RalphV Posted September 29 Share Posted September 29 I am trying to create terrain like this. It's not the "horizontal lines", but the actual terrain texture in the same colors I like to do (all blue'ish or red'ish or...). I know there's the cool "Relief Map Generator" plugin from Ego Eram Reputo, but it's not doing what I want (or I am being dumb and not using it correctly). Thanks!!! Quote Link to comment Share on other sites More sharing options...
Solution Ego Eram Reputo Posted September 30 Solution Share Posted September 30 Hey @RalphV, Little known fact, my Planetoid plugin can render 2D maps in the colors of your choice. Once you have a suitable map, run Effects > Stylize > Relief over the layer to give your map some texture. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
RalphV Posted September 30 Author Share Posted September 30 Thanks a million. I will be playing a bit with Planetoid. Quote Link to comment Share on other sites More sharing options...
RalphV Posted October 1 Author Share Posted October 1 Damnation. I marked the wrong post as solution. Obviously, the post from Ego Eram Reputo contains the solution..... 1 Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted October 1 Share Posted October 1 1 hour ago, RalphV said: I marked the wrong post as solution. I've corrected this for you. 1 Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
