Tut request: sound wave
zvaragabor
Sound is a series of compression waves that moves through air or other materials.These sound waves are created by the vibration of some object, like a radio loudspeaker.
Creating sound
Whenever an object in air vibrates,it causes compression waves in the air.These waves move away from the object as sound.There are many forms of the vibration,some not so obvious.Sound can also be created by vibrating an object in a liquid such as water or in a solid such as iron. A train rolling on a steel railroad track will create a sound wave that travels through the tracks.They will then vibrate,creating sound in air that you can hear,while the train may be a great distance away.
joycelorenza
Influencer
not enough for a tut so quick walk thru
open new picture
bucket fill the page with black
add a transparent layer
change your primary color to white
use the plug in sin curves viewtopic.php?f=16&t=22085&hilit=Sine if you have
or
the one called equations viewtopic.php?f=16&t=22521&hilit=equations with in this one you will have to set the color inside the plugin.
I seldom use it so not sure how to set the black line curve to white. you may end up just wanding that and bucketfilling with white.
use the jitter plug in by Pyrochild (if you don't have this download his pkg. an excellent well written set of plugins.)
and then motion blur.
merge the layers together
