ami7878 Posted November 20, 2008 Share Posted November 20, 2008 Can an entire layer, including its properties, be copied to a different (new or existing) image? I'm talking about doing something similar to what can be done with sheets in MS-Excel. Thanks. Quote Link to comment Share on other sites More sharing options...
david.atwell Posted November 20, 2008 Share Posted November 20, 2008 Not automatically. But if you turn off the visibility on every other layer and save it as a .PNG, then import it into the other image, it will retain transparency. You'll still have to do blend mode manually, though. Quote The Doctor: There was a goblin, or a trickster, or a warrior... A nameless, terrible thing, soaked in the blood of a billion galaxies. The most feared being in all the cosmos. And nothing could stop it, or hold it, or reason with it. One day it would just drop out of the sky and tear down your world.Amy: But how did it end up in there?The Doctor: You know fairy tales. A good wizard tricked it.River Song: I hate good wizards in fairy tales; they always turn out to be him. Link to comment Share on other sites More sharing options...
PyroTechniques Posted November 20, 2008 Share Posted November 20, 2008 Or you can select the whole layer by using rectangle select, then hitting ctrl + c and pasting it into a new image/layer. Quote Photobucket Sucks! Link to comment Share on other sites More sharing options...
david.atwell Posted November 20, 2008 Share Posted November 20, 2008 I knew someone would say that. :-) Two problems: 1. It won't save transparency information. 2. Margin of error: you may not select the whole thing. If you're going to do it that way (that is, if you haven't changed the Transparency on the layer at all), you should use Ctrl+A to select all. But the way I posted in the original post is the only way to retain layer transparency data. Quote The Doctor: There was a goblin, or a trickster, or a warrior... A nameless, terrible thing, soaked in the blood of a billion galaxies. The most feared being in all the cosmos. And nothing could stop it, or hold it, or reason with it. One day it would just drop out of the sky and tear down your world.Amy: But how did it end up in there?The Doctor: You know fairy tales. A good wizard tricked it.River Song: I hate good wizards in fairy tales; they always turn out to be him. Link to comment Share on other sites More sharing options...
PyroTechniques Posted November 22, 2008 Share Posted November 22, 2008 I knew someone would say that. :-) Two problems:1. It won't save transparency information. It won't? *opens PDN and tries* Well, I'll be darned. It won't. But you could just look at the opacity number and set it to the same on the new layer... unless you're using BoltBait's Transparency plugin. Ah well. Another great idea shot down once again by the inestimable David.Atwell. (some day, I will come up with something you can't gainsay... ) Quote Photobucket Sucks! Link to comment Share on other sites More sharing options...
david.atwell Posted November 22, 2008 Share Posted November 22, 2008 (some day, I will come up with something you can't gainsay... ) Undoubtedly. :-) But not today. Quote The Doctor: There was a goblin, or a trickster, or a warrior... A nameless, terrible thing, soaked in the blood of a billion galaxies. The most feared being in all the cosmos. And nothing could stop it, or hold it, or reason with it. One day it would just drop out of the sky and tear down your world.Amy: But how did it end up in there?The Doctor: You know fairy tales. A good wizard tricked it.River Song: I hate good wizards in fairy tales; they always turn out to be him. Link to comment Share on other sites More sharing options...
