"Turn" Texture needs higher detail.. any ideas, comments?
Urnemanden
Well, if you're going for a pixeled look then I think it looks pretty good.
Edit: I forgot to add, the topic is kinda in the wrong section since this is for personal galleries and such. If you're looking for opinions/help on your work, then you might want to try the 'Image Hospital' which can be found at the top of 'The Pictorium'.
Yes, I'm a fan. ;]
Yea, that was kinda what i was looking for. Didn't know this was in the wrong section, since my other post i made here for textures was moved to the pictorium. Anyways.
Thank you for the nice comment Overkill! :)
Run some black and white clouds on a new layer, preferably slightly rough, apply a blend mode multiply on the layer, lower the opacity to something suitable, and you'll have a slightly aged Turn sign thingy. Or... Check this tut out: viewtopic.php?f=35&t=27092
Adapt it to your turn sign thingy and it'll be like loads of LED's showing the sign. You could even make it into an animated GIF if you want to. :wink:
☆★☆★Merry Christmas★☆★☆
