Help Needed: paint.net crashes when using selection tools
Go to solution Solved by rbersan,
Hello paint.net Community,
I'm reaching out for assistance regarding a persistent issue I'm encountering with paint.net on my Windows 11 Home x64 laptop. Whenever I use the selection tools (Rectangular or Lasso), the application crashes without displaying any error messages. I've performed a pdnrepair but the problem is still there.
I checked the Windows Event Viewer for details, which revealed the following error:
Quote
Faulting application name: PaintDotNet.exe
Faulting module name: HookTool64.dll
Exception code: 0xc00000fd
Fault offset: 0x000000000001146d
System Specifications:
- Operating System: Windows 11 Home x64 (10.0.22631.0)
- CPU: 11th Gen Intel(R) Core(TM) i7-1195G7
- Graphics Card: Intel(R) Iris(R) Xe Graphics
- .NET Version: 7.0.16 x64
- Paint.NET Version: 5.13.8830.42291
The crash occurs consistently whenever I use the Rectangular or Lasso selection tools.
I would greatly appreciate any guidance or solutions to resolve this issue. If anyone has encountered a similar problem or has suggestions for troubleshooting, please let me know. Your help would be invaluable in getting paint.net back to full functionality.
Thank you in advance for your assistance!
Best regards,
Riccardo
Could you start paint.net (don't use the selection tools) and go to :Settings: Settings -> Diagnostics -> Copy to clipboard and paste the text here.
Also click Open crash log folder and see whether there are any pdncrash.n.log files.  These are text files and the content can be emailed to the address shown on the first line of the file.
Your wording suggests that paint.net used to work correctly on your system. Do you have any idea what changed just prior to the problem starting?
You may have malware on your PC.
See Trojan.KeyLogger.43099   https://vms.drweb.com/virus/?i=23537722
I'd suggest doing a full scan using Defender (part of Windows) and/or installing a scanner such as Malwarebytes and seeing what that reports.
  • Upvote 2
The diagnostics info that @Tactilis requested will tell us where this file is, and that usually gives more information about what it is.
But, this is definitely not a Paint.NET bug -- HookTool64.dll is definitely the culprit.
Thank you for your kind answers.
Quote
Please find the output text in the last part of this message.
Quote
That folder is empty.
Quote
A scan with Defender reported no issue.
HookTool64.dll seems to be a Native module at path C:\Program Files\TrustView\HookTool64.dll
Should i remove it and reinstall Paint.NET?
Thank you
Application                                          paint.net 5.0.13 (Stable 5.13.8830.42291)
Build Date                                           Tuesday, 5 March, 2024
Install type                                         Classic
Language:                                            en-US
DPI                                                  1.25 (1.25x scale)
UI/Canvas GPU                                        False
Rendering GPU                                        Intel(R) Iris(R) Xe Graphics
Remote session                                       False
Animations                                           True
Translucent windows                                  True
Windows Ink                                          True
OS                                                   Windows 11 Home x64 (10.0.22631.0)
Runtime                                              .NET 7.0.16 x64
Physical Memory                                      16026 MB (3215 MB free)
Paging File                                          35482 MB (18232 MB free)
CPU                                                  11th Gen Intel(R) Core(TM) i7-1195G7 @ 2.90GHz
    Speed                                            ~2918 MHz
    Cores / Threads                                  4 / 8
    Features                                         SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2
Pointer                                              \??\Microsoft HID RID\000D_0002\1
    Type                                             IntegratedPen
    Contacts                                         1
    Cursors                                          Tip (10)
                                                     Eraser (11)
Monitor                                              1
    Resolution                                       1920 x 1080, 60 Hz
    DPI                                              120 (1.25x scale)
    Coordinates                                      (L=0, T=0, R=1920, B=1080)
    Bit depth                                        6
    Color space                                      RgbFullGamma22NoneP709
    Connected to                                     Intel(R) Iris(R) Xe Graphics
Monitor                                              2
    DPI                                              96 (1.00x scale)
    Coordinates                                      (L=-1920, T=-188, R=0, B=892)
    Bit depth                                        8
Video Card                                           Intel(R) Iris(R) Xe Graphics
    Hardware Acceleration                            Supported
    Dedicated Video RAM                              128 MB
    Dedicated System RAM                             0 MB
    Shared System RAM                                8013 MB
    Driver Version                                   31.0.101.4032
    Vendor ID                                        0x8086
    Device ID                                        0x9A49
    Subsystem ID                                     0x89BC103C
    Revision                                         3
    LUID                                             0x00010A00
    Flags                                            AcgCompatible, SupportMonitoredFences, KeyedMutexConformance
    Graphics Preemption                              PrimitiveBoundary
    Compute Preemption                               ThreadGroupBoundary
    Outputs                                          2
    Feature Level                                    Level_12_1
    Features                                         ComputeShadersEtc
    DXGI Formats                                     A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float
    Buffer Precisions                                UInt8Normalized, UInt8NormalizedSrgb, UInt16Normalized, Float16, Float32
    Maximum Bitmap Size                              16384
Video Card                                           Microsoft Basic Render Driver
    Hardware Acceleration                            N/A
    Dedicated Video RAM                              0 MB
    Driver Version                                   10.0.22621.2506
    Vendor ID                                        0x1414
    Device ID                                        0x008C
    Subsystem ID                                     0x00000000
    Revision                                         0
    LUID                                             0x00010D76
    Flags                                            Software, AcgCompatible, SupportMonitoredFences, KeyedMutexConformance
    Graphics Preemption                              InstructionBoundary
    Compute Preemption                               InstructionBoundary
    Outputs                                          0
    Features                                         Doubles, ComputeShadersEtc
    Maximum Bitmap Size                              8388608
Managed assemblies                                   94
    System.Private.CoreLib                           .\System.Private.CoreLib.dll, Version=7.0.0.0, PublicKeyToken=7cec85d7bea7798e
    paintdotnet                                      .\paintdotnet.dll, Version=5.13.8830.42291
    System.Runtime                                   .\System.Runtime.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Fundamentals                         .\PaintDotNet.Fundamentals.dll, Version=5.13.8830.42291
    System.Windows.Forms                             .\System.Windows.Forms.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Diagnostics.Tracing                       .\System.Diagnostics.Tracing.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Thread                          .\System.Threading.Thread.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Base                                 .\PaintDotNet.Base.dll, Version=5.13.8830.42291
    PaintDotNet.Collections                          .\PaintDotNet.Collections.dll, Version=5.13.8830.42291
    PaintDotNet.ComponentModel                       .\PaintDotNet.ComponentModel.dll, Version=5.13.8830.42291
    PaintDotNet.Windows                              .\PaintDotNet.Windows.dll, Version=5.13.8830.42291
    TerraFX.Interop.Windows                          .\TerraFX.Interop.Windows.dll, Version=10.0.22621.2, PublicKeyToken=35b01b53313a6f7e
    PaintDotNet.Primitives                           .\PaintDotNet.Primitives.dll, Version=5.13.8830.42291
    System.Collections.Concurrent                    .\System.Collections.Concurrent.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Runtime                              .\PaintDotNet.Runtime.dll, Version=5.13.8830.42291
    PointerToolkit                                   .\PointerToolkit.dll, Version=1.0.0.0
    System.Threading                                 .\System.Threading.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.SystemLayer                          .\PaintDotNet.SystemLayer.dll, Version=5.13.8830.42291
    PaintDotNet.Systrace                             .\PaintDotNet.Systrace.dll, Version=5.13.8830.42291
    System.Diagnostics.Process                       .\System.Diagnostics.Process.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Private.Uri                               .\System.Private.Uri.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel.Primitives                 .\System.ComponentModel.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    WindowsBase                                      .\WindowsBase.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.Windows.Forms.Primitives                  .\System.Windows.Forms.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    PaintDotNet.ObjectModel                          .\PaintDotNet.ObjectModel.dll, Version=5.13.8830.42291
    System.Runtime.InteropServices                   .\System.Runtime.InteropServices.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections                               .\System.Collections.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Drawing.Primitives                        .\System.Drawing.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Microsoft.Win32.Primitives                       .\Microsoft.Win32.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.TraceSource                   .\System.Diagnostics.TraceSource.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Configuration.ConfigurationManager        .\System.Configuration.ConfigurationManager.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Text.Encoding.CodePages                   .\System.Text.Encoding.CodePages.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.Specialized                   .\System.Collections.Specialized.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Core                                 .\PaintDotNet.Core.dll, Version=5.13.8830.42291
    System.Xml.ReaderWriter                          .\System.Xml.ReaderWriter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Resources                            .\PaintDotNet.Resources.dll, Version=5.13.8830.42291
    System.Private.Xml                               .\System.Private.Xml.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.ObjectModel                               .\System.ObjectModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Net.WebClient                             .\System.Net.WebClient.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    PaintDotNet.Data                                 .\PaintDotNet.Data.dll, Version=5.13.8830.42291
    System.ComponentModel.EventBasedAsync            .\System.ComponentModel.EventBasedAsync.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Framework                            .\PaintDotNet.Framework.dll, Version=5.13.8830.42291
    CommunityToolkit.HighPerformance                 .\CommunityToolkit.HighPerformance.dll, Version=8.2.0.0, PublicKeyToken=4aff67a105548ee2
    System.Memory                                    .\System.Memory.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Threading.ThreadPool                      .\System.Threading.ThreadPool.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Windows.Framework                    .\PaintDotNet.Windows.Framework.dll, Version=5.13.8830.42291
    System.Text.Encoding.Extensions                  .\System.Text.Encoding.Extensions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Drawing.Common                            .\System.Drawing.Common.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    Microsoft.Win32.SystemEvents                     .\Microsoft.Win32.SystemEvents.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Diagnostics.FileVersionInfo               .\System.Diagnostics.FileVersionInfo.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.UI                                   .\PaintDotNet.UI.dll, Version=5.13.8830.42291
    System.Linq                                      .\System.Linq.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.Immutable                     .\System.Collections.Immutable.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Microsoft.Win32.Registry                         .\Microsoft.Win32.Registry.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Principal.Windows                .\System.Security.Principal.Windows.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    ComputeSharp.D2D1                                .\ComputeSharp.D2D1.dll, Version=2.1.0.0, PublicKeyToken=dc35fa229f6881d8
    System.Security.Claims                           .\System.Security.Claims.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PresentationFramework                            .\PresentationFramework.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    PaintDotNet.Windows.Core                         .\PaintDotNet.Windows.Core.dll, Version=5.13.8830.42291
    PaintDotNet.PropertySystem                       .\PaintDotNet.PropertySystem.dll, Version=5.13.8830.42291
    System.ComponentModel.TypeConverter              .\System.ComponentModel.TypeConverter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel                            .\System.ComponentModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.Packaging                              .\System.IO.Packaging.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Effects.Core                         .\PaintDotNet.Effects.Core.dll, Version=5.13.8830.42291
    System.Xaml                                      .\System.Xaml.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    Accessibility                                    .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35
    PresentationCore                                 .\PresentationCore.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.Numerics.Vectors                          .\System.Numerics.Vectors.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    DirectWriteForwarder                             .\DirectWriteForwarder.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.Runtime.Extensions                        .\System.Runtime.Extensions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Tasks.Parallel                  .\System.Threading.Tasks.Parallel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.Debug                         .\System.Diagnostics.Debug.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Loader                            .\System.Runtime.Loader.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.CompilerServices.VisualC          .\System.Runtime.CompilerServices.VisualC.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.NonGeneric                    .\System.Collections.NonGeneric.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    DdsFileTypePlus                                  .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.12.8.0
    WebPFileType                                     .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.21.0
    PaintDotNet.Effects.Gpu                          .\PaintDotNet.Effects.Gpu.dll, Version=5.13.8830.42291
    AvifFileType                                     .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.30.0
    PaintDotNet.Effects                              .\PaintDotNet.Effects.dll, Version=5.13.8830.42291
    UIAutomationTypes                                .\UIAutomationTypes.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    PaintDotNet.Effects.Legacy                       .\PaintDotNet.Effects.Legacy.dll, Version=5.13.8830.42291
    System.IO.Hashing                                .\System.IO.Hashing.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Runtime.Serialization.Formatters          .\System.Runtime.Serialization.Formatters.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Newtonsoft.Json                                  .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed
    System.Text.RegularExpressions                   .\System.Text.RegularExpressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Linq.Expressions                          .\System.Linq.Expressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Numerics                          .\System.Runtime.Numerics.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Intrinsics                        .\System.Runtime.Intrinsics.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    PhotoSauce.MagicScaler                           .\PhotoSauce.MagicScaler.dll, Version=0.13.2.0, PublicKeyToken=fc6b9b7b06809481
    ComputeSharp.Core                                .\ComputeSharp.Core.dll, Version=2.1.0.0, PublicKeyToken=dc35fa229f6881d8
    PointerToolkit.TerraFX.Interop.Windows           .\PointerToolkit.TerraFX.Interop.Windows.dll, Version=10.0.22621.2
    System.Reflection.MetadataLoadContext            .\System.Reflection.MetadataLoadContext.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.IO.Compression                            .\System.IO.Compression.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
Native modules                                       195
    paintdotnet.exe                                  .\paintdotnet.exe, version=5.13.8830.42291
    ntdll.dll                                        C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    KERNEL32.DLL                                     C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.22621.3374 (WinBuild.160101.0800)
    KERNELBASE.dll                                   C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    SHELL32.dll                                      C:\WINDOWS\System32\SHELL32.dll, version=10.0.22621.2792 (WinBuild.160101.0800)
    msvcp_win.dll                                    C:\WINDOWS\System32\msvcp_win.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    ucrtbase.dll                                     C:\WINDOWS\System32\ucrtbase.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    USER32.dll                                       C:\WINDOWS\System32\USER32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    win32u.dll                                       C:\WINDOWS\System32\win32u.dll, version=10.0.22621.3447 (WinBuild.160101.0800)
    GDI32.dll                                        C:\WINDOWS\System32\GDI32.dll, version=10.0.22621.3085 (WinBuild.160101.0800)
    gdi32full.dll                                    C:\WINDOWS\System32\gdi32full.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    ole32.dll                                        C:\WINDOWS\System32\ole32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    combase.dll                                      C:\WINDOWS\System32\combase.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    RPCRT4.dll                                       C:\WINDOWS\System32\RPCRT4.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    OLEAUT32.dll                                     C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    SHLWAPI.dll                                      C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    msvcrt.dll                                       C:\WINDOWS\System32\msvcrt.dll, version=7.0.22621.2506 (WinBuild.160101.0800)
    VCRUNTIME140_1.dll                               .\VCRUNTIME140_1.dll, version=14.38.33135.0
    VCRUNTIME140.dll                                 .\VCRUNTIME140.dll, version=14.38.33135.0
    IMM32.DLL                                        C:\WINDOWS\System32\IMM32.DLL, version=10.0.22621.3374 (WinBuild.160101.0800)
    shcore.dll                                       C:\WINDOWS\System32\shcore.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    hostfxr.dll                                      .\hostfxr.dll, version=7,0,1624,6629 @Commit: 567edafe6106e6b769c64f6a2ed876190baa642a
    ADVAPI32.dll                                     C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    sechost.dll                                      C:\WINDOWS\System32\sechost.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    bcrypt.dll                                       C:\WINDOWS\System32\bcrypt.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    hostpolicy.dll                                   .\hostpolicy.dll, version=7,0,1624,6629 @Commit: 567edafe6106e6b769c64f6a2ed876190baa642a
    coreclr.dll                                      .\coreclr.dll, version=7,0,1624,6629 @Commit: 567edafe6106e6b769c64f6a2ed876190baa642a
    bcryptPrimitives.dll                             C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    System.Private.CoreLib.dll                       .\System.Private.CoreLib.dll, version=7.0.1624.6629
    clrjit.dll                                       .\clrjit.dll, version=7,0,1624,6629 @Commit: 567edafe6106e6b769c64f6a2ed876190baa642a
    kernel.appcore.dll                               C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.22621.2715 (WinBuild.160101.0800)
    paintdotnet.dll                                  .\paintdotnet.dll, version=5.13.8830.42291
    System.Runtime.dll                               .\System.Runtime.dll, version=7.0.1624.6629
    uxtheme.dll                                      C:\WINDOWS\system32\uxtheme.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    HookTool64.dll                                   C:\Program Files\TrustView\HookTool64.dll, version=4, 0, 23, 509
    WS2_32.dll                                       C:\WINDOWS\System32\WS2_32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    gdiplus.dll                                      C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.22621.3085_none_57ff6980ce140777\gdiplus.dll, version=10.0.22621.3085 (WinBuild.160101.0800)
    MSIMG32.dll                                      C:\WINDOWS\SYSTEM32\MSIMG32.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    WINHTTP.dll                                      C:\WINDOWS\SYSTEM32\WINHTTP.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    WININET.dll                                      C:\WINDOWS\SYSTEM32\WININET.dll, version=11.00.22621.1 (WinBuild.160101.0800)
    VERSION.dll                                      C:\WINDOWS\SYSTEM32\VERSION.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    TVCommonUtil.dll                                 C:\Program Files\TrustView\TVCommonUtil.dll, version=1, 0, 15, 1123
    IPHLPAPI.DLL                                     C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    CryptUtilDll.dll                                 C:\Program Files\TrustView\CryptUtilDll.dll, version=1, 0, 12, 0924
    dxgi.dll                                         C:\WINDOWS\SYSTEM32\dxgi.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    d3d11.dll                                        C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.22621.3235 (WinBuild.160101.0800)
    Magnification.dll                                C:\WINDOWS\SYSTEM32\Magnification.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    WTSAPI32.dll                                     C:\WINDOWS\SYSTEM32\WTSAPI32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    d3d9.dll                                         C:\WINDOWS\SYSTEM32\d3d9.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    dwmapi.dll                                       C:\WINDOWS\SYSTEM32\dwmapi.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    dxcore.dll                                       C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    PaintDotNet.Fundamentals.dll                     .\PaintDotNet.Fundamentals.dll, version=5.13.8830.42291
    System.Windows.Forms.dll                         .\System.Windows.Forms.dll, version=7.0.1624.6711
    System.Diagnostics.Tracing.dll                   .\System.Diagnostics.Tracing.dll, version=7.0.1624.6629
    icu.dll                                          C:\WINDOWS\SYSTEM32\icu.dll, version=68, 2, 0, 10 (WinBuild.160101.0800)
    System.Threading.Thread.dll                      .\System.Threading.Thread.dll, version=7.0.1624.6629
    PaintDotNet.Base.dll                             .\PaintDotNet.Base.dll, version=5.13.8830.42291
    PaintDotNet.Collections.dll                      .\PaintDotNet.Collections.dll, version=5.13.8830.42291
    PaintDotNet.ComponentModel.dll                   .\PaintDotNet.ComponentModel.dll, version=5.13.8830.42291
    PaintDotNet.Windows.dll                          .\PaintDotNet.Windows.dll, version=5.13.8830.42291
    TerraFX.Interop.Windows.dll                      .\TerraFX.Interop.Windows.dll, version=10.0.22621.2
    PaintDotNet.Primitives.dll                       .\PaintDotNet.Primitives.dll, version=5.13.8830.42291
    System.Collections.Concurrent.dll                .\System.Collections.Concurrent.dll, version=7.0.1624.6629
    PaintDotNet.Runtime.dll                          .\PaintDotNet.Runtime.dll, version=5.13.8830.42291
    PointerToolkit.dll                               .\PointerToolkit.dll, version=1.0.0.0
    System.Threading.dll                             .\System.Threading.dll, version=7.0.1624.6629
    PaintDotNet.SystemLayer.dll                      .\PaintDotNet.SystemLayer.dll, version=5.13.8830.42291
    PaintDotNet.Systrace.dll                         .\PaintDotNet.Systrace.dll, version=5.13.8830.42291
    System.Diagnostics.Process.dll                   .\System.Diagnostics.Process.dll, version=7.0.1624.6629
    System.Private.Uri.dll                           .\System.Private.Uri.dll, version=7.0.1624.6629
    System.ComponentModel.Primitives.dll             .\System.ComponentModel.Primitives.dll, version=7.0.1624.6629
    WindowsBase.dll                                  .\WindowsBase.dll, version=7.0.1624.6804
    System.Windows.Forms.Primitives.dll              .\System.Windows.Forms.Primitives.dll, version=7.0.1624.6711
    PaintDotNet.ObjectModel.dll                      .\PaintDotNet.ObjectModel.dll, version=5.13.8830.42291
    System.Runtime.InteropServices.dll               .\System.Runtime.InteropServices.dll, version=7.0.1624.6629
    System.Collections.dll                           .\System.Collections.dll, version=7.0.1624.6629
    System.Drawing.Primitives.dll                    .\System.Drawing.Primitives.dll, version=7.0.1624.6629
    Microsoft.Win32.Primitives.dll                   .\Microsoft.Win32.Primitives.dll, version=7.0.1624.6629
    PresentationNative_cor3.dll                      .\PresentationNative_cor3.dll, version=7,0,23,57101 @Commit: 562bdf3c1209b3703fde123c03fc9a2c86002f03
    System.Diagnostics.TraceSource.dll               .\System.Diagnostics.TraceSource.dll, version=7.0.1624.6629
    System.Configuration.ConfigurationManager.dll    .\System.Configuration.ConfigurationManager.dll, version=7.0.1624.6629
    System.Text.Encoding.CodePages.dll               .\System.Text.Encoding.CodePages.dll, version=7.0.1624.6629
    System.Collections.Specialized.dll               .\System.Collections.Specialized.dll, version=7.0.1624.6629
    PaintDotNet.Core.dll                             .\PaintDotNet.Core.dll, version=5.13.8830.42291
    System.Xml.ReaderWriter.dll                      .\System.Xml.ReaderWriter.dll, version=7.0.1624.6629
    PaintDotNet.Resources.dll                        .\PaintDotNet.Resources.dll, version=5.13.8830.42291
    System.Private.Xml.dll                           .\System.Private.Xml.dll, version=7.0.1624.6629
    System.ObjectModel.dll                           .\System.ObjectModel.dll, version=7.0.1624.6629
    System.Net.WebClient.dll                         .\System.Net.WebClient.dll, version=7.0.1624.6629
    PaintDotNet.Data.dll                             .\PaintDotNet.Data.dll, version=5.13.8830.42291
    System.ComponentModel.EventBasedAsync.dll        .\System.ComponentModel.EventBasedAsync.dll, version=7.0.1624.6629
    PaintDotNet.Framework.dll                        .\PaintDotNet.Framework.dll, version=5.13.8830.42291
    CommunityToolkit.HighPerformance.dll             .\CommunityToolkit.HighPerformance.dll, version=8.2.1.1
    System.Memory.dll                                .\System.Memory.dll, version=7.0.1624.6629
    System.Threading.ThreadPool.dll                  .\System.Threading.ThreadPool.dll, version=7.0.1624.6629
    directxdatabasehelper.dll                        C:\WINDOWS\SYSTEM32\directxdatabasehelper.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    windows.storage.dll                              C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    wintypes.dll                                     C:\WINDOWS\SYSTEM32\wintypes.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    profapi.dll                                      C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    PaintDotNet.Windows.Framework.dll                .\PaintDotNet.Windows.Framework.dll, version=5.13.8830.42291
    System.Text.Encoding.Extensions.dll              .\System.Text.Encoding.Extensions.dll, version=7.0.1624.6629
    System.Drawing.Common.dll                        .\System.Drawing.Common.dll, version=7.0.1624.6629
    Microsoft.Win32.SystemEvents.dll                 .\Microsoft.Win32.SystemEvents.dll, version=7.0.1624.6629
    MSCTF.dll                                        C:\WINDOWS\System32\MSCTF.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Diagnostics.FileVersionInfo.dll           .\System.Diagnostics.FileVersionInfo.dll, version=7.0.1624.6629
    PaintDotNet.UI.dll                               .\PaintDotNet.UI.dll, version=5.13.8830.42291
    System.Linq.dll                                  .\System.Linq.dll, version=7.0.1624.6629
    System.Collections.Immutable.dll                 .\System.Collections.Immutable.dll, version=7.0.1624.6629
    Microsoft.Win32.Registry.dll                     .\Microsoft.Win32.Registry.dll, version=7.0.1624.6629
    igd10iumd64.dll                                  C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_6e6a7f579616ad0a\igd10iumd64.dll, version=31.0.101.4032
    apphelp.dll                                      C:\WINDOWS\SYSTEM32\apphelp.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    igd10um64xe.DLL                                  C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_6e6a7f579616ad0a\igd10um64xe.DLL, version=31.0.101.4032
    CRYPT32.dll                                      C:\WINDOWS\System32\CRYPT32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    WINMM.dll                                        C:\WINDOWS\SYSTEM32\WINMM.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    ControlLib.dll                                   C:\WINDOWS\SYSTEM32\ControlLib.dll, version=1.0.178
    CFGMGR32.dll                                     C:\WINDOWS\SYSTEM32\CFGMGR32.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    IntelControlLib.dll                              C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_6e6a7f579616ad0a\IntelControlLib.dll, version=1.0.127
    SETUPAPI.dll                                     C:\WINDOWS\System32\SETUPAPI.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    DEVOBJ.dll                                       C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    WINTRUST.dll                                     C:\WINDOWS\System32\WINTRUST.dll, version=10.0.22621.3447 (WinBuild.160101.0800)
    MSASN1.dll                                       C:\WINDOWS\SYSTEM32\MSASN1.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    igdgmm64.dll                                     C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_6e6a7f579616ad0a\igdgmm64.dll, version=31.0.101.4032
    igc64.dll                                        C:\WINDOWS\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_6e6a7f579616ad0a\igc64.dll, version=31.0.101.4032
    System.Security.Principal.Windows.dll            .\System.Security.Principal.Windows.dll, version=7.0.1624.6629
    ComputeSharp.D2D1.dll                            .\ComputeSharp.D2D1.dll, version=2.1.0.0
    System.Security.Claims.dll                       .\System.Security.Claims.dll, version=7.0.1624.6629
    PresentationFramework.dll                        .\PresentationFramework.dll, version=7.0.1624.6804
    PaintDotNet.Windows.Core.dll                     .\PaintDotNet.Windows.Core.dll, version=5.13.8830.42291
    d2d1.DLL                                         C:\WINDOWS\SYSTEM32\d2d1.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    PaintDotNet.PropertySystem.dll                   .\PaintDotNet.PropertySystem.dll, version=5.13.8830.42291
    XmlLite.dll                                      C:\WINDOWS\SYSTEM32\XmlLite.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    WindowsCodecs.dll                                C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    System.ComponentModel.TypeConverter.dll          .\System.ComponentModel.TypeConverter.dll, version=7.0.1624.6629
    System.ComponentModel.dll                        .\System.ComponentModel.dll, version=7.0.1624.6629
    clbcatq.dll                                      C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800)
    UIAnimation.dll                                  C:\WINDOWS\System32\UIAnimation.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.IO.Packaging.dll                          .\System.IO.Packaging.dll, version=7.0.1624.6629
    PaintDotNet.Effects.Core.dll                     .\PaintDotNet.Effects.Core.dll, version=5.13.8830.42291
    dwrite.DLL                                       C:\WINDOWS\SYSTEM32\dwrite.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    comctl32.dll                                     C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.22621.3235_none_270f74e173860f98\comctl32.dll, version=6.10 (WinBuild.160101.0800)
    System.Xaml.dll                                  .\System.Xaml.dll, version=7.0.1624.6804
    Accessibility.dll                                .\Accessibility.dll, version=7.0.1624.6711
    PresentationCore.dll                             .\PresentationCore.dll, version=7.0.1624.6804
    System.Numerics.Vectors.dll                      .\System.Numerics.Vectors.dll, version=7.0.1624.6629
    DirectWriteForwarder.dll                         .\DirectWriteForwarder.dll, version=7,0,1624,6804 @Commit: 4a6accdbfd70e66399781c75b0c0a179f4b7e7eb
    System.Runtime.Extensions.dll                    .\System.Runtime.Extensions.dll, version=7.0.1624.6629
    TextShaping.dll                                  C:\WINDOWS\SYSTEM32\TextShaping.dll, version=10.0.22621.3085 (WinBuild.160101.0800)
    System.Threading.Tasks.Parallel.dll              .\System.Threading.Tasks.Parallel.dll, version=7.0.1624.6629
    mfplat.dll                                       C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    RTWorkQ.DLL                                      C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    CompPkgSup.DLL                                   C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.22621.3235 (WinBuild.160101.0800)
    Windows.StateRepositoryPS.dll                    C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    System.Diagnostics.Debug.dll                     .\System.Diagnostics.Debug.dll, version=7.0.1624.6629
    System.Runtime.Loader.dll                        .\System.Runtime.Loader.dll, version=7.0.1624.6629
    System.Runtime.CompilerServices.VisualC.dll      .\System.Runtime.CompilerServices.VisualC.dll, version=7.0.1624.6629
    System.Collections.NonGeneric.dll                .\System.Collections.NonGeneric.dll, version=7.0.1624.6629
    DdsFileTypePlus.dll                              .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.12.8.0
    WebPFileType.dll                                 .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.21.0
    PaintDotNet.Effects.Gpu.dll                      .\PaintDotNet.Effects.Gpu.dll, version=5.13.8830.42291
    AvifFileType.dll                                 .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.30.0
    PaintDotNet.Effects.dll                          .\PaintDotNet.Effects.dll, version=5.13.8830.42291
    WINSTA.dll                                       C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    UIAutomationTypes.dll                            .\UIAutomationTypes.dll, version=7.0.1624.6804
    D3D10Warp.dll                                    C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    UIAutomationCore.dll                             C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.22621.1 (WinBuild.160101.0800)
    PaintDotNet.Effects.Legacy.dll                   .\PaintDotNet.Effects.Legacy.dll, version=5.13.8830.42291
    dataexchange.dll                                 C:\WINDOWS\system32\dataexchange.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    twinapi.appcore.dll                              C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    textinputframework.dll                           C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.22621.3447 (WinBuild.160101.0800)
    Oleacc.dll                                       C:\WINDOWS\system32\Oleacc.dll, version=7.2.22621.1 (WinBuild.160101.0800)
    ApplicationTargetedFeatureDatabase.dll           C:\WINDOWS\system32\ApplicationTargetedFeatureDatabase.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    powrprof.dll                                     C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.22621.3374 (WinBuild.160101.0800)
    UMPDC.dll                                        C:\WINDOWS\SYSTEM32\UMPDC.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.IO.Hashing.dll                            .\System.IO.Hashing.dll, version=7.0.22.51805
    System.Runtime.Serialization.Formatters.dll      .\System.Runtime.Serialization.Formatters.dll, version=7.0.1624.6629
    Newtonsoft.Json.dll                              .\Newtonsoft.Json.dll, version=13.0.3.27908
    System.Text.RegularExpressions.dll               .\System.Text.RegularExpressions.dll, version=7.0.1624.6629
    System.Linq.Expressions.dll                      .\System.Linq.Expressions.dll, version=7.0.1624.6629
    System.Runtime.Numerics.dll                      .\System.Runtime.Numerics.dll, version=7.0.1624.6629
    PaintDotNet.SystemLayer.Native.x64.dll           .\PaintDotNet.SystemLayer.Native.x64.dll, version=5.13.8830.42291
    System.Runtime.Intrinsics.dll                    .\System.Runtime.Intrinsics.dll, version=7.0.1624.6629
    PhotoSauce.MagicScaler.dll                       .\PhotoSauce.MagicScaler.dll, version=0.13.2.0
    explorerframe.dll                                C:\WINDOWS\system32\explorerframe.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    PROPSYS.dll                                      C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.22621.2506 (WinBuild.160101.0800)
    ComputeSharp.Core.dll                            .\ComputeSharp.Core.dll, version=2.1.0.0
    d3dcompiler_47.DLL                               C:\WINDOWS\SYSTEM32\d3dcompiler_47.DLL, version=10.0.22621.2506 (WinBuild.160101.0800)
    CRYPTSP.dll                                      C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.22621.2506 (WinBuild.160101.0800)
    Cabinet.dll                                      C:\WINDOWS\SYSTEM32\Cabinet.dll, version=5.00 (WinBuild.160101.0800)
    dcomp.dll                                        C:\WINDOWS\SYSTEM32\dcomp.dll, version=10.0.22621.3447 (WinBuild.160101.0800)
    PointerToolkit.TerraFX.Interop.Windows.dll       .\PointerToolkit.TerraFX.Interop.Windows.dll, version=10.0.22621.2
    CoreMessaging.dll                                C:\WINDOWS\SYSTEM32\CoreMessaging.dll, version=10.0.22621.3085 (WinBuild.160101.0800)
    CoreUIComponents.dll                             C:\WINDOWS\SYSTEM32\CoreUIComponents.dll, version=10.0.22621.2506
    CRYPTBASE.DLL                                    C:\WINDOWS\SYSTEM32\CRYPTBASE.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Reflection.MetadataLoadContext.dll        .\System.Reflection.MetadataLoadContext.dll, version=7.0.22.51805
    System.IO.Compression.dll                        .\System.IO.Compression.dll, version=7.0.1624.6629
  • Solution
[SOLVED]
Hello,
after receiving guidance from this forum, I took the following step to troubleshoot the problem:
Removed TrustView from Startup
> I removed the TrustView application from the Windows 11 Startup list via Settings > Apps > Startup, and then rebooted my laptop.
I'm pleased to report that after performing this step, the issue with paint.net seems to be completely resolved! I can now use the selection tools without any crashes.
If anyone else encounters a similar issue with paint.net, I recommend checking your system's startup applications and removing any potentially conflicting software.
I want to extend my sincere thanks to @Tactilis and @Rick Brewster who offered kind suggestions and support during this troubleshooting process.
Thank you once again for your help and expertise!
  • Upvote 3
