graffics Posted November 24, 2008 Share Posted November 24, 2008 whenever i try to feather this happens............ just an example... OH, and before you ask, YES i've downloaded BoltBait latest pack. Feather STILL does not work. Quote Link to comment Share on other sites More sharing options...
TopHATslash Posted November 24, 2008 Share Posted November 24, 2008 Next time, don't shout. It's breaking the rules. But for your feather problem, I don't know what's wrong. Maybe, the file got corrupted? Other then that I have no feedback, sorry. I know there are plenty of users who know much more then me, so just give it time and they will reply. Quote Link to comment Share on other sites More sharing options...
graffics Posted November 24, 2008 Author Share Posted November 24, 2008 apologys. im new, sorry if im bad in english. i am of italian. Quote Link to comment Share on other sites More sharing options...
BoltBait Posted November 24, 2008 Share Posted November 24, 2008 Show me a screenshot with the feather effect open. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
graffics Posted November 24, 2008 Author Share Posted November 24, 2008 Show me a screenshot with the feather effect open. Quote Link to comment Share on other sites More sharing options...
taboo Posted November 24, 2008 Share Posted November 24, 2008 actually, i have had the exact same problem for a long time - so i haven't used feather for months. :shock: Quote ... I should have been a pair of ragged claws ... - T.S. Eliot Taboo Monkey Blue Blog: Writing on Writing - Sudoku Tips and Tricks - The Greatest Maze Link to comment Share on other sites More sharing options...
BoltBait Posted November 24, 2008 Share Posted November 24, 2008 OK, there's your problem! You need to update your feather plugin. Go here: viewtopic.php?f=16&t=22819 and download the latest plugin pack. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
jake2k Posted November 24, 2008 Share Posted November 24, 2008 I've had the same effect with a couple of different effects for a while now but I don't use them too much so I never tried to figure out what was wrong. Is this what happens when a plugin isnt updated? Quote ^Click to visit my Flickr Gallery^ Link to comment Share on other sites More sharing options...
BoltBait Posted November 24, 2008 Share Posted November 24, 2008 Well, there was a bug in the template that I was using when creating plugins. So, several of my plugins had a bug. And, as it turns out, Tanel was using the same template, so several of his plugins have this problem as well. When Paint.NET 3.36 was released, Rick changed the way that plugins were called from within Paint.NET. Before, a plugin was always called with a 1px tall selection. Now, they are called with 2px tall selections. The problem with the template is that the second line never gets rendered. I fixed this issue in the template and published updates to all of my plugins. Just follow the link above (or the one in my sig) and update the plugins on your system. I have asked Rick to block my older plugins from loading on the next version of Paint.NET. So, update now and you won't be affected. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
