Posted
Can I specify a color or layer to be transparent when creating a gif? So when added to an html page the original background.gif or color shows through.
Ann-Marie
Posted
If you'd like an area to be transparent, all you have to do is remove the background in that area. Anywhere you see the little grey checkerboard pattern will be transparent when the image is saved in a format that supports transparency, such as .png or .gif.
If the image already has one color where you need the transparency to be, you can use the Magic Wand tool to select just that color and delete it.
Hope that answers your question! :)
Dan
~ Becoming the Archetype
Posted
You must select the color (while holding shift with the magic wand tool), wich should be transparent and delete it, if you open a gif. Then save it again and you'll have got a transparency in the picture!
Greets
Flo
