 (WinBuild.160101.0800) VCRUNTIME140.dll .\VCRUNTIME140.dll, version=14.42.34433.0 VCRUNTIME140_1.dll .\VCRUNTIME140_1.dll, version=14.42.34433.0 IMM32.DLL C:\Windows\System32\IMM32.DLL, version=10.0.19041.4474 (WinBuild.160101.0800) shcore.dll C:\Windows\System32\shcore.dll, version=10.0.19041.1 (WinBuild.160101.0800) hostfxr.dll .\hostfxr.dll, version=9,0,24,52809 @Commit: 9d5a6a9aa463d6d10b0b0ba6d5982cc82f363dc3 ADVAPI32.dll C:\Windows\System32\ADVAPI32.dll, version=10.0.19041.1 (WinBuild.160101.0800) sechost.dll C:\Windows\System32\sechost.dll, version=10.0.19041.1 (WinBuild.160101.0800) bcrypt.dll C:\Windows\System32\bcrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) hostpolicy.dll .\hostpolicy.dll, version=9,0,24,52809 @Commit: 9d5a6a9aa463d6d10b0b0ba6d5982cc82f363dc3 coreclr.dll .\coreclr.dll, version=9,0,24,52809 @Commit: 9d5a6a9aa463d6d10b0b0ba6d5982cc82f363dc3 bcryptPrimitives.dll C:\Windows\System32\bcryptPrimitives.dll, version=10.0.19041.5007 (WinBuild.160101.0800) System.Private.CoreLib.dll .\System.Private.CoreLib.dll, version=9.0.24.52809 kernel.appcore.dll C:\Windows\SYSTEM32\kernel.appcore.dll, version=10.0.19041.3758 (WinBuild.160101.0800) paintdotnet.dll .\paintdotnet.dll, version=5.100.9082.35298 System.Runtime.dll .\System.Runtime.dll, version=9.0.24.52809 uxtheme.dll C:\Windows\system32\uxtheme.dll, version=10.0.19041.4529 (WinBuild.160101.0800) AudioDevProps2.dll C:\ProgramData\A-Volute\A-Volute.Nahimic\Modules\Scheduled\x64\AudioDevProps2.dll, version=2.6.28.0 WS2_32.dll C:\Windows\System32\WS2_32.dll, version=10.0.19041.3636 (WinBuild.160101.0800) PaintDotNet.Windows.Core.dll .\PaintDotNet.Windows.Core.dll, version=5.100.9082.35298 PaintDotNet.Windows.dll .\PaintDotNet.Windows.dll, version=5.100.9082.35298 PaintDotNet.ComponentModel.dll .\PaintDotNet.ComponentModel.dll, version=5.100.9082.35298 PaintDotNet.Primitives.dll .\PaintDotNet.Primitives.dll, version=5.100.9082.35298 PaintDotNet.Fundamentals.dll .\PaintDotNet.Fundamentals.dll, version=5.100.9082.35298 System.Windows.Forms.dll .\System.Windows.Forms.dll, version=9.0.24.52901 System.Diagnostics.Tracing.dll .\System.Diagnostics.Tracing.dll, version=9.0.24.52809 clrjit.dll .\clrjit.dll, version=9,0,24,52809 @Commit: 9d5a6a9aa463d6d10b0b0ba6d5982cc82f363dc3 icu.dll C:\Windows\SYSTEM32\icu.dll, version=64, 2, 0, 0 (WinBuild.160101.0800) System.Threading.Thread.dll .\System.Threading.Thread.dll, version=9.0.24.52809 PaintDotNet.Base.dll .\PaintDotNet.Base.dll, version=5.100.9082.35298 PaintDotNet.Collections.dll .\PaintDotNet.Collections.dll, version=5.100.9082.35298 TerraFX.Interop.Windows.dll .\TerraFX.Interop.Windows.dll, version=10.0.26100.0 dxgi.DLL C:\Windows\SYSTEM32\dxgi.DLL, version=10.0.19041.5072 (WinBuild.160101.0800) PaintDotNet.Runtime.dll .\PaintDotNet.Runtime.dll, version=5.100.9082.35298 System.Collections.Concurrent.dll .\System.Collections.Concurrent.dll, version=9.0.24.52809 PointerToolkit.dll .\PointerToolkit.dll, version=1.0.1.0 PaintDotNet.Systrace.dll .\PaintDotNet.Systrace.dll, version=5.100.9082.35298 windows.storage.dll C:\Windows\SYSTEM32\windows.storage.dll, version=10.0.19041.1 (WinBuild.160101.0800) Wldp.dll C:\Windows\SYSTEM32\Wldp.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Private.Uri.dll .\System.Private.Uri.dll, version=9.0.24.52809 PaintDotNet.UI.dll .\PaintDotNet.UI.dll, version=5.100.9082.35298 PaintDotNet.Windows.Framework.dll .\PaintDotNet.Windows.Framework.dll, version=5.100.9082.35298 WindowsBase.dll .\WindowsBase.dll, version=9.0.24.52902 Microsoft.Windows.SDK.NET.dll .\Microsoft.Windows.SDK.NET.dll, version=10.0.26100.52 PaintDotNet.ObjectModel.dll .\PaintDotNet.ObjectModel.dll, version=5.100.9082.35298 PresentationFramework.dll .\PresentationFramework.dll, version=9.0.24.52902 WinRT.Runtime.dll .\WinRT.Runtime.dll, version=2.1.6.47881 System.Xaml.dll .\System.Xaml.dll, version=9.0.24.52902 System.Runtime.InteropServices.dll .\System.Runtime.InteropServices.dll, version=9.0.24.52809 System.ComponentModel.dll .\System.ComponentModel.dll, version=9.0.24.52809 System.ComponentModel.Primitives.dll .\System.ComponentModel.Primitives.dll, version=9.0.24.52809 coremessaging.DLL C:\Windows\SYSTEM32\coremessaging.DLL, version=10.0.19041.4355 System.Collections.dll .\System.Collections.dll, version=9.0.24.52809 System.Threading.dll .\System.Threading.dll, version=9.0.24.52809 System.ObjectModel.dll .\System.ObjectModel.dll, version=9.0.24.52809 Microsoft.Win32.Primitives.dll .\Microsoft.Win32.Primitives.dll, version=9.0.24.52809 System.Windows.Forms.Primitives.dll .\System.Windows.Forms.Primitives.dll, version=9.0.24.52901 System.Private.Windows.Core.dll .\System.Private.Windows.Core.dll, version=9.0.24.52901 System.Drawing.Primitives.dll .\System.Drawing.Primitives.dll, version=9.0.24.52809 System.Configuration.ConfigurationManager.dll .\System.Configuration.ConfigurationManager.dll, version=9.0.24.52809 System.Collections.Specialized.dll .\System.Collections.Specialized.dll, version=9.0.24.52809 System.Private.Xml.dll .\System.Private.Xml.dll, version=9.0.24.52809 System.Text.Encoding.CodePages.dll .\System.Text.Encoding.CodePages.dll, version=9.0.24.52809 PaintDotNet.Core.dll .\PaintDotNet.Core.dll, version=5.100.9082.35298 PresentationNative_cor3.dll .\PresentationNative_cor3.dll, version=9,0,24,47404 @Commit: c7dea8ec4c32ed09d3cedbdd1f967a276b3f75c0 System.Xml.ReaderWriter.dll .\System.Xml.ReaderWriter.dll, version=9.0.24.52809 PaintDotNet.SystemLayer.dll .\PaintDotNet.SystemLayer.dll, version=5.100.9082.35298 System.Net.WebClient.dll .\System.Net.WebClient.dll, version=9.0.24.52809 PaintDotNet.Resources.dll .\PaintDotNet.Resources.dll, version=5.100.9082.35298 System.Memory.dll .\System.Memory.dll, version=9.0.24.52809 System.Drawing.Common.dll .\System.Drawing.Common.dll, version=9.0.24.52901 System.Text.Encoding.Extensions.dll .\System.Text.Encoding.Extensions.dll, version=9.0.24.52809 System.Linq.dll .\System.Linq.dll, version=9.0.24.52809 PaintDotNet.Data.dll .\PaintDotNet.Data.dll, version=5.100.9082.35298 PaintDotNet.Framework.dll .\PaintDotNet.Framework.dll, version=5.100.9082.35298 CommunityToolkit.HighPerformance.dll .\CommunityToolkit.HighPerformance.dll, version=8.3.2.1 System.Threading.ThreadPool.dll .\System.Threading.ThreadPool.dll, version=9.0.24.52809 Microsoft.Win32.Registry.dll .\Microsoft.Win32.Registry.dll, version=9.0.24.52809 ComputeSharp.D2D1.dll .\ComputeSharp.D2D1.dll, version=3.0.1.0 System.Collections.Immutable.dll .\System.Collections.Immutable.dll, version=9.0.24.52809 PointerToolkit.TerraFX.Interop.Windows.dll .\PointerToolkit.TerraFX.Interop.Windows.dll, version=10.0.26100.0 profapi.dll C:\Windows\SYSTEM32\profapi.dll, version=10.0.19041.4355 (WinBuild.160101.0800) Microsoft.Win32.SystemEvents.dll .\Microsoft.Win32.SystemEvents.dll, version=9.0.24.52809 System.Numerics.Vectors.dll .\System.Numerics.Vectors.dll, version=9.0.24.52809 System.ComponentModel.TypeConverter.dll .\System.ComponentModel.TypeConverter.dll, version=9.0.24.52809 MSCTF.dll C:\Windows\System32\MSCTF.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.ComponentModel.EventBasedAsync.dll .\System.ComponentModel.EventBasedAsync.dll, version=9.0.24.52809 PresentationCore.dll .\PresentationCore.dll, version=9.0.24.52902 dwrite.dll C:\Windows\SYSTEM32\dwrite.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Security.Principal.Windows.dll .\System.Security.Principal.Windows.dll, version=9.0.24.52809 DirectWriteForwarder.dll .\DirectWriteForwarder.dll, version=9,0,24,52902 @Commit: a04736acb8edb533756131d3d5fc55f15cd03d6a System.Security.Claims.dll .\System.Security.Claims.dll, version=9.0.24.52809 d3d11.DLL C:\Windows\SYSTEM32\d3d11.DLL, version=10.0.19041.4355 (WinBuild.160101.0800) System.Runtime.Extensions.dll .\System.Runtime.Extensions.dll, version=9.0.24.52809 igd10iumd64.dll C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_357acc06f2c40efb\igd10iumd64.dll, version=30.0.101.2079 apphelp.dll C:\Windows\SYSTEM32\apphelp.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Diagnostics.Debug.dll .\System.Diagnostics.Debug.dll, version=9.0.24.52809 igd10um64xe.DLL C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_357acc06f2c40efb\igd10um64xe.DLL, version=30.0.101.2079 CRYPT32.dll C:\Windows\System32\CRYPT32.dll, version=10.0.19041.1 (WinBuild.160101.0800) ncrypt.dll C:\Windows\SYSTEM32\ncrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) NTASN1.dll C:\Windows\SYSTEM32\NTASN1.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Runtime.CompilerServices.VisualC.dll .\System.Runtime.CompilerServices.VisualC.dll, version=9.0.24.52809 ControlLib.dll C:\Windows\SYSTEM32\ControlLib.dll, version=1.0.90 SETUPAPI.dll C:\Windows\System32\SETUPAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800) cfgmgr32.dll C:\Windows\System32\cfgmgr32.dll, version=10.0.19041.3996 (WinBuild.160101.0800) DEVOBJ.dll C:\Windows\SYSTEM32\DEVOBJ.dll, version=10.0.19041.4355 (WinBuild.160101.0800) IntelControlLib.dll C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_357acc06f2c40efb\IntelControlLib.dll, version=1.0.90 System.Collections.NonGeneric.dll .\System.Collections.NonGeneric.dll, version=9.0.24.52809 WINTRUST.dll C:\Windows\System32\WINTRUST.dll, version=10.0.19041.4957 (WinBuild.160101.0800) MSASN1.dll C:\Windows\SYSTEM32\MSASN1.dll, version=10.0.19041.3636 (WinBuild.160101.0800) System.Diagnostics.TraceSource.dll .\System.Diagnostics.TraceSource.dll, version=9.0.24.52809 igdgmm64.dll C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_357acc06f2c40efb\igdgmm64.dll, version=30.0.101.2079 igc64.dll C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_357acc06f2c40efb\igc64.dll, version=30.0.101.2079 d2d1.DLL C:\Windows\SYSTEM32\d2d1.DLL, version=10.0.19041.1 (WinBuild.160101.0800) PaintDotNet.PropertySystem.dll .\PaintDotNet.PropertySystem.dll, version=5.100.9082.35298 gdiplus.dll C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.4597_none_91a78020cc854124\gdiplus.dll, version=10.0.19041.4597 (WinBuild.160101.0800) dxcore.dll C:\Windows\SYSTEM32\dxcore.dll, version=10.0.19041.4474 (WinBuild.160101.0800) System.IO.Packaging.dll .\System.IO.Packaging.dll, version=9.0.24.52809 WindowsCodecs.dll C:\Windows\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.5129 (WinBuild.160101.0800) clbcatq.dll C:\Windows\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800) XmlLite.dll C:\Windows\SYSTEM32\XmlLite.dll, version=10.0.19041.3636 (WinBuild.160101.0800) UIAnimation.dll C:\Windows\System32\UIAnimation.dll, version=10.0.19041.3636 (WinBuild.160101.0800) PaintDotNet.Effects.Core.dll .\PaintDotNet.Effects.Core.dll, version=5.100.9082.35298 wtsapi32.dll C:\Windows\SYSTEM32\wtsapi32.dll, version=10.0.19041.3636 (WinBuild.160101.0800) WINSTA.dll C:\Windows\SYSTEM32\WINSTA.dll, version=10.0.19041.3636 (WinBuild.160101.0800) comctl32.dll C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.4355_none_60b8b9eb71f62e16\comctl32.dll, version=6.10 (WinBuild.160101.0800) Accessibility.dll .\Accessibility.dll, version=9.0.24.52901 System.IO.Hashing.dll .\System.IO.Hashing.dll, version=9.0.24.52809 SauceControl.Blake2Fast.dll .\SauceControl.Blake2Fast.dll, version=2.0.0.0 PaintDotNet.Effects.Gpu.dll .\PaintDotNet.Effects.Gpu.dll, version=5.100.9082.35298 TextShaping.dll C:\Windows\SYSTEM32\TextShaping.dll, version= System.Threading.Tasks.Parallel.dll .\System.Threading.Tasks.Parallel.dll, version=9.0.24.52809 System.Diagnostics.FileVersionInfo.dll .\System.Diagnostics.FileVersionInfo.dll, version=9.0.24.52809 System.Runtime.Loader.dll .\System.Runtime.Loader.dll, version=9.0.24.52809 mfplat.dll C:\Windows\SYSTEM32\mfplat.dll, version=10.0.19041.1 (WinBuild.160101.0800) RTWorkQ.DLL C:\Windows\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.4355 (WinBuild.160101.0800) version.dll C:\Windows\SYSTEM32\version.dll, version=10.0.19041.3636 (WinBuild.160101.0800) CompPkgSup.DLL C:\Windows\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.4355 (WinBuild.160101.0800) DdsFileTypePlus.dll .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.12.11.0 WebPFileType.dll .\Bundled\WebPFileType\WebPFileType.dll, version=1.4.0.0 AvifFileType.dll .\Bundled\AvifFileType\AvifFileType.dll, version=3.10.0.0 WinTypes.dll C:\Windows\System32\WinTypes.dll, version=10.0.19041.3636 (WinBuild.160101.0800) PaintDotNet.Effects.dll .\PaintDotNet.Effects.dll, version=5.100.9082.35298 System.Reflection.Metadata.dll .\System.Reflection.Metadata.dll, version=9.0.24.52809 System.IO.MemoryMappedFiles.dll .\System.IO.MemoryMappedFiles.dll, version=9.0.24.52809 Mono.Cecil.dll .\Mono.Cecil.dll, version=0.11.6.0 netstandard.dll .\netstandard.dll, version=9.0.24.52809 System.Reflection.MetadataLoadContext.dll .\System.Reflection.MetadataLoadContext.dll, version=9.0.24.52809 PaintDotNet.Effects.Legacy.dll .\PaintDotNet.Effects.Legacy.dll, version=5.100.9082.35298 D3D10Warp.dll C:\Windows\SYSTEM32\D3D10Warp.dll, version=10.0.19041.4355 (WinBuild.160101.0800) PaintDotNet.Plugins.Compatibility.dll .\PaintDotNet.Plugins.Compatibility.dll, version=5.100.9082.35298 System.Diagnostics.Process.dll .\System.Diagnostics.Process.dll, version=9.0.24.52809 System.Console.dll .\System.Console.dll, version=9.0.24.52809 ComplementaryColors.dll .\Effects\ComplementaryColors.dll, version=6.0.8407.23961 BBChart.dll .\Effects\BBChart.dll, version=1.1.0.0 amsi.dll C:\Windows\SYSTEM32\amsi.dll, version=10.0.19041.4355 (WinBuild.160101.0800) BBOutlinedGradientText.dll .\Effects\BBOutlinedGradientText.dll, version=6.0.8407.21976 BandWPlus.dll .\Effects\BandWPlus.dll, version=6.0.8407.21940 Calendar.dll .\Effects\Calendar.dll, version=6.0.8407.22090 CombinedAdjustments.dll .\Effects\CombinedAdjustments.dll, version=6.0.8407.22130 Alpha2Gray.dll .\Effects\Alpha2Gray.dll, version=6.0.8407.21872 ApplyMask.dll .\Effects\ApplyMask.dll, version=6.0.8407.21905 ColorBalance.dll .\Effects\ColorBalance.dll, version=6.0.8407.22111 Burninate.dll .\Effects\Burninate.dll, version=6.0.8407.22069 USERENV.dll C:\Windows\SYSTEM32\USERENV.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Windows.Forms.DataVisualization.dll .\Effects\System.Windows.Forms.DataVisualization.dll, version=1.0.20.11001 MpOav.dll C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24090.11-0\MpOav.dll, version=4.18.24090.11 (26d75470953920f90fd0438874501e9d9a31e621) MPCLIENT.DLL C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.24090.11-0\MPCLIENT.DLL, version=4.18.24090.11 (26d75470953920f90fd0438874501e9d9a31e621) CreativeTextPro.dll .\Effects\CreativeTextPro.dll, version=6.0.8407.22165 System.Resources.Extensions.dll .\System.Resources.Extensions.dll, version=9.0.24.52809 Dream.dll .\Effects\Dream.dll, version=6.0.8407.22379 FillFromClipboard.dll .\Effects\FillFromClipboard.dll, version=6.0.8407.22397 Dimensions.dll .\Effects\Dimensions.dll, version=1.3.6826.38472 FillFromFile.dll .\Effects\FillFromFile.dll, version=6.0.8407.22418 mscorlib.dll .\mscorlib.dll, version=9.0.24.52809 EOEffects.dll .\Effects\EOEffects.dll, version=1.10.16.12 System.Drawing.dll .\System.Drawing.dll, version=9.0.24.52901 System.dll .\System.dll, version=9.0.24.52809 Twist.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Twist.dll, version=4.0.5873.25056 Flip.dll .\Effects\Flip.dll, version=4.6.7358.36953 FloydSteinbergDithering.dll .\Effects\FloydSteinbergDithering.dll, version=5.2.8174.39918 GaussianBlurPlus.dll .\Effects\GaussianBlurPlus.dll, version=4.2.5691.27401 Gray2Alpha.dll .\Effects\Gray2Alpha.dll, version=6.0.8407.22439 gpapi.dll C:\Windows\SYSTEM32\gpapi.dll, version=10.0.19041.1 (WinBuild.160101.0800) GridCheckerboard.dll .\Effects\GridCheckerboard.dll, version=5.2.8141.24786 HueSatPlus.dll .\Effects\HueSatPlus.dll, version=5.2.8174.40274 mscms.DLL C:\Windows\SYSTEM32\mscms.DLL, version=10.0.19041.1 (WinBuild.160101.0800) ColorAdapterClient.dll C:\Windows\SYSTEM32\ColorAdapterClient.dll, version=10.0.19041.5129 (WinBuild.160101.0800) icm32.dll C:\Windows\SYSTEM32\icm32.dll, version=10.0.19041.5129 (WinBuild.160101.0800) PhotoSauce.MagicScaler.dll .\PhotoSauce.MagicScaler.dll, version=0.15.0.0 windowscodecsext.dll C:\Windows\system32\windowscodecsext.dll, version=10.0.19041.3636 (WinBuild.160101.0800) Cabinet.dll C:\Windows\SYSTEM32\Cabinet.dll, version=5.00 (WinBuild.160101.0800) MemeMaker.dll .\Effects\MemeMaker.dll, version=6.0.8407.22476 OldFeather.dll .\Effects\OldFeather.dll, version=2.3.4315.37038 LevelHorizon.dll .\Effects\LevelHorizon.dll, version=6.0.8407.22459 ObjectTools.dll .\Effects\ObjectTools.dll, version=6.0.8407.28625 PasteAlpha.dll .\Effects\PasteAlpha.dll, version=5.2.8174.40450 Landscape.dll .\Effects\Landscape.dll, version=5.2.8174.40347 PhotoAdjustments.dll .\Effects\PhotoAdjustments.dll, version=6.0.8407.22495 Pastel.dll .\Effects\Pastel.dll, version=5.2.8174.40506 OilPaintingPlus.dll .\Effects\OilPaintingPlus.dll, version=5.2.8141.27893 System.Runtime.Serialization.Formatters.dll .\System.Runtime.Serialization.Formatters.dll, version=9.0.24.52809 Trail.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Trail.dll, version=4.0.4642.26791 RemoveDust.dll .\Effects\RemoveDust.dll, version=6.0.8407.22513 SelectionTools.dll .\Effects\SelectionTools.dll, version=6.0.8407.22045 SeamCarving.dll .\Effects\SeamCarving.dll, version=5.2.8176.39366 Transparency.dll .\Effects\Transparency.dll, version=6.0.8407.22532 Stitch.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Stitch.dll, version=4.0.4642.26808 TubeOblique.dll .\Effects\TubeOblique.dll, version=1.2.5.0 VignettePlus.dll .\Effects\VignettePlus.dll, version=6.0.8407.22549 Borders N' Shapes.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Borders N' Shapes.dll, version=4.0.4642.26476 UIAutomationCore.dll C:\Windows\SYSTEM32\UIAutomationCore.dll, version=7.2.19041.1 (WinBuild.160101.0800) PROPSYS.dll C:\Windows\SYSTEM32\PROPSYS.dll, version=7.0.19041.3636 (WinBuild.160101.0800) Color Match.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Color Match.dll, version=4.2.7630.21216 Splatter.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Splatter.dll, version=4.0.5873.25083 Film.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Film.dll, version=4.0.4642.26607 Gradient Bars.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Gradient Bars.dll, version=4.0.5152.23084 Gradient Blocks.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Gradient Blocks.dll, version=4.0.4642.26658 Curves+.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Curves+.dll, version=4.0.6119.31044 Gradient Grid.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Gradient Grid.dll, version=4.0.6436.36068 Jitter.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Jitter.dll, version=4.0.4642.26986 Liquify.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Liquify.dll, version=4.0.5873.25113 Pixelate+.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Pixelate+.dll, version=4.0.4642.26940 Outline Object.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Outline Object.dll, version=4.0.4642.26954 System.Core.dll .\System.Core.dll, version=9.0.24.52809 Random Effect.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Random Effect.dll, version=4.0.4642.26928 Grid Warp.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Grid Warp.dll, version=4.0.6544.34496 Random Shape Fill.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Random Shape Fill.dll, version=4.0.4642.26910 Smudge.dll C:\Users\wainp\Documents\Paint.NET App Files\Effects\Smudge.dll, version=4.0.5873.25097 System.Net.Http.dll .\System.Net.Http.dll, version=9.0.24.52809 System.Net.Primitives.dll .\System.Net.Primitives.dll, version=9.0.24.52809 System.Diagnostics.DiagnosticSource.dll .\System.Diagnostics.DiagnosticSource.dll, version=9.0.24.52809 System.Net.Security.dll .\System.Net.Security.dll, version=9.0.24.52809 System.Security.Cryptography.dll .\System.Security.Cryptography.dll, version=9.0.24.52809 ComputeSharp.Core.dll .\ComputeSharp.Core.dll, version=3.0.1.0 d3dcompiler_47.DLL C:\Windows\SYSTEM32\d3dcompiler_47.DLL, version=10.0.19041.3636 (WinBuild.160101.0800) CRYPTSP.dll C:\Windows\SYSTEM32\CRYPTSP.dll, version=10.0.19041.3636 (WinBuild.160101.0800) dwmapi.DLL C:\Windows\SYSTEM32\dwmapi.DLL, version=10.0.19041.1 (WinBuild.160101.0800) dataexchange.dll C:\Windows\system32\dataexchange.dll, version=10.0.19041.4355 (WinBuild.160101.0800) dcomp.dll C:\Windows\system32\dcomp.dll, version=10.0.19041.4597 (WinBuild.160101.0800) twinapi.appcore.dll C:\Windows\system32\twinapi.appcore.dll, version=10.0.19041.1 (WinBuild.160101.0800) powrprof.dll C:\Windows\SYSTEM32\powrprof.dll, version=10.0.19041.1 (WinBuild.160101.0800) UMPDC.dll C:\Windows\SYSTEM32\UMPDC.dll, version= textinputframework.dll C:\Windows\SYSTEM32\textinputframework.dll, version=10.0.19041.5072 (WinBuild.160101.0800) CoreUIComponents.dll C:\Windows\System32\CoreUIComponents.dll, version=10.0.19041.3636 ntmarta.dll C:\Windows\SYSTEM32\ntmarta.dll, version=10.0.19041.1 (WinBuild.160101.0800) winmm.DLL C:\Windows\SYSTEM32\winmm.DLL, version=10.0.19041.1 (WinBuild.160101.0800) Newtonsoft.Json.dll .\Newtonsoft.Json.dll, version=13.0.3.27908 System.Linq.Expressions.dll .\System.Linq.Expressions.dll, version=9.0.24.52809 System.Text.RegularExpressions.dll .\System.Text.RegularExpressions.dll, version=9.0.24.52809 System.Runtime.Numerics.dll .\System.Runtime.Numerics.dll, version=9.0.24.52809 PaintDotNet.SystemLayer.Native.x64.dll .\PaintDotNet.SystemLayer.Native.x64.dll, version=5.100.9082.35298 System.Runtime.Intrinsics.dll .\System.Runtime.Intrinsics.dll, version=9.0.24.52809 System.IO.Compression.dll .\System.IO.Compression.dll, version=9.0.24.52809 sxs.dll C:\Windows\SYSTEM32\sxs.dll, version=10.0.19041.1 (WinBuild.160101.0800) comdlg32.dll C:\Windows\System32\comdlg32.dll, version=10.0.19041.1 (WinBuild.160101.0800) DUI70.dll C:\Windows\System32\DUI70.dll, version=10.0.19041.1 (WinBuild.160101.0800) DUser.dll C:\Windows\System32\DUser.dll, version=10.0.19041.1 (WinBuild.160101.0800) tiptsf.dll C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll, version=10.0.19041.1 (WinBuild.160101.0800) edputil.dll C:\Windows\SYSTEM32\edputil.dll, version=10.0.19041.1 (WinBuild.160101.0800) explorerframe.dll C:\Windows\system32\explorerframe.dll, version=10.0.19041.4842 (WinBuild.160101.0800) thumbcache.dll C:\Windows\System32\thumbcache.dll, version=10.0.19041.1 (WinBuild.160101.0800) Windows.Globalization.dll C:\Windows\System32\Windows.Globalization.dll, version=10.0.19041.3636 (WinBuild.160101.0800) Bcp47Langs.dll C:\Windows\System32\Bcp47Langs.dll, version=10.0.19041.4355 (WinBuild.160101.0800) bcp47mrm.dll C:\Windows\System32\bcp47mrm.dll, version=10.0.19041.4355 (WinBuild.160101.0800) globinputhost.dll C:\Windows\SYSTEM32\globinputhost.dll, version=10.0.19041.4355 (WinBuild.160101.0800) Windows.FileExplorer.Common.dll C:\Windows\System32\Windows.FileExplorer.Common.dll, version=10.0.19041.1 (WinBuild.160101.0800) iertutil.dll C:\Windows\System32\iertutil.dll, version=11.00.19041.1 (WinBuild.160101.0800) netutils.dll C:\Windows\System32\netutils.dll, version=10.0.19041.3636 (WinBuild.160101.0800) srvcli.dll C:\Windows\System32\srvcli.dll, version=10.0.19041.3636 (WinBuild.160101.0800) StructuredQuery.dll C:\Windows\System32\StructuredQuery.dll, version=7.0.19041.4355 (WinBuild.160101.0800) atlthunk.dll C:\Windows\SYSTEM32\atlthunk.dll, version=10.0.19041.3636 (WinBuild.160101.0800) cldapi.dll C:\Windows\System32\cldapi.dll, version=10.0.19041.3636 (WinBuild.160101.0800) FLTLIB.DLL C:\Windows\System32\FLTLIB.DLL, version=10.0.19041.1 (WinBuild.160101.0800) SspiCli.dll C:\Windows\SYSTEM32\SspiCli.dll, version=10.0.19041.4239 (WinBuild.160101.0800) MPR.dll C:\Windows\SYSTEM32\MPR.dll, version=10.0.19041.1 (WinBuild.160101.0800) drprov.dll C:\Windows\System32\drprov.dll, version=10.0.19041.1 (WinBuild.160101.0800) ntlanman.dll C:\Windows\System32\ntlanman.dll, version=10.0.19041.3636 (WinBuild.160101.0800) davclnt.dll C:\Windows\System32\davclnt.dll, version=10.0.19041.3636 (WinBuild.160101.0800) DAVHLPR.dll C:\Windows\System32\DAVHLPR.dll, version=10.0.19041.3636 (WinBuild.160101.0800) wkscli.dll C:\Windows\System32\wkscli.dll, version=10.0.19041.3636 (WinBuild.160101.0800) cscapi.dll C:\Windows\SYSTEM32\cscapi.dll, version=10.0.19041.3636 (WinBuild.160101.0800) twinapi.dll C:\Windows\System32\twinapi.dll, version=10.0.19041.1 (WinBuild.160101.0800) dlnashext.dll C:\Windows\System32\dlnashext.dll, version=10.0.19041.1 (WinBuild.160101.0800) DevDispItemProvider.dll C:\Windows\System32\DevDispItemProvider.dll, version=10.0.19041.3636 (WinBuild.160101.0800) MMDevApi.dll C:\Windows\System32\MMDevApi.dll, version=10.0.19041.1 (WinBuild.160101.0800) AudioSes.dll C:\Windows\SYSTEM32\AudioSes.dll, version=10.0.19041.1 (WinBuild.160101.0800) ntshrui.dll C:\Windows\SYSTEM32\ntshrui.dll, version=10.0.19041.1 (WinBuild.160101.0800) MrmCoreR.dll C:\Windows\System32\MrmCoreR.dll, version=10.0.19041.4717 (WinBuild.160101.0800) windows.staterepositorycore.dll C:\Windows\SYSTEM32\windows.staterepositorycore.dll, version=10.0.19041.4842 (WinBuild.160101.0800) ProductInfo.dll C:\ProgramData\A-Volute\A-Volute.Nahimic\Modules\Scheduled\x64\ProductInfo.dll, version=1.10.3.0 ASM.Plugin.AudioDevProps2.dll C:\ProgramData\A-Volute\A-Volute.Nahimic\Modules\Scheduled\x64\ASM.Plugin.AudioDevProps2.dll, version=1.0.1.0 EhStorShell.dll C:\Windows\System32\EhStorShell.dll, version=10.0.19041.1 (WinBuild.160101.0800) PhotoMetadataHandler.dll C:\Windows\SYSTEM32\PhotoMetadataHandler.dll, version=10.0.19041.4355 (WinBuild.160101.0800) coml2.dll C:\Windows\System32\coml2.dll, version=10.0.19041.4355 (WinBuild.160101.0800) LINKINFO.dll C:\Windows\SYSTEM32\LINKINFO.dll, version=10.0.19041.3636 (WinBuild.160101.0800) ActXPrxy.dll C:\Windows\System32\ActXPrxy.dll, version=10.0.19041.3758 (WinBuild.160101.0800) policymanager.dll C:\Windows\SYSTEM32\policymanager.dll, version=10.0.19041.4597 (WinBuild.160101.0800) msvcp110_win.dll C:\Windows\SYSTEM32\msvcp110_win.dll, version=10.0.19041.3636 (WinBuild.160101.0800) IconCodecService.dll C:\Windows\system32\IconCodecService.dll, version=10.0.19041.1 (WinBuild.160101.0800) FileSyncShell64.dll C:\Users\wainp\AppData\Local\Microsoft\OneDrive\24.206.1013.0004\FileSyncShell64.dll, version=24.206.1013.0004 Secur32.dll C:\Windows\SYSTEM32\Secur32.dll, version=10.0.19041.3636 (WinBuild.160101.0800) WININET.dll C:\Windows\SYSTEM32\WININET.dll, version=11.00.19041.3636 (WinBuild.160101.0800) CRYPTBASE.DLL C:\Windows\SYSTEM32\CRYPTBASE.DLL, version=10.0.19041.3636 (WinBuild.160101.0800) NetworkExplorer.dll C:\Windows\system32\NetworkExplorer.dll, version=10.0.19041.1 (WinBuild.160101.0800) urlmon.dll C:\Windows\System32\urlmon.dll, version=11.00.19041.3636 (WinBuild.160101.0800) System.CodeDom.dll .\System.CodeDom.dll, version=9.0.24.52809 System.IO.Compression.Native.dll .\System.IO.Compression.Native.dll, version=9,0,24,52809 @Commit: 9d5a6a9aa463d6d10b0b0ba6d5982cc82f363dc3 System.Private.Xml.Linq.dll .\System.Private.Xml.Linq.dll, version=9.0.24.52809 AvifNative_x64.dll .\Bundled\AvifFileType\AvifNative_x64.dll, version=3.10.0.0 System.Xml.XDocument.dll .\System.Xml.XDocument.dll, version=9.0.24.52809 K4os.Compression.LZ4.dll .\K4os.Compression.LZ4.dll, version=1.3.8.0 PresentationFramework-SystemXmlLinq.dll .\PresentationFramework-SystemXmlLinq.dll, version=9.0.24.52902 System.Xml.Linq.dll .\System.Xml.Linq.dll, version=9.0.24.52809 cryptnet.dll C:\Windows\SYSTEM32\cryptnet.dll, version=10.0.19041.3636 (WinBuild.160101.0800) drvstore.dll C:\Windows\SYSTEM32\drvstore.dll, version=10.0.19041.4355 (WinBuild.160101.0800) imagehlp.dll C:\Windows\System32\imagehlp.dll, version=10.0.19041.3636 (WinBuild.160101.0800) rsaenh.dll C:\Windows\system32\rsaenh.dll, version=10.0.19041.1 (WinBuild.160101.0800) nvppex.dll C:\Windows\System32\DriverStore\FileRepository\nvmii.inf_amd64_881a68749106a57c\nvppex.dll, version=32.0.15.6614 Quote
Rick Brewster Posted November 15 Posted November 15 You have something called "A-Volute" installed. It's known to cause all sorts of issues, including this. I forget if you can fix this by reinstalling, or if you have to completely remove it. Searching the forum for "A-Volute" should find the answer. But yeah, it's A-Volute. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html
quibop Posted November 15 Author Posted November 15 disabled nahimic in the services thing and i checked the diagnostics again and a-volute is nowhere to be found so that should've taken care of that i'll come back if the problem persists 1 1 Quote
Tactilis Posted November 15 Posted November 15 5 hours ago, quibop said: disabled nahimic in the services Info for other people who may encounter this problem: "Nahimic is audio software made by A-Volute – a France-based company specialized in gaming audio solutions. Similar to what Realtek and Conexant software does, Nahimic allows users to make various audio enhancements and adjustments via a single control panel application." Quote
Rick Brewster Posted November 16 Posted November 16 Looks like there's a secret way (for my code I mean) to block Nahimic: https://docs.kicad.org/doxygen/windows_2app_8cpp_source.html#:~:text=// So there exists this malware called Nahimic by A-Volute So this shouldn't be a problem anymore starting with PDN 5.1.1 ... extern "C" { // So there exists this malware called Nahimic by A-Volute, which is marketed as an audio enhancement // software. In reality it's an aggressive form of malware that injects itself wildly into every process // on the system for god knows what reason. It even includes a tracking/analytics package, <insert tinfoil hat> // Our problem is this garbage basically bugs out OpenGL (why an audio driver does that, who knows, its made by morons) // And then we get issues reported both in our issue tracker and sentry reports as a result // At least these malware authors were nice to include a dumb "disable" trick where it checks if the exe is exporting // a symbol called NoHotPatch, so here we are. // Hopefully this works and stops the bug reports. Apparently the worst part is this malware aggressively gets reinstalled // by awful low-tier motherboard vendors like MSI, Alienware and others who bundled it into their driver packages // and distributed it over Windows Update // Did I mention they clearly had issues with other apps so instead of fixing their malware, they blacklisted a hundred common // apps and even some games in their own config? Obviously kicad isn't on that blacklist :( // This malware seems to no longer be distributed as Nahimic and replaced with "Sonar" by SteelSeries. // Time will tell if it's the same garbage, I'm not volunteering to install it. __declspec(dllexport) void NoHotPatch() { // this is a intentionally empty function return; } } 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html
quibop Posted Tuesday at 03:19 PM Author Posted Tuesday at 03:19 PM (edited) ok apparently even though i disabled nahimic in services a few weeks ago (and it's still disabled) the screen glitching is still happening, although maybe less frequently? clearly something else is causing this as well but idk what it is that.txt Edited Tuesday at 03:27 PM by quibop it's called services not system manager you dum dum Quote
Rick Brewster Posted Tuesday at 03:28 PM Posted Tuesday at 03:28 PM @quibop Try the 5.1.1 Beta (build 9102). It may help. You can also disable FreeSync / GSYNC / VRR, which may help. Lastly, you can disable something called MPOs using the .reg file I posted here: https://forums.getpaint.net/topic/132047-crashing-gpu/page/2/#findComment-642002 (even though that links to NVIDIA's site, the reg file will work for any GPU) Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html
Xiel Posted Tuesday at 10:00 PM Posted Tuesday at 10:00 PM On 11/15/2024 at 2:49 AM, toe_head2001 said: Hi @quibop, Please post the diagnostic information found within paint.net. Settings -> Diagnostics -> Copy to clipboard. I have had the same issue. normally happens while I'm pasting something and moving it. Spoiler Application Paint.NET 5.1 (Stable 5.100.9082.35298) Build Date November 12, 2024 Current Date and Time 2024-12-03 4:58:10 PM System uptime 16.21:59:03.5150000 Process uptime 00:04:57.5260000 Application state Running Install type Classic Install directory C:\Program Files\paint.net Application directory C:\Program Files\paint.net Current directory C:\Program Files\paint.net OS Windows 10 Home x64 (10.0.19045.0) Runtime .NET 9.0.0 x64 Physical Memory 32,637 MB (20,299 MB free) Paging File 49,021 MB (31,208 MB free) Working Set 322,676 KB Handles 2445 Threads 159 GDI objects 208 User objects 263 Language en-US UI Scaling 1.00x (96 DPI) Cursor Scaling 1.00x UI/Canvas GPU True Rendering GPU 🚀 Performance (NVIDIA GeForce RTX 3080 Ti) Advanced Color True Windows Ink True Animations True Translucent Windows True Remote Session False Battery Saver False Theme Aero (Aero.msstyles), Light Updates Enabled Last Checked 2024-12-03 Journal ShouldCheckForUpdate, CheckedForUpdate CPU 11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz Speed ~3504 MHz Cores / Threads 8 / 16 Features SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2, AVX512BW, AVX512CD, AVX512DQ, AVX512F, AVX512_VBMI Display Generic PnP Monitor Connected to NVIDIA GeForce RTX 3080 Ti Resolution 2560 x 1440, 8-bit, 170 Hz DPI 96 (1.00x scale) Coordinates (L=0, T=0, R=2560, B=1440) Advanced Color StandardDynamicRange SDR white level 80 nits Color space RgbFullGamma22NoneP709 Composition Support Fullscreen, Windowed Display LG IPSFULLHD(HDMI) Connected to NVIDIA GeForce RTX 3080 Ti Resolution 1920 x 1080, 8-bit, 60 Hz DPI 96 (1.00x scale) Coordinates (L=2560, T=353, R=4480, B=1433) Advanced Color StandardDynamicRange SDR white level 80 nits Color space RgbFullGamma22NoneP709 Composition Support Fullscreen, CursorStretched Video Card NVIDIA GeForce RTX 3080 Ti Hardware Acceleration Supported Performance Class Good Dedicated Video RAM 12,086 MB Dedicated System RAM 0 MB Shared System RAM 16,318 MB Driver Version 32.0.15.6094 Vendor ID 0x10DE Device ID 0x2208 Subsystem ID 0x88021043 Revision 161 LUID 0x0000E89C Flags AcgCompatible, SupportMonitoredFences, KeyedMutexConformance Graphics Preemption PixelBoundary Compute Preemption DispatchBoundary Outputs 2 Feature Level Level_12_1 Features Doubles, ComputeShadersEtc Maximum Bitmap Size 16384 Video Card Microsoft Basic Render Driver Hardware Acceleration N/A Performance Class VeryLow Dedicated Video RAM 0 MB Dedicated System RAM 0 MB Shared System RAM 16,318 MB Driver Version 10.0.19041.4355 Vendor ID 0x1414 Device ID 0x008C Subsystem ID 0x00000000 Revision 0 LUID 0x0000F636 Flags Software, AcgCompatible, SupportMonitoredFences, KeyedMutexConformance Graphics Preemption InstructionBoundary Compute Preemption InstructionBoundary Outputs 0 Feature Level Level_12_1 Features Doubles, ComputeShadersEtc Maximum Bitmap Size 8388608 Managed assemblies 104 System.Private.CoreLib .\System.Private.CoreLib.dll, Version=9.0.0.0, PublicKeyToken=7cec85d7bea7798e paintdotnet .\paintdotnet.dll, Version=5.100.9082.35298 System.Runtime .\System.Runtime.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Windows.Core .\PaintDotNet.Windows.Core.dll, Version=5.100.9082.35298 PaintDotNet.Windows .\PaintDotNet.Windows.dll, Version=5.100.9082.35298 PaintDotNet.ComponentModel .\PaintDotNet.ComponentModel.dll, Version=5.100.9082.35298 PaintDotNet.Primitives .\PaintDotNet.Primitives.dll, Version=5.100.9082.35298 PaintDotNet.Fundamentals .\PaintDotNet.Fundamentals.dll, Version=5.100.9082.35298 System.Windows.Forms .\System.Windows.Forms.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089 System.Diagnostics.Tracing .\System.Diagnostics.Tracing.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Thread .\System.Threading.Thread.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Base .\PaintDotNet.Base.dll, Version=5.100.9082.35298 System.Collections.Concurrent .\System.Collections.Concurrent.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Collections .\PaintDotNet.Collections.dll, Version=5.100.9082.35298 TerraFX.Interop.Windows .\TerraFX.Interop.Windows.dll, Version=10.0.26100.0, PublicKeyToken=35b01b53313a6f7e PaintDotNet.Runtime .\PaintDotNet.Runtime.dll, Version=5.100.9082.35298 PointerToolkit .\PointerToolkit.dll, Version=1.0.1.0 PaintDotNet.Systrace .\PaintDotNet.Systrace.dll, Version=5.100.9082.35298 System.Private.Uri .\System.Private.Uri.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Windows.Framework .\PaintDotNet.Windows.Framework.dll, Version=5.100.9082.35298 PaintDotNet.UI .\PaintDotNet.UI.dll, Version=5.100.9082.35298 Microsoft.Windows.SDK.NET .\Microsoft.Windows.SDK.NET.dll, Version=10.0.26100.38, PublicKeyToken=31bf3856ad364e35 WindowsBase .\WindowsBase.dll, Version=9.0.0.0, PublicKeyToken=31bf3856ad364e35 PaintDotNet.ObjectModel .\PaintDotNet.ObjectModel.dll, Version=5.100.9082.35298 PresentationFramework .\PresentationFramework.dll, Version=9.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Xaml .\System.Xaml.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089 WinRT.Runtime .\WinRT.Runtime.dll, Version=2.1.0.0, PublicKeyToken=99ea127f02d97709 System.ComponentModel .\System.ComponentModel.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.InteropServices .\System.Runtime.InteropServices.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.Primitives .\System.ComponentModel.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections .\System.Collections.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading .\System.Threading.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ObjectModel .\System.ObjectModel.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.Primitives .\Microsoft.Win32.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Windows.Forms.Primitives .\System.Windows.Forms.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089 System.Private.Windows.Core .\System.Private.Windows.Core.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089 System.Configuration.ConfigurationManager .\System.Configuration.ConfigurationManager.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Collections.Specialized .\System.Collections.Specialized.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Private.Xml .\System.Private.Xml.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Drawing.Primitives .\System.Drawing.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Net.WebClient .\System.Net.WebClient.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Text.Encoding.CodePages .\System.Text.Encoding.CodePages.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Core .\PaintDotNet.Core.dll, Version=5.100.9082.35298 System.Memory .\System.Memory.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 PaintDotNet.SystemLayer .\PaintDotNet.SystemLayer.dll, Version=5.100.9082.35298 PaintDotNet.Resources .\PaintDotNet.Resources.dll, Version=5.100.9082.35298 Microsoft.Win32.Registry .\Microsoft.Win32.Registry.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Drawing.Common .\System.Drawing.Common.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Linq .\System.Linq.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Data .\PaintDotNet.Data.dll, Version=5.100.9082.35298 PaintDotNet.Framework .\PaintDotNet.Framework.dll, Version=5.100.9082.35298 CommunityToolkit.HighPerformance .\CommunityToolkit.HighPerformance.dll, Version=8.3.0.0, PublicKeyToken=4aff67a105548ee2 ComputeSharp.D2D1 .\ComputeSharp.D2D1.dll, Version=3.0.1.0, PublicKeyToken=dc35fa229f6881d8 System.Xml.ReaderWriter .\System.Xml.ReaderWriter.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.Encoding.Extensions .\System.Text.Encoding.Extensions.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Immutable .\System.Collections.Immutable.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.SystemEvents .\Microsoft.Win32.SystemEvents.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.ComponentModel.TypeConverter .\System.ComponentModel.TypeConverter.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PointerToolkit.TerraFX.Interop.Windows .\PointerToolkit.TerraFX.Interop.Windows.dll, Version=10.0.26100.0 PresentationCore .\PresentationCore.dll, Version=9.0.0.0, PublicKeyToken=31bf3856ad364e35 DirectWriteForwarder .\DirectWriteForwarder.dll, Version=9.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Runtime.Extensions .\System.Runtime.Extensions.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.Debug .\System.Diagnostics.Debug.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.CompilerServices.VisualC .\System.Runtime.CompilerServices.VisualC.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.NonGeneric .\System.Collections.NonGeneric.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.EventBasedAsync .\System.ComponentModel.EventBasedAsync.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Security.Principal.Windows .\System.Security.Principal.Windows.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Security.Claims .\System.Security.Claims.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.TraceSource .\System.Diagnostics.TraceSource.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.PropertySystem .\PaintDotNet.PropertySystem.dll, Version=5.100.9082.35298 System.IO.Packaging .\System.IO.Packaging.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Numerics.Vectors .\System.Numerics.Vectors.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Effects.Core .\PaintDotNet.Effects.Core.dll, Version=5.100.9082.35298 Accessibility .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35 System.Threading.Tasks.Parallel .\System.Threading.Tasks.Parallel.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.FileVersionInfo .\System.Diagnostics.FileVersionInfo.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Effects.Gpu .\PaintDotNet.Effects.Gpu.dll, Version=5.100.9082.35298 System.Net.Http .\System.Net.Http.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Net.Primitives .\System.Net.Primitives.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.DiagnosticSource .\System.Diagnostics.DiagnosticSource.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Net.Security .\System.Net.Security.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Security.Cryptography .\System.Security.Cryptography.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.ThreadPool .\System.Threading.ThreadPool.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Loader .\System.Runtime.Loader.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a WebPFileType .\Bundled\WebPFileType\WebPFileType.dll, Version=1.4.0.0 DdsFileTypePlus .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.12.11.0 AvifFileType .\Bundled\AvifFileType\AvifFileType.dll, Version=3.10.0.0 PaintDotNet.Effects .\PaintDotNet.Effects.dll, Version=5.100.9082.35298 PaintDotNet.Effects.Legacy .\PaintDotNet.Effects.Legacy.dll, Version=5.100.9082.35298 SauceControl.Blake2Fast .\SauceControl.Blake2Fast.dll, Version=2.0.0.0, PublicKeyToken=deebe556222e40dc ComputeSharp.Core .\ComputeSharp.Core.dll, Version=3.0.1.0, PublicKeyToken=dc35fa229f6881d8 PhotoSauce.MagicScaler .\PhotoSauce.MagicScaler.dll, Version=0.15.0.0, PublicKeyToken=fc6b9b7b06809481 System.IO.Hashing .\System.IO.Hashing.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 Newtonsoft.Json .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed System.Linq.Expressions .\System.Linq.Expressions.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.RegularExpressions .\System.Text.RegularExpressions.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Numerics .\System.Runtime.Numerics.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Intrinsics .\System.Runtime.Intrinsics.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Net.Sockets .\System.Net.Sockets.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Overlapped .\System.Threading.Overlapped.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Net.NameResolution .\System.Net.NameResolution.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Reflection.MetadataLoadContext .\System.Reflection.MetadataLoadContext.dll, Version=9.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.IO.Compression .\System.IO.Compression.dll, Version=9.0.0.0, PublicKeyToken=b77a5c561934e089 System.Diagnostics.Process .\System.Diagnostics.Process.dll, Version=9.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Native modules 223 paintdotnet.exe .\paintdotnet.exe, version=5.100.9082.35298 ntdll.dll C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.4842 (WinBuild.160101.0800) KERNEL32.DLL C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.19041.5072 (WinBuild.160101.0800) KERNELBASE.dll C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.5072 (WinBuild.160101.0800) SHELL32.dll C:\WINDOWS\System32\SHELL32.dll, version=10.0.19041.4957 (WinBuild.160101.0800) msvcp_win.dll C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.3636 (WinBuild.160101.0800) ucrtbase.dll C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.3636 (WinBuild.160101.0800) USER32.dll C:\WINDOWS\System32\USER32.dll, version=10.0.19041.1 (WinBuild.160101.0800) win32u.dll C:\WINDOWS\System32\win32u.dll, version=10.0.19041.5129 (WinBuild.160101.0800) GDI32.dll C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.4474 (WinBuild.160101.0800) gdi32full.dll C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.4957 (WinBuild.160101.0800) ole32.dll C:\WINDOWS\System32\ole32.dll, version=10.0.19041.3636 (WinBuild.160101.0800) RPCRT4.dll C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.3636 (WinBuild.160101.0800) combase.dll C:\WINDOWS\System32\combase.dll, version=10.0.19041.3636 (WinBuild.160101.0800) OLEAUT32.dll C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.3636 (WinBuild.160101.0800) SHLWAPI.dll C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800) msvcrt.dll C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.3636 (WinBuild.160101.0800) VCRUNTIME140_1.dll .\VCRUNTIME140_1.dll, version=14.42.34433.0 VCRUNTIME140.dll .\VCRUNTIME140.dll, version=14.42.34433.0 IMM32.DLL C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.4474 (WinBuild.160101.0800) shcore.dll C:\WINDOWS\System32\shcore.dll, version=10.0.19041.1 (WinBuild.160101.0800) hostfxr.dll .\hostfxr.dll, version=9,0,24,52809 @Commit: 9d5a6a9aa463d6d10b0b0ba6d5982cc82f363dc3 ADVAPI32.dll C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.1 (WinBuild.160101.0800) sechost.dll C:\WINDOWS\System32\sechost.dll, version=10.0.19041.1 (WinBuild.160101.0800) bcrypt.dll C:\WINDOWS\System32\bcrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) hostpolicy.dll .\hostpolicy.dll, version=9,0,24,52809 @Commit: 9d5a6a9aa463d6d10b0b0ba6d5982cc82f363dc3 coreclr.dll .\coreclr.dll, version=9,0,24,52809 @Commit: 9d5a6a9aa463d6d10b0b0ba6d5982cc82f363dc3 bcryptPrimitives.dll C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.5007 (WinBuild.160101.0800) System.Private.CoreLib.dll .\System.Private.CoreLib.dll, version=9.0.24.52809 kernel.appcore.dll C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.3758 (WinBuild.160101.0800) paintdotnet.dll .\paintdotnet.dll, version=5.100.9082.35298 System.Runtime.dll .\System.Runtime.dll, version=9.0.24.52809 uxtheme.dll C:\WINDOWS\system32\uxtheme.dll, version=10.0.19041.4529 (WinBuild.160101.0800) PaintDotNet.Windows.Core.dll .\PaintDotNet.Windows.Core.dll, version=5.100.9082.35298 PaintDotNet.Windows.dll .\PaintDotNet.Windows.dll, version=5.100.9082.35298 PaintDotNet.ComponentModel.dll .\PaintDotNet.ComponentModel.dll, version=5.100.9082.35298 PaintDotNet.Primitives.dll .\PaintDotNet.Primitives.dll, version=5.100.9082.35298 PaintDotNet.Fundamentals.dll .\PaintDotNet.Fundamentals.dll, version=5.100.9082.35298 System.Windows.Forms.dll .\System.Windows.Forms.dll, version=9.0.24.52901 System.Diagnostics.Tracing.dll .\System.Diagnostics.Tracing.dll, version=9.0.24.52809 clrjit.dll .\clrjit.dll, version=9,0,24,52809 @Commit: 9d5a6a9aa463d6d10b0b0ba6d5982cc82f363dc3 icu.dll C:\WINDOWS\SYSTEM32\icu.dll, version=64, 2, 0, 0 (WinBuild.160101.0800) System.Threading.Thread.dll .\System.Threading.Thread.dll, version=9.0.24.52809 PaintDotNet.Base.dll .\PaintDotNet.Base.dll, version=5.100.9082.35298 System.Collections.Concurrent.dll .\System.Collections.Concurrent.dll, version=9.0.24.52809 PaintDotNet.Collections.dll .\PaintDotNet.Collections.dll, version=5.100.9082.35298 TerraFX.Interop.Windows.dll .\TerraFX.Interop.Windows.dll, version=10.0.26100.0 dxgi.DLL C:\WINDOWS\SYSTEM32\dxgi.DLL, version=10.0.19041.5072 (WinBuild.160101.0800) PaintDotNet.Runtime.dll .\PaintDotNet.Runtime.dll, version=5.100.9082.35298 PointerToolkit.dll .\PointerToolkit.dll, version=1.0.1.0 PaintDotNet.Systrace.dll .\PaintDotNet.Systrace.dll, version=5.100.9082.35298 windows.storage.dll C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.1 (WinBuild.160101.0800) Wldp.dll C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Private.Uri.dll .\System.Private.Uri.dll, version=9.0.24.52809 PaintDotNet.Windows.Framework.dll .\PaintDotNet.Windows.Framework.dll, version=5.100.9082.35298 PaintDotNet.UI.dll .\PaintDotNet.UI.dll, version=5.100.9082.35298 Microsoft.Windows.SDK.NET.dll .\Microsoft.Windows.SDK.NET.dll, version=10.0.26100.52 WindowsBase.dll .\WindowsBase.dll, version=9.0.24.52902 PaintDotNet.ObjectModel.dll .\PaintDotNet.ObjectModel.dll, version=5.100.9082.35298 PresentationFramework.dll .\PresentationFramework.dll, version=9.0.24.52902 System.Xaml.dll .\System.Xaml.dll, version=9.0.24.52902 WinRT.Runtime.dll .\WinRT.Runtime.dll, version=2.1.6.47881 System.ComponentModel.dll .\System.ComponentModel.dll, version=9.0.24.52809 System.Runtime.InteropServices.dll .\System.Runtime.InteropServices.dll, version=9.0.24.52809 System.ComponentModel.Primitives.dll .\System.ComponentModel.Primitives.dll, version=9.0.24.52809 System.Collections.dll .\System.Collections.dll, version=9.0.24.52809 System.Threading.dll .\System.Threading.dll, version=9.0.24.52809 coremessaging.DLL C:\WINDOWS\SYSTEM32\coremessaging.DLL, version=10.0.19041.4355 WS2_32.dll C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.3636 (WinBuild.160101.0800) System.ObjectModel.dll .\System.ObjectModel.dll, version=9.0.24.52809 Microsoft.Win32.Primitives.dll .\Microsoft.Win32.Primitives.dll, version=9.0.24.52809 System.Windows.Forms.Primitives.dll .\System.Windows.Forms.Primitives.dll, version=9.0.24.52901 System.Private.Windows.Core.dll .\System.Private.Windows.Core.dll, version=9.0.24.52901 System.Configuration.ConfigurationManager.dll .\System.Configuration.ConfigurationManager.dll, version=9.0.24.52809 System.Collections.Specialized.dll .\System.Collections.Specialized.dll, version=9.0.24.52809 System.Private.Xml.dll .\System.Private.Xml.dll, version=9.0.24.52809 System.Drawing.Primitives.dll .\System.Drawing.Primitives.dll, version=9.0.24.52809 System.Net.WebClient.dll .\System.Net.WebClient.dll, version=9.0.24.52809 System.Text.Encoding.CodePages.dll .\System.Text.Encoding.CodePages.dll, version=9.0.24.52809 PaintDotNet.Core.dll .\PaintDotNet.Core.dll, version=5.100.9082.35298 System.Memory.dll .\System.Memory.dll, version=9.0.24.52809 PaintDotNet.SystemLayer.dll .\PaintDotNet.SystemLayer.dll, version=5.100.9082.35298 PaintDotNet.Resources.dll .\PaintDotNet.Resources.dll, version=5.100.9082.35298 Microsoft.Win32.Registry.dll .\Microsoft.Win32.Registry.dll, version=9.0.24.52809 System.Drawing.Common.dll .\System.Drawing.Common.dll, version=9.0.24.52901 System.Linq.dll .\System.Linq.dll, version=9.0.24.52809 PaintDotNet.Data.dll .\PaintDotNet.Data.dll, version=5.100.9082.35298 PaintDotNet.Framework.dll .\PaintDotNet.Framework.dll, version=5.100.9082.35298 CommunityToolkit.HighPerformance.dll .\CommunityToolkit.HighPerformance.dll, version=8.3.2.1 ComputeSharp.D2D1.dll .\ComputeSharp.D2D1.dll, version=3.0.1.0 PresentationNative_cor3.dll .\PresentationNative_cor3.dll, version=9,0,24,47404 @Commit: c7dea8ec4c32ed09d3cedbdd1f967a276b3f75c0 System.Xml.ReaderWriter.dll .\System.Xml.ReaderWriter.dll, version=9.0.24.52809 System.Text.Encoding.Extensions.dll .\System.Text.Encoding.Extensions.dll, version=9.0.24.52809 System.Collections.Immutable.dll .\System.Collections.Immutable.dll, version=9.0.24.52809 Microsoft.Win32.SystemEvents.dll .\Microsoft.Win32.SystemEvents.dll, version=9.0.24.52809 System.ComponentModel.TypeConverter.dll .\System.ComponentModel.TypeConverter.dll, version=9.0.24.52809 PointerToolkit.TerraFX.Interop.Windows.dll .\PointerToolkit.TerraFX.Interop.Windows.dll, version=10.0.26100.0 PresentationCore.dll .\PresentationCore.dll, version=9.0.24.52902 dwrite.dll C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.1 (WinBuild.160101.0800) DirectWriteForwarder.dll .\DirectWriteForwarder.dll, version=9,0,24,52902 @Commit: a04736acb8edb533756131d3d5fc55f15cd03d6a System.Runtime.Extensions.dll .\System.Runtime.Extensions.dll, version=9.0.24.52809 System.Diagnostics.Debug.dll .\System.Diagnostics.Debug.dll, version=9.0.24.52809 System.Runtime.CompilerServices.VisualC.dll .\System.Runtime.CompilerServices.VisualC.dll, version=9.0.24.52809 System.Collections.NonGeneric.dll .\System.Collections.NonGeneric.dll, version=9.0.24.52809 System.ComponentModel.EventBasedAsync.dll .\System.ComponentModel.EventBasedAsync.dll, version=9.0.24.52809 System.Security.Principal.Windows.dll .\System.Security.Principal.Windows.dll, version=9.0.24.52809 System.Security.Claims.dll .\System.Security.Claims.dll, version=9.0.24.52809 System.Diagnostics.TraceSource.dll .\System.Diagnostics.TraceSource.dll, version=9.0.24.52809 PaintDotNet.PropertySystem.dll .\PaintDotNet.PropertySystem.dll, version=5.100.9082.35298 System.IO.Packaging.dll .\System.IO.Packaging.dll, version=9.0.24.52809 System.Numerics.Vectors.dll .\System.Numerics.Vectors.dll, version=9.0.24.52809 PaintDotNet.Effects.Core.dll .\PaintDotNet.Effects.Core.dll, version=5.100.9082.35298 Accessibility.dll .\Accessibility.dll, version=9.0.24.52901 System.Threading.Tasks.Parallel.dll .\System.Threading.Tasks.Parallel.dll, version=9.0.24.52809 System.Diagnostics.FileVersionInfo.dll .\System.Diagnostics.FileVersionInfo.dll, version=9.0.24.52809 PaintDotNet.Effects.Gpu.dll .\PaintDotNet.Effects.Gpu.dll, version=5.100.9082.35298 System.Net.Http.dll .\System.Net.Http.dll, version=9.0.24.52809 System.Net.Primitives.dll .\System.Net.Primitives.dll, version=9.0.24.52809 System.Diagnostics.DiagnosticSource.dll .\System.Diagnostics.DiagnosticSource.dll, version=9.0.24.52809 System.Net.Security.dll .\System.Net.Security.dll, version=9.0.24.52809 System.Security.Cryptography.dll .\System.Security.Cryptography.dll, version=9.0.24.52809 System.Threading.ThreadPool.dll .\System.Threading.ThreadPool.dll, version=9.0.24.52809 MSCTF.dll C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.1 (WinBuild.160101.0800) profapi.dll C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.19041.4355 (WinBuild.160101.0800) d3d11.DLL C:\WINDOWS\SYSTEM32\d3d11.DLL, version=10.0.19041.4355 (WinBuild.160101.0800) nvldumdx.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispig.inf_amd64_0afec3f2050014a0\nvldumdx.dll, version=32.0.15.6094 VERSION.dll C:\WINDOWS\SYSTEM32\VERSION.dll, version=10.0.19041.3636 (WinBuild.160101.0800) d2d1.DLL C:\WINDOWS\SYSTEM32\d2d1.DLL, version=10.0.19041.1 (WinBuild.160101.0800) msasn1.dll C:\WINDOWS\SYSTEM32\msasn1.dll, version=10.0.19041.3636 (WinBuild.160101.0800) cryptnet.dll C:\WINDOWS\SYSTEM32\cryptnet.dll, version=10.0.19041.3636 (WinBuild.160101.0800) CRYPT32.dll C:\WINDOWS\System32\CRYPT32.dll, version=10.0.19041.1 (WinBuild.160101.0800) cryptbase.dll C:\WINDOWS\SYSTEM32\cryptbase.dll, version=10.0.19041.3636 (WinBuild.160101.0800) drvstore.dll C:\WINDOWS\SYSTEM32\drvstore.dll, version=10.0.19041.4355 (WinBuild.160101.0800) devobj.dll C:\WINDOWS\SYSTEM32\devobj.dll, version=10.0.19041.4355 (WinBuild.160101.0800) cfgmgr32.dll C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.3996 (WinBuild.160101.0800) wintrust.dll C:\WINDOWS\System32\wintrust.dll, version=10.0.19041.4957 (WinBuild.160101.0800) gdiplus.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.4597_none_91a78020cc854124\gdiplus.dll, version=10.0.19041.4597 (WinBuild.160101.0800) imagehlp.dll C:\WINDOWS\System32\imagehlp.dll, version=10.0.19041.3636 (WinBuild.160101.0800) WindowsCodecs.dll C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.5129 (WinBuild.160101.0800) clbcatq.dll C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800) UIAnimation.dll C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.3636 (WinBuild.160101.0800) XmlLite.dll C:\WINDOWS\SYSTEM32\XmlLite.dll, version=10.0.19041.3636 (WinBuild.160101.0800) wtsapi32.dll C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.19041.3636 (WinBuild.160101.0800) WINSTA.dll C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.3636 (WinBuild.160101.0800) comctl32.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.4355_none_60b8b9eb71f62e16\comctl32.dll, version=6.10 (WinBuild.160101.0800) CRYPTSP.dll C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.19041.3636 (WinBuild.160101.0800) rsaenh.dll C:\WINDOWS\system32\rsaenh.dll, version=10.0.19041.1 (WinBuild.160101.0800) nvgpucomp64.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispig.inf_amd64_0afec3f2050014a0\nvgpucomp64.dll, version=32.0.15.6094 mfplat.dll C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.1 (WinBuild.160101.0800) RTWorkQ.DLL C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.4355 (WinBuild.160101.0800) CompPkgSup.DLL C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.4355 (WinBuild.160101.0800) Windows.StateRepositoryPS.dll C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.19041.4842 (WinBuild.160101.0800) System.Runtime.Loader.dll .\System.Runtime.Loader.dll, version=9.0.24.52809 WebPFileType.dll .\Bundled\WebPFileType\WebPFileType.dll, version=1.4.0.0 DdsFileTypePlus.dll .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.12.11.0 AvifFileType.dll .\Bundled\AvifFileType\AvifFileType.dll, version=3.10.0.0 TextShaping.dll C:\WINDOWS\SYSTEM32\TextShaping.dll, version= WinTypes.dll C:\Windows\System32\WinTypes.dll, version=10.0.19041.3636 (WinBuild.160101.0800) PaintDotNet.Effects.dll .\PaintDotNet.Effects.dll, version=5.100.9082.35298 nvwgf2umx.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispig.inf_amd64_0afec3f2050014a0\nvwgf2umx.dll, version=32.0.15.6094 powrprof.dll C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.1 (WinBuild.160101.0800) WINMM.dll C:\WINDOWS\SYSTEM32\WINMM.dll, version=10.0.19041.1 (WinBuild.160101.0800) UMPDC.dll C:\WINDOWS\SYSTEM32\UMPDC.dll, version= PaintDotNet.Effects.Legacy.dll .\PaintDotNet.Effects.Legacy.dll, version=5.100.9082.35298 dxcore.dll C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.4474 (WinBuild.160101.0800) nvppex.dll C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispig.inf_amd64_0afec3f2050014a0\nvppex.dll, version=32.0.15.6094 D3D10Warp.dll C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.4355 (WinBuild.160101.0800) UIAutomationCore.dll C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.19041.1 (WinBuild.160101.0800) PROPSYS.dll C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.3636 (WinBuild.160101.0800) SauceControl.Blake2Fast.dll .\SauceControl.Blake2Fast.dll, version=2.0.0.0 ComputeSharp.Core.dll .\ComputeSharp.Core.dll, version=3.0.1.0 d3dcompiler_47.DLL C:\WINDOWS\SYSTEM32\d3dcompiler_47.DLL, version=10.0.19041.3636 (WinBuild.160101.0800) mscms.DLL C:\WINDOWS\SYSTEM32\mscms.DLL, version=10.0.19041.1 (WinBuild.160101.0800) ColorAdapterClient.dll C:\WINDOWS\SYSTEM32\ColorAdapterClient.dll, version=10.0.19041.5129 (WinBuild.160101.0800) USERENV.dll C:\WINDOWS\SYSTEM32\USERENV.dll, version=10.0.19041.1 (WinBuild.160101.0800) icm32.dll C:\WINDOWS\SYSTEM32\icm32.dll, version=10.0.19041.5129 (WinBuild.160101.0800) PhotoSauce.MagicScaler.dll .\PhotoSauce.MagicScaler.dll, version=0.15.0.0 Cabinet.dll C:\WINDOWS\SYSTEM32\Cabinet.dll, version=5.00 (WinBuild.160101.0800) dwmapi.DLL C:\WINDOWS\SYSTEM32\dwmapi.DLL, version=10.0.19041.1 (WinBuild.160101.0800) dataexchange.dll C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.4355 (WinBuild.160101.0800) dcomp.dll C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.4597 (WinBuild.160101.0800) twinapi.appcore.dll C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.1 (WinBuild.160101.0800) textinputframework.dll C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.5072 (WinBuild.160101.0800) CoreUIComponents.dll C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.3636 ntmarta.dll C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.IO.Hashing.dll .\System.IO.Hashing.dll, version=9.0.24.52809 Newtonsoft.Json.dll .\Newtonsoft.Json.dll, version=13.0.3.27908 System.Linq.Expressions.dll .\System.Linq.Expressions.dll, version=9.0.24.52809 System.Text.RegularExpressions.dll .\System.Text.RegularExpressions.dll, version=9.0.24.52809 System.Runtime.Numerics.dll .\System.Runtime.Numerics.dll, version=9.0.24.52809 windowscodecsext.dll C:\WINDOWS\system32\windowscodecsext.dll, version=10.0.19041.3636 (WinBuild.160101.0800) PaintDotNet.SystemLayer.Native.x64.dll .\PaintDotNet.SystemLayer.Native.x64.dll, version=5.100.9082.35298 System.Runtime.Intrinsics.dll .\System.Runtime.Intrinsics.dll, version=9.0.24.52809 iphlpapi.dll C:\WINDOWS\SYSTEM32\iphlpapi.dll, version=10.0.19041.1 (WinBuild.160101.0800) DNSAPI.dll C:\WINDOWS\SYSTEM32\DNSAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800) NSI.dll C:\WINDOWS\System32\NSI.dll, version=10.0.19041.3636 (WinBuild.160101.0800) dhcpcsvc6.DLL C:\WINDOWS\SYSTEM32\dhcpcsvc6.DLL, version=10.0.19041.1 (WinBuild.160101.0800) dhcpcsvc.DLL C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL, version=10.0.19041.1 (WinBuild.160101.0800) WINNSI.DLL C:\WINDOWS\SYSTEM32\WINNSI.DLL, version=10.0.19041.3636 (WinBuild.160101.0800) winhttp.dll C:\WINDOWS\SYSTEM32\winhttp.dll, version=10.0.19041.3636 (WinBuild.160101.0800) System.Net.Sockets.dll .\System.Net.Sockets.dll, version=9.0.24.52809 mswsock.dll C:\WINDOWS\system32\mswsock.dll, version=10.0.19041.1 (WinBuild.160101.0800) wshunix.dll C:\WINDOWS\system32\wshunix.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Threading.Overlapped.dll .\System.Threading.Overlapped.dll, version=9.0.24.52809 System.Net.NameResolution.dll .\System.Net.NameResolution.dll, version=9.0.24.52809 mdnsNSP.dll C:\Program Files\Bonjour\mdnsNSP.dll, version=3,0,0,10 winrnr.dll C:\WINDOWS\System32\winrnr.dll, version=10.0.19041.3636 (WinBuild.160101.0800) rasadhlp.dll C:\Windows\System32\rasadhlp.dll, version=10.0.19041.3636 (WinBuild.160101.0800) napinsp.dll C:\WINDOWS\system32\napinsp.dll, version=10.0.19041.1 (WinBuild.160101.0800) wshbth.dll C:\WINDOWS\system32\wshbth.dll, version=10.0.19041.3636 (WinBuild.160101.0800) pnrpnsp.dll C:\WINDOWS\system32\pnrpnsp.dll, version=10.0.19041.1 (WinBuild.160101.0800) NLAapi.dll C:\WINDOWS\system32\NLAapi.dll, version=10.0.19041.4123 (WinBuild.160101.0800) fwpuclnt.dll C:\WINDOWS\System32\fwpuclnt.dll, version=10.0.19041.3636 (WinBuild.160101.0800) sspicli.dll C:\WINDOWS\SYSTEM32\sspicli.dll, version=10.0.19041.4239 (WinBuild.160101.0800) schannel.DLL C:\WINDOWS\system32\schannel.DLL, version=10.0.19041.1 (WinBuild.160101.0800) mskeyprotect.dll C:\WINDOWS\SYSTEM32\mskeyprotect.dll, version=10.0.19041.1 (WinBuild.160101.0800) NTASN1.dll C:\WINDOWS\SYSTEM32\NTASN1.dll, version=10.0.19041.1 (WinBuild.160101.0800) ncrypt.dll C:\WINDOWS\SYSTEM32\ncrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) ncryptsslp.dll C:\WINDOWS\system32\ncryptsslp.dll, version=10.0.19041.3636 (WinBuild.160101.0800) System.Reflection.MetadataLoadContext.dll .\System.Reflection.MetadataLoadContext.dll, version=9.0.24.52809 System.IO.Compression.dll .\System.IO.Compression.dll, version=9.0.24.52809 System.Diagnostics.Process.dll .\System.Diagnostics.Process.dll, version=9.0.24.52809 setupapi.DLL C:\WINDOWS\System32\setupapi.DLL, version=10.0.19041.1 (WinBuild.160101.0800) (this was copied after it crashed and I had to restart it.) Quote
BoltBait Posted Tuesday at 10:17 PM Posted Tuesday at 10:17 PM 17 minutes ago, Xiel said: Paint.NET 5.1 (Stable 5.100.9082.35298) A lot of work has been done in this area. Try using the latest Beta build and see if it fixes your problem: Quote Download: BoltBait's Plugin Pack | CodeLab | and a Free Computer Dominos Game
Rick Brewster Posted Tuesday at 11:22 PM Posted Tuesday at 11:22 PM In fact, there's an even newer build that I just posted (build 9103): Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html
