Print UI leaves behind stuck processes
Go to solution Solved by Rick Brewster,
Probably not a very meaningful bug at all, but figured I'd report it anyway just in case it has other side effects under the hood.
If the print UI is closed too quickly, the paintdotnet.exe child process it spawns gets stuck and doesn't close on its own, or even after closing the program itself. It sticks around in the process list doing nothing but consuming a few MB of memory.
This seems to happen reliably if you press control-P and immediately hit esc (I blame my "press control-P to adjust CodeLab effect settings" reflex, even when CodeLab isn't open). If the print window is given a couple seconds to "settle", the process it spawns closes normally.
Diagnostics, just in case:
Spoiler
Application                                                paint.net 5.0.11 (Stable 5.11.8685.3093)
Build Date                                                 torstai 12. lokakuuta 2023
Install type                                               Classic
Language:                                                  en-US
DPI                                                        1.25 (1.25x scale)
UI/Canvas GPU                                              True
Rendering GPU                                              🚀 Performance (NVIDIA GeForce RTX 3080)
Remote session                                             False
Animations                                                 True
Translucent windows                                        True
Windows Ink                                                False
OS                                                         Windows 11 Home x64 (10.0.22621.0)
Runtime                                                    .NET 7.0.12 x64
Physical Memory                                            32 509 MB (19 031 MB free)
Paging File                                                35 578 MB (12 919 MB free)
CPU                                                        13th Gen Intel(R) Core(TM) i7-13700K
    Speed                                                  ~3418 MHz
    Cores / Threads                                        16 / 24
    Features                                               SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2
Monitor                                                    1
    Resolution                                             1920 x 1080, 60 Hz
    DPI                                                    120 (1.25x scale)
    Coordinates                                            (L=0, T=0, R=1920, B=1080)
    Bit depth                                              10
    Color space                                            RgbFullGamma22NoneP709
    Connected to                                           NVIDIA GeForce RTX 3080
Video Card                                                 NVIDIA GeForce RTX 3080
    Hardware Acceleration                                  Supported
    Dedicated Video RAM                                    10 067 MB
    Dedicated System RAM                                   0 MB
    Shared System RAM                                      16 254 MB
    Vendor ID                                              0x10DE
    Device ID                                              0x2216
    Subsystem ID                                           0x88221043
    Revision                                               161
    LUID                                                   0x00011239
    Flags                                                  AcgCompatible, SupportMonitoredFences, KeyedMutexConformance
    Graphics Preemption                                    PixelBoundary
    Compute Preemption                                     DispatchBoundary
    Outputs                                                1
    Feature Level                                          Level_12_1
    Features                                               Doubles, ComputeShadersEtc
    DXGI Formats                                           A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float
    Buffer Precisions                                      UInt8Normalized, UInt8NormalizedSrgb, UInt16Normalized, Float16, Float32
    Maximum Bitmap Size                                    16384
Video Card                                                 Microsoft Basic Render Driver
    Hardware Acceleration                                  N/A
    Dedicated Video RAM                                    0 MB
    Vendor ID                                              0x1414
    Device ID                                              0x008C
    Subsystem ID                                           0x00000000
    Revision                                               0
    LUID                                                   0x0001204D
    Flags                                                  Software, AcgCompatible, SupportMonitoredFences, KeyedMutexConformance
    Graphics Preemption                                    InstructionBoundary
    Compute Preemption                                     InstructionBoundary
    Outputs                                                0
    Maximum Bitmap Size                                    8388608
Managed assemblies                                         291
    System.Private.CoreLib                                 .\System.Private.CoreLib.dll, Version=7.0.0.0, PublicKeyToken=7cec85d7bea7798e
    paintdotnet                                            .\paintdotnet.dll, Version=5.11.8685.3093
    System.Runtime                                         .\System.Runtime.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Windows.Forms                                   .\System.Windows.Forms.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    PaintDotNet.Fundamentals                               .\PaintDotNet.Fundamentals.dll, Version=5.11.8685.3093
    System.Diagnostics.Tracing                             .\System.Diagnostics.Tracing.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Thread                                .\System.Threading.Thread.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Base                                       .\PaintDotNet.Base.dll, Version=5.11.8685.3093
    PaintDotNet.Collections                                .\PaintDotNet.Collections.dll, Version=5.11.8685.3093
    PaintDotNet.ComponentModel                             .\PaintDotNet.ComponentModel.dll, Version=5.11.8685.3093
    PaintDotNet.Windows                                    .\PaintDotNet.Windows.dll, Version=5.11.8685.3093
    TerraFX.Interop.Windows                                .\TerraFX.Interop.Windows.dll, Version=10.0.22621.2, PublicKeyToken=35b01b53313a6f7e
    PaintDotNet.Primitives                                 .\PaintDotNet.Primitives.dll, Version=5.11.8685.3093
    System.Collections.Concurrent                          .\System.Collections.Concurrent.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Runtime                                    .\PaintDotNet.Runtime.dll, Version=5.11.8685.3093
    PointerToolkit                                         .\PointerToolkit.dll, Version=1.0.0.0
    System.Threading                                       .\System.Threading.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.SystemLayer                                .\PaintDotNet.SystemLayer.dll, Version=5.11.8685.3093
    PaintDotNet.Systrace                                   .\PaintDotNet.Systrace.dll, Version=5.11.8685.3093
    System.Diagnostics.Process                             .\System.Diagnostics.Process.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Private.Uri                                     .\System.Private.Uri.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel.Primitives                       .\System.ComponentModel.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Windows.Forms.Primitives                        .\System.Windows.Forms.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    WindowsBase                                            .\WindowsBase.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    PaintDotNet.ObjectModel                                .\PaintDotNet.ObjectModel.dll, Version=5.11.8685.3093
    System.Runtime.InteropServices                         .\System.Runtime.InteropServices.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Drawing.Primitives                              .\System.Drawing.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections                                     .\System.Collections.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.TraceSource                         .\System.Diagnostics.TraceSource.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Microsoft.Win32.Primitives                             .\Microsoft.Win32.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Text.Encoding.CodePages                         .\System.Text.Encoding.CodePages.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Core                                       .\PaintDotNet.Core.dll, Version=5.11.8685.3093
    PaintDotNet.Resources                                  .\PaintDotNet.Resources.dll, Version=5.11.8685.3093
    System.ObjectModel                                     .\System.ObjectModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Data                                       .\PaintDotNet.Data.dll, Version=5.11.8685.3093
    PaintDotNet.Framework                                  .\PaintDotNet.Framework.dll, Version=5.11.8685.3093
    CommunityToolkit.HighPerformance                       .\CommunityToolkit.HighPerformance.dll, Version=8.2.0.0, PublicKeyToken=4aff67a105548ee2
    System.Threading.ThreadPool                            .\System.Threading.ThreadPool.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.Immutable                           .\System.Collections.Immutable.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Windows.Framework                          .\PaintDotNet.Windows.Framework.dll, Version=5.11.8685.3093
    System.Configuration.ConfigurationManager              .\System.Configuration.ConfigurationManager.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Collections.Specialized                         .\System.Collections.Specialized.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Drawing.Common                                  .\System.Drawing.Common.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    PaintDotNet.UI                                         .\PaintDotNet.UI.dll, Version=5.11.8685.3093
    System.Xml.ReaderWriter                                .\System.Xml.ReaderWriter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Private.Xml                                     .\System.Private.Xml.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Net.WebClient                                   .\System.Net.WebClient.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.ComponentModel.EventBasedAsync                  .\System.ComponentModel.EventBasedAsync.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Memory                                          .\System.Memory.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    Microsoft.Win32.SystemEvents                           .\Microsoft.Win32.SystemEvents.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Text.Encoding.Extensions                        .\System.Text.Encoding.Extensions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Linq                                            .\System.Linq.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.FileVersionInfo                     .\System.Diagnostics.FileVersionInfo.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Microsoft.Win32.Registry                               .\Microsoft.Win32.Registry.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Principal.Windows                      .\System.Security.Principal.Windows.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Claims                                 .\System.Security.Claims.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Windows.Core                               .\PaintDotNet.Windows.Core.dll, Version=5.11.8685.3093
    System.ComponentModel                                  .\System.ComponentModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    ComputeSharp.D2D1                                      .\ComputeSharp.D2D1.dll, Version=2.1.0.0, PublicKeyToken=dc35fa229f6881d8
    PresentationFramework                                  .\PresentationFramework.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    PaintDotNet.PropertySystem                             .\PaintDotNet.PropertySystem.dll, Version=5.11.8685.3093
    System.ComponentModel.TypeConverter                    .\System.ComponentModel.TypeConverter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Xaml                                            .\System.Xaml.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    PaintDotNet.Effects.Core                               .\PaintDotNet.Effects.Core.dll, Version=5.11.8685.3093
    System.IO.Packaging                                    .\System.IO.Packaging.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PresentationCore                                       .\PresentationCore.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    DirectWriteForwarder                                   .\DirectWriteForwarder.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.Runtime.Extensions                              .\System.Runtime.Extensions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.Debug                               .\System.Diagnostics.Debug.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.CompilerServices.VisualC                .\System.Runtime.CompilerServices.VisualC.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.NonGeneric                          .\System.Collections.NonGeneric.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Accessibility                                          .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35
    UIAutomationTypes                                      .\UIAutomationTypes.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.IO.Hashing                                      .\System.IO.Hashing.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    PaintDotNet.Effects.Gpu                                .\PaintDotNet.Effects.Gpu.dll, Version=5.11.8685.3093
    PaintDotNet.Effects                                    .\PaintDotNet.Effects.dll, Version=5.11.8685.3093
    System.Threading.Tasks.Parallel                        .\System.Threading.Tasks.Parallel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Reflection.Metadata                             .\System.Reflection.Metadata.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.MemoryMappedFiles                            .\System.IO.MemoryMappedFiles.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Reflection.MetadataLoadContext                  .\System.Reflection.MetadataLoadContext.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Numerics.Vectors                                .\System.Numerics.Vectors.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Loader                                  .\System.Runtime.Loader.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    CSVFiletype                                            .\FileTypes\CSVFiletype.dll, Version=1.0.0.0
    PhotoShop                                              .\FileTypes\PhotoShop.dll, Version=2.5.0.40665
    Jpeg2000Filetype                                       .\FileTypes\Jpeg2000Filetype.dll, Version=1.0.0.6
    ImXcf.FileType                                         .\FileTypes\ImXCF.FileType.dll, Version=1.4.0.95
    OptiPngFileType                                        .\FileTypes\OptiPngFileType.dll, Version=8.11.30.0
    IcoCur                                                 .\FileTypes\IcoCur.dll, Version=3.7.0.0
    ImAGIF.FileType                                        .\FileTypes\ImAGIF.FileType.dll, Version=1.4.0.0
    ImAPNG.FileType                                        .\FileTypes\ImAPNG.FileType.dll, Version=0.3.0.19
    mscorlib                                               .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    System                                                 .\System.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Drawing                                         .\System.Drawing.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.FileSystem                                   .\System.IO.FileSystem.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    AvifFileType                                           .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.26.0
    WebPFileType                                           .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.20.0
    DdsFileTypePlus                                        .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.12.8.0
    Mono.Cecil                                             .\Mono.Cecil.dll, Version=0.11.5.0, PublicKeyToken=50cebf1cceb9d05e
    netstandard                                            .\netstandard.dll, Version=2.1.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    PaintDotNet.Effects.Legacy                             .\PaintDotNet.Effects.Legacy.dll, Version=5.11.8685.3093
    PaintDotNet.Plugins.Compatibility                      .\PaintDotNet.Plugins.Compatibility.dll, Version=5.11.8685.3093
    System.Console                                         .\System.Console.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    CalliColour                                            .\Effects\CalliColour.dll, Version=1.0.1.0
    AA's_Assistant                                         .\Effects\AA's_Assistant.dll, Version=1.1.4329.33034
    AlphaToDots                                            .\Effects\AlphaToDots.dll, Version=1.0.4675.19955
    AlphaBlur                                              .\Effects\AlphaBlur.dll, Version=2.0.0.0
    AverageEdgeBlur                                        .\Effects\AverageEdgeBlur.dll, Version=1.0.3991.32409
    AveragedColorBlur                                      .\Effects\AveragedColorBlur.dll, Version=1.0.0.0
    BandWPlus                                              .\Effects\BandWPlus.dll, Version=6.0.8407.21940
    Alphalizer                                             .\Effects\Alphalizer.dll, Version=2.0.5434.24240
    BasicPhotoAdjustments                                  .\Effects\BasicPhotoAdjustments.dll, Version=2.1.4020.485
    CellTexture                                            .\Effects\CellTexture.dll, Version=1.1.0.0
    Bars                                                   .\Effects\Bars.dll, Version=1.1.0.0
    BlendModesPlus                                         .\Effects\BlendModesPlus.dll, Version=3.1.0.0
    BBOutlinedGradientText                                 .\Effects\BBOutlinedGradientText.dll, Version=6.0.8426.37652
    BoldBrush                                              .\Effects\BoldBrush.dll, Version=2.0.8470.26873
    Bidirectional Blur                                     .\Effects\Bidirectional Blur.dll, Version=1.0.0.0
    CircleText                                             .\Effects\CircleText.dll, Version=1.4.4415.32488
    ClipWarpNew                                            .\Effects\ClipWarpNew.dll, Version=1.0.1.0
    ClipDisplace                                           .\Effects\ClipDisplace.dll, Version=1.0.5763.42010
    Cobweb                                                 .\Effects\Cobweb.dll, Version=1.0.1.0
    coloraberation                                         .\Effects\coloraberation.dll, Version=1.0.3859.18981
    System.Runtime.Serialization.Formatters                .\System.Runtime.Serialization.Formatters.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    ColorBalance                                           .\Effects\ColorBalance.dll, Version=6.0.8407.22111
    ColorCount                                             .\Effects\ColorCount.dll, Version=1.0.0.0
    CodeLab                                                .\Effects\CodeLab.dll, Version=6.10.8685.36729
    voronoi.dll                                            .\Effects\voronoi.dll, Version=1.0.0.0
    ColorZoomBlur                                          .\Effects\ColorZoomBlur.dll, Version=1.1.3873.36417
    ColorMixer                                             .\Effects\ColorMixer.dll, Version=1.3.0.0
    Contour                                                .\Effects\Contour.dll, Version=1.0.1.0
    VignettePlus                                           .\Effects\VignettePlus.dll, Version=6.0.8407.22549
    ConvolutionEffect                                      .\Effects\ConvolutionEffect.dll, Version=1.0.0.2
    ContentAwareFill                                       .\Effects\ContentAwareFill.dll, Version=1.5.1.0
    CreativeTextPro                                        .\Effects\CreativeTextPro.dll, Version=6.0.8407.22165
    Cuboids                                                .\Effects\Cuboids.dll, Version=1.0.0.0
    CycleHSV                                               .\Effects\CycleHSV.dll, Version=1.0.4909.35068
    dpyColorBalance                                        .\Effects\dpyColorBalance.dll, Version=1.1.4330.37850
    Diffuse                                                .\Effects\Diffuse.dll, Version=1.0.3254.27766
    Curves+                                                .\Effects\Curves+.dll, Version=4.0.6119.31044
    Dryad                                                  .\Effects\Dryad.dll, Version=1.0.1.0
    Dream                                                  .\Effects\Dream.dll, Version=6.0.8414.36727
    DistortThis                                            .\Effects\DistortThis.dll, Version=2.10.0.0
    Edge Shader                                            .\Effects\Edge Shader.dll, Version=1.0.1.0
    EdHarvey.Edfects                                       .\Effects\EdHarvey.Edfects.dll, Version=5.0.0.0
    velc.SlabText                                          .\Effects\velc.SlabText.dll, Version=1.1.8174.32156
    AlphaMask                                              .\Effects\AlphaMask.dll, Version=2.0.3574.41943
    EigenBlur                                              .\Effects\EigenBlur.dll, Version=1.3.3555.24648
    EOEffects                                              .\Effects\EOEffects.dll, Version=1.10.16.12
    Erode                                                  .\Effects\Erode.dll, Version=1.0.0.0
    Facet                                                  .\Effects\Facet.dll, Version=1.0.3.0
    ErodeDilate                                            .\Effects\ErodeDilate_v0.2.dll, Version=1.0.0.0
    FillFromClipboard                                      .\Effects\FillFromClipboard.dll, Version=6.0.8407.22397
    FindEdges                                              .\Effects\FindEdges.dll, Version=1.2.0.0
    FloydSteinbergDithering                                .\Effects\FloydSteinbergDithering.dll, Version=5.2.8174.39918
    Flip                                                   .\Effects\Flip.dll, Version=4.6.7358.36953
    FurBlur                                                .\Effects\FurBlur.dll, Version=1.0.1.0
    F_AdjustHSLuv                                          .\Effects\F_AdjustHSLuv.dll, Version=1.0.8717.41948
    F_ColorVectorCross                                     .\Effects\F_ColorVectorCross.dll, Version=1.2.8710.30670
    F_ColorVectorRotation                                  .\Effects\F_ColorVectorRotation.dll, Version=1.2.8710.28036
    F_FastAlpha2Gray                                       .\Effects\F_FastAlpha2Gray.dll, Version=1.0.8716.30768
    F_ColorVectorRotationAxAng                             .\Effects\F_ColorVectorRotationAxAng.dll, Version=1.2.8710.27976
    F_FastAlphaRemove                                      .\Effects\F_FastAlphaRemove.dll, Version=1.0.8716.30758
    Vandermotten.PaintDotNetEffects.ObjectAlign            .\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, Version=5.0.0.0
    F_FastClipboard2AlphaMultiply                          .\Effects\F_FastClipboard2AlphaMultiply.dll, Version=1.0.8716.34503
    F_FastClipboard2AlphaOverwrite                         .\Effects\F_FastClipboard2AlphaOverwrite.dll, Version=1.0.8716.34508
    Vandermotten.PaintDotNetEffects                        .\Effects\Vandermotten.PaintDotNetEffects.dll, Version=5.0.0.0
    F_FastGray2AlphaPrimary                                .\Effects\F_FastGray2AlphaPrimary.dll, Version=1.0.8716.30765
    F_FastGray2AlphaRetain                                 .\Effects\F_FastGray2AlphaRetain.dll, Version=1.0.8716.30762
    F_SeamlessSimplexClouds                                .\Effects\F_SeamlessSimplexClouds.dll, Version=1.0.8713.9300
    F_SeamlessVoronoi                                      .\Effects\F_SeamlessVoronoi.dll, Version=1.0.8715.42222
    GaussianBlurPlus                                       .\Effects\GaussianBlurPlus.dll, Version=4.2.5691.27401
    Gossamer                                               .\Effects\Gossamer.dll, Version=1.0.1.0
    Gmic                                                   .\Effects\Gmic.dll, Version=3.3.2.0
    Gradient Bars                                          .\Effects\Gradient Bars.dll, Version=4.0.5152.23084
    Gradient Blocks                                        .\Effects\Gradient Blocks.dll, Version=4.0.4642.26658
    GradientBlur                                           .\Effects\Gradient Blur.dll, Version=1.0.0.0
    Grain                                                  .\Effects\Grain.dll, Version=1.0.3854.25523
    GridMaker                                              .\Effects\GridMaker.dll, Version=4.0.0.0
    Helix                                                  .\Effects\Helix.dll, Version=1.0.1.0
    System.Net.Http                                        .\System.Net.Http.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    HexaGrid                                               .\Effects\HexaGrid.dll, Version=1.2.0.0
    Grid Warp                                              .\Effects\Grid Warp.dll, Version=4.0.6544.34496
    HueSatPlus                                             .\Effects\HueSatPlus.dll, Version=5.2.8174.40274
    System.Net.Primitives                                  .\System.Net.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    IrisBlur                                               .\Effects\IrisBlur.dll, Version=1.0.8690.21381
    IncreaseLocalContrast                                  .\Effects\IncreaseLocalContrast.dll, Version=1.0.0.0
    Jitter                                                 .\Effects\Jitter.dll, Version=4.0.4642.26986
    Kuwahara                                               .\Effects\Kuwahara.dll, Version=1.0.0.0
    kb_lens                                                .\Effects\kb_lens.dll, Version=0.0.0.0
    System.Core                                            .\System.Core.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    Line Tracer                                            .\Effects\Line Tracer.dll, Version=1.0.4911.29141
    LavEnt.Effects.Mosaic                                  .\Effects\LavEnt.Effects.Mosaic.dll, Version=1.1.0.0
    LaplacianPyramidFilter                                 .\Effects\LaplacianPyramidFilter.dll, Version=1.0.0.1
    LocalContrast                                          .\Effects\LocalContrast.dll, Version=3.0.0.0
    Liquify                                                .\Effects\Liquify.dll, Version=4.0.5873.25113
    LocalNoise                                             .\Effects\LocalNoise.dll, Version=1.0.4674.29909
    Magnifier                                              .\Effects\Magnifier.dll, Version=1.1.0.0
    MirrorRotateMenu                                       .\Effects\MirrorRotateMenu.dll, Version=2.0.2.0
    Morphologic                                            .\Effects\Morphologic.dll, Version=1.0.0.0
    MultiSpline                                            .\Effects\MultiSpline.dll, Version=1.0.3.0
    NoiseChoice                                            .\Effects\NoiseChoice.dll, Version=1.0.1.0
    Norm_Render                                            .\Effects\Norm_Render.dll, Version=7.3.4484.27012
    ObjectBevel                                            .\Effects\ObjectBevel.dll, Version=1.0.6.0
    System.Resources.Extensions                            .\System.Resources.Extensions.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    ObjectEdge                                             .\Effects\Objectedge.dll, Version=1.0.1.0
    ObjectTools                                            .\Effects\ObjectTools.dll, Version=6.0.8428.8314
    Oblique                                                .\Effects\Oblique.dll, Version=1.0.0.0
    IniFile                                                .\Effects\IniFile.dll, Version=2.0.2.0
    Panelling                                              .\Effects\Panelling.dll, Version=1.1.0.0
    OilPaintingPlus                                        .\Effects\OilPaintingPlus.dll, Version=5.2.8141.27893
    PasteFill                                              .\Effects\PasteFill.dll, Version=2.0.0.0
    Pastel                                                 .\Effects\Pastel.dll, Version=5.2.8174.40506
    Perspective                                            .\Effects\Perspective.dll, Version=2.1.4415.36116
    phips_fill_gaps                                        .\Effects\phips_fill_gaps.dll, Version=1.0.3307.18956
    PhotoAdjustments                                       .\Effects\PhotoAdjustments.dll, Version=6.0.8416.38377
    Pixelate+                                              .\Effects\Pixelate+.dll, Version=4.0.4642.26940
    PointBlur                                              .\Effects\PointBlur.dll, Version=1.0.0.0
    Polar                                                  .\Effects\Polar.dll, Version=1.1.1.0
    QuadrilateralCorrection                                .\Effects\QuadrilateralCorrection.dll, Version=1.3.0.0
    RandLines                                              .\Effects\Random lines.dll, Version=1.1.0.0
    QuantDith                                              .\Effects\QuantDith.dll, Version=1.5.8260.29377
    RandMaze1                                              .\Effects\Random Maze1.dll, Version=1.1.0.0
    Random Shape Fill                                      .\Effects\Random Shape Fill.dll, Version=4.0.4642.26910
    RemoveDust                                             .\Effects\RemoveDust.dll, Version=6.0.8407.22513
    RandMaze2                                              .\Effects\Random Maze2.dll, Version=1.1.0.0
    RGB_Remap4                                             .\Effects\RGB_Remap4.dll, Version=1.0.3538.24311
    Rosaces                                                .\Effects\Rosaces.dll, Version=1.1.0.0
    Scribble                                               .\Effects\Scribble.dll, Version=1.0.1.0
    SeamCarving                                            .\Effects\SeamCarving.dll, Version=5.2.8176.39366
    PSFilterPdn                                            .\Effects\PSFilterPdn\PSFilterPdn.dll, Version=2.0.6.0
    Selection2Clear                                        .\Effects\Selection2Clear.dll, Version=1.0.1.0
    SelectionTools                                         .\Effects\SelectionTools.dll, Version=6.0.8412.38725
    Sharpen+                                               .\Effects\Sharpen+.dll, Version=4.0.0.0
    SinWaves                                               .\Effects\SinWaves.dll, Version=1.1.0.0
    Slinky                                                 .\Effects\Slinky.dll, Version=1.0.1.0
    Smudge                                                 .\Effects\Smudge.dll, Version=4.0.5873.25097
    silhouetteplus                                         .\Effects\silhouetteplus.dll, Version=1.1.3131.17586
    Splashes                                               .\Effects\Splashes.dll, Version=1.1.1.0
    Splatter                                               .\Effects\Splatter.dll, Version=4.0.5873.25083
    SpiroGraph                                             .\Effects\SpiroGraph.dll, Version=1.1.0.0
    StringAndPin                                           .\Effects\StringAndPin.dll, Version=1.0.1.0
    TextFactory                                            .\Effects\TextFactory.dll, Version=1.0.8702.17604
    Vandermotten.PaintDotNetEffects.MakeTransparent        .\Effects\Vandermotten.PaintDotNetEffects.MakeTransparent.dll, Version=5.0.0.0
    TR'sColorizerHMS                                       .\Effects\TR'sColorizerHMS.dll, Version=1.0.4937.30626
    TextureShader                                          .\Effects\TextureShader.dll, Version=1.0.5655.35781
    TerraFX.Interop.Windows                                .\Effects\PSFilterPdn\TerraFX.Interop.Windows.dll, Version=10.0.22621.2, PublicKeyToken=35b01b53313a6f7e
    Transparency                                           .\Effects\Transparency.dll, Version=6.0.8407.22532
    TRs Scatter                                            .\Effects\TRs Scatter.dll, Version=1.3.4949.23250
    System.Runtime.Intrinsics                              .\System.Runtime.Intrinsics.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    TRsCustomPaletteMatch                                  .\Effects\TRsCustomPaletteMatch.dll, Version=1.0.5.0
    TRsPasteFrame                                          .\Effects\TRsPasteFrame.dll, Version=1.3.20.9613
    TRsKaboom                                              .\Effects\TRsKaboom.dll, Version=1.0.5118.21464
    TRsFilaments                                           .\Effects\TRsFilaments.dll, Version=1.0.15.11399
    TRsPasteWarp                                           .\Effects\TRsPasteWarp.dll, Version=1.0.0.0
    TubeOblique                                            .\Effects\TubeOblique.dll, Version=1.0.0.0
    Tweaktrans2                                            .\Effects\Tweaktrans2.dll, Version=2.0.4252.27152
    Tweaktrans4                                            .\Effects\Tweaktrans.dll, Version=1.0.4193.41856
    Twist                                                  .\Effects\Twist.dll, Version=4.0.5873.25056
    Vandermotten.PaintDotNetEffects.Blurs                  .\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, Version=5.0.0.0
    MessagePack                                            .\Effects\PSFilterPdn\MessagePack.dll, Version=2.5.0.0, PublicKeyToken=b4a0369545f0a1be
    Vandermotten.PaintDotNetEffects.DropShadow             .\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, Version=5.0.0.0
    Vandermotten.PaintDotNetEffects.Gradient               .\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, Version=5.0.0.0
    System.Threading.Tasks                                 .\System.Threading.Tasks.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Windows.Forms.Legacy                            .\System.Windows.Forms.Legacy.dll, Version=1.0.0.0
    System.Text.RegularExpressions                         .\System.Text.RegularExpressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Xml.XDocument                                   .\System.Xml.XDocument.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Private.Xml.Linq                                .\System.Private.Xml.Linq.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Security.Cryptography.Primitives                .\System.Security.Cryptography.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Cryptography                           .\System.Security.Cryptography.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.Compression                                  .\System.IO.Compression.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Runtime.Numerics                                .\System.Runtime.Numerics.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Polygon                                                .\Effects\Polygon.dll, Version=4.5.6828.38648
    System.Security.Cryptography.Algorithms                .\System.Security.Cryptography.Algorithms.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    HSVGradients                                           .\Effects\HSVGradients.dll, Version=4.5.6832.41864
    Newtonsoft.Json                                        .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed
    System.Linq.Expressions                                .\System.Linq.Expressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PresentationFramework-SystemXmlLinq                    .\PresentationFramework-SystemXmlLinq.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Xml.Linq                                        .\System.Xml.Linq.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    Gradient Mapping                                       .\Effects\Gradient Mapping.dll, Version=4.0.6547.33963
    ComputeSharp.Core                                      .\ComputeSharp.Core.dll, Version=2.1.0.0, PublicKeyToken=dc35fa229f6881d8
    PhotoSauce.MagicScaler                                 .\PhotoSauce.MagicScaler.dll, Version=0.13.2.0, PublicKeyToken=fc6b9b7b06809481
    ParallelLines.Effect                                   .\Effects\ParallelLines.Effect.dll, Version=1.6.0.575
    OptionBasedLibrary v0.7.9                              .\Effects\OptionBasedLibrary v0.7.9.dll, Version=0.7.9.1561
    PointerToolkit.TerraFX.Interop.Windows                 .\PointerToolkit.TerraFX.Interop.Windows.dll, Version=10.0.22621.2
    Interop.WIA                                            .\Interop.WIA.dll, Version=1.0.0.0
    System.CodeDom                                         .\System.CodeDom.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    K4os.Compression.LZ4                                   .\K4os.Compression.LZ4.dll, Version=1.2.16.0, PublicKeyToken=2186fa9121ef231d
Native modules                                             404
    paintdotnet.exe                                        .\paintdotnet.exe, version=5.11.8685.3093
    ntdll.dll                                              C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.22621.2361 (WinBuild.160101.0800)
    KERNEL32.DLL                                           C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.22621.2428 (WinBuild.160101.0800)
    KERNELBASE.dll                                         C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    SHELL32.dll                                            C:\WINDOWS\System32\SHELL32.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    msvcp_win.dll                                          C:\WINDOWS\System32\msvcp_win.dll, version=10.0.22621.608 (WinBuild.160101.0800)
    ucrtbase.dll                                           C:\WINDOWS\System32\ucrtbase.dll, version=10.0.22621.608 (WinBuild.160101.0800)
    USER32.dll                                             C:\WINDOWS\System32\USER32.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    win32u.dll                                             C:\WINDOWS\System32\win32u.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    GDI32.dll                                              C:\WINDOWS\System32\GDI32.dll, version=10.0.22621.2215 (WinBuild.160101.0800)
    gdi32full.dll                                          C:\WINDOWS\System32\gdi32full.dll, version=10.0.22621.2361 (WinBuild.160101.0800)
    ole32.dll                                              C:\WINDOWS\System32\ole32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    combase.dll                                            C:\WINDOWS\System32\combase.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    RPCRT4.dll                                             C:\WINDOWS\System32\RPCRT4.dll, version=10.0.22621.1344 (WinBuild.160101.0800)
    OLEAUT32.dll                                           C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.22621.1992 (WinBuild.160101.0800)
    SHLWAPI.dll                                            C:\WINDOWS\System32\SHLWAPI.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    msvcrt.dll                                             C:\WINDOWS\System32\msvcrt.dll, version=7.0.22621.608 (WinBuild.160101.0800)
    VCRUNTIME140_1.dll                                     .\VCRUNTIME140_1.dll, version=14.38.33126.1
    VCRUNTIME140.dll                                       .\VCRUNTIME140.dll, version=14.38.33126.1
    IMM32.DLL                                              C:\WINDOWS\System32\IMM32.DLL, version=10.0.22621.1344 (WinBuild.160101.0800)
    shcore.dll                                             C:\WINDOWS\System32\shcore.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    hostfxr.dll                                            .\hostfxr.dll, version=7,0,1223,47720 @Commit: 4a824ef37caa51072221584c64cbf15455f406ca
    ADVAPI32.dll                                           C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    sechost.dll                                            C:\WINDOWS\System32\sechost.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    hostpolicy.dll                                         .\hostpolicy.dll, version=7,0,1223,47720 @Commit: 4a824ef37caa51072221584c64cbf15455f406ca
    coreclr.dll                                            .\coreclr.dll, version=7,0,1223,47720 @Commit: 4a824ef37caa51072221584c64cbf15455f406ca
    bcryptPrimitives.dll                                   C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.22621.2361 (WinBuild.160101.0800)
    System.Private.CoreLib.dll                             .\System.Private.CoreLib.dll, version=7.0.1223.47720
    clrjit.dll                                             .\clrjit.dll, version=7,0,1223,47720 @Commit: 4a824ef37caa51072221584c64cbf15455f406ca
    kernel.appcore.dll                                     C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    paintdotnet.dll                                        .\paintdotnet.dll, version=5.11.8685.3093
    System.Runtime.dll                                     .\System.Runtime.dll, version=7.0.1223.47720
    uxtheme.dll                                            C:\WINDOWS\system32\uxtheme.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    System.Windows.Forms.dll                               .\System.Windows.Forms.dll, version=7.0.1223.47803
    PaintDotNet.Fundamentals.dll                           .\PaintDotNet.Fundamentals.dll, version=5.11.8685.3093
    System.Diagnostics.Tracing.dll                         .\System.Diagnostics.Tracing.dll, version=7.0.1223.47720
    icu.dll                                                C:\WINDOWS\SYSTEM32\icu.dll, version=68, 2, 0, 10 (WinBuild.160101.0800)
    System.Threading.Thread.dll                            .\System.Threading.Thread.dll, version=7.0.1223.47720
    PaintDotNet.Base.dll                                   .\PaintDotNet.Base.dll, version=5.11.8685.3093
    PaintDotNet.Collections.dll                            .\PaintDotNet.Collections.dll, version=5.11.8685.3093
    PaintDotNet.ComponentModel.dll                         .\PaintDotNet.ComponentModel.dll, version=5.11.8685.3093
    PaintDotNet.Windows.dll                                .\PaintDotNet.Windows.dll, version=5.11.8685.3093
    TerraFX.Interop.Windows.dll                            .\TerraFX.Interop.Windows.dll, version=10.0.22621.2
    PaintDotNet.Primitives.dll                             .\PaintDotNet.Primitives.dll, version=5.11.8685.3093
    System.Collections.Concurrent.dll                      .\System.Collections.Concurrent.dll, version=7.0.1223.47720
    PaintDotNet.Runtime.dll                                .\PaintDotNet.Runtime.dll, version=5.11.8685.3093
    PointerToolkit.dll                                     .\PointerToolkit.dll, version=1.0.0.0
    System.Threading.dll                                   .\System.Threading.dll, version=7.0.1223.47720
    PaintDotNet.SystemLayer.dll                            .\PaintDotNet.SystemLayer.dll, version=5.11.8685.3093
    PaintDotNet.Systrace.dll                               .\PaintDotNet.Systrace.dll, version=5.11.8685.3093
    System.Diagnostics.Process.dll                         .\System.Diagnostics.Process.dll, version=7.0.1223.47720
    windows.storage.dll                                    C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    wintypes.dll                                           C:\WINDOWS\SYSTEM32\wintypes.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Private.Uri.dll                                 .\System.Private.Uri.dll, version=7.0.1223.47720
    BCrypt.dll                                             C:\WINDOWS\SYSTEM32\BCrypt.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.ComponentModel.Primitives.dll                   .\System.ComponentModel.Primitives.dll, version=7.0.1223.47720
    System.Windows.Forms.Primitives.dll                    .\System.Windows.Forms.Primitives.dll, version=7.0.1223.47803
    WindowsBase.dll                                        .\WindowsBase.dll, version=7.0.1223.47802
    PaintDotNet.ObjectModel.dll                            .\PaintDotNet.ObjectModel.dll, version=5.11.8685.3093
    System.Runtime.InteropServices.dll                     .\System.Runtime.InteropServices.dll, version=7.0.1223.47720
    System.Drawing.Primitives.dll                          .\System.Drawing.Primitives.dll, version=7.0.1223.47720
    System.Collections.dll                                 .\System.Collections.dll, version=7.0.1223.47720
    System.Diagnostics.TraceSource.dll                     .\System.Diagnostics.TraceSource.dll, version=7.0.1223.47720
    Microsoft.Win32.Primitives.dll                         .\Microsoft.Win32.Primitives.dll, version=7.0.1223.47720
    System.Text.Encoding.CodePages.dll                     .\System.Text.Encoding.CodePages.dll, version=7.0.1223.47720
    PaintDotNet.Core.dll                                   .\PaintDotNet.Core.dll, version=5.11.8685.3093
    PaintDotNet.Resources.dll                              .\PaintDotNet.Resources.dll, version=5.11.8685.3093
    System.ObjectModel.dll                                 .\System.ObjectModel.dll, version=7.0.1223.47720
    PaintDotNet.Data.dll                                   .\PaintDotNet.Data.dll, version=5.11.8685.3093
    PaintDotNet.Framework.dll                              .\PaintDotNet.Framework.dll, version=5.11.8685.3093
    CommunityToolkit.HighPerformance.dll                   .\CommunityToolkit.HighPerformance.dll, version=8.2.1.1
    System.Threading.ThreadPool.dll                        .\System.Threading.ThreadPool.dll, version=7.0.1223.47720
    dxgi.DLL                                               C:\WINDOWS\SYSTEM32\dxgi.DLL, version=10.0.22621.2361 (WinBuild.160101.0800)
    PresentationNative_cor3.dll                            .\PresentationNative_cor3.dll, version=7,0,23,40905 @Commit: 62999eb1848d22a5271ae178aa2b92383e1df544
    System.Collections.Immutable.dll                       .\System.Collections.Immutable.dll, version=7.0.1223.47720
    PaintDotNet.Windows.Framework.dll                      .\PaintDotNet.Windows.Framework.dll, version=5.11.8685.3093
    System.Configuration.ConfigurationManager.dll          .\System.Configuration.ConfigurationManager.dll, version=7.0.1223.47720
    dxcore.dll                                             C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.22621.2361 (WinBuild.160101.0800)
    System.Collections.Specialized.dll                     .\System.Collections.Specialized.dll, version=7.0.1223.47720
    System.Drawing.Common.dll                              .\System.Drawing.Common.dll, version=7.0.1223.47720
    directxdatabasehelper.dll                              C:\WINDOWS\SYSTEM32\directxdatabasehelper.dll, version=10.0.22621.2361 (WinBuild.160101.0800)
    PaintDotNet.UI.dll                                     .\PaintDotNet.UI.dll, version=5.11.8685.3093
    System.Xml.ReaderWriter.dll                            .\System.Xml.ReaderWriter.dll, version=7.0.1223.47720
    System.Private.Xml.dll                                 .\System.Private.Xml.dll, version=7.0.1223.47720
    System.Net.WebClient.dll                               .\System.Net.WebClient.dll, version=7.0.1223.47720
    System.ComponentModel.EventBasedAsync.dll              .\System.ComponentModel.EventBasedAsync.dll, version=7.0.1223.47720
    System.Memory.dll                                      .\System.Memory.dll, version=7.0.1223.47720
    Microsoft.Win32.SystemEvents.dll                       .\Microsoft.Win32.SystemEvents.dll, version=7.0.1223.47720
    System.Text.Encoding.Extensions.dll                    .\System.Text.Encoding.Extensions.dll, version=7.0.1223.47720
    System.Linq.dll                                        .\System.Linq.dll, version=7.0.1223.47720
    System.Diagnostics.FileVersionInfo.dll                 .\System.Diagnostics.FileVersionInfo.dll, version=7.0.1223.47720
    profapi.dll                                            C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.22621.1928 (WinBuild.160101.0800)
    version.dll                                            C:\WINDOWS\SYSTEM32\version.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    MSCTF.dll                                              C:\WINDOWS\System32\MSCTF.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    Microsoft.Win32.Registry.dll                           .\Microsoft.Win32.Registry.dll, version=7.0.1223.47720
    System.Security.Principal.Windows.dll                  .\System.Security.Principal.Windows.dll, version=7.0.1223.47720
    System.Security.Claims.dll                             .\System.Security.Claims.dll, version=7.0.1223.47720
    PaintDotNet.Windows.Core.dll                           .\PaintDotNet.Windows.Core.dll, version=5.11.8685.3093
    System.ComponentModel.dll                              .\System.ComponentModel.dll, version=7.0.1223.47720
    ComputeSharp.D2D1.dll                                  .\ComputeSharp.D2D1.dll, version=2.1.0.0
    d3d11.DLL                                              C:\WINDOWS\SYSTEM32\d3d11.DLL, version=10.0.22621.2070 (WinBuild.160101.0800)
    PresentationFramework.dll                              .\PresentationFramework.dll, version=7.0.1223.47802
    nvldumdx.dll                                           C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_4eef80c06561d01a\nvldumdx.dll, version=31.0.15.4584
    msasn1.dll                                             C:\WINDOWS\SYSTEM32\msasn1.dll, version=10.0.22621.819 (WinBuild.160101.0800)
    cryptnet.dll                                           C:\WINDOWS\SYSTEM32\cryptnet.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    CRYPT32.dll                                            C:\WINDOWS\System32\CRYPT32.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    drvstore.dll                                           C:\WINDOWS\SYSTEM32\drvstore.dll, version=10.0.22621.2070 (WinBuild.160101.0800)
    devobj.dll                                             C:\WINDOWS\SYSTEM32\devobj.dll, version=10.0.22621.1344 (WinBuild.160101.0800)
    cfgmgr32.dll                                           C:\WINDOWS\SYSTEM32\cfgmgr32.dll, version=10.0.22621.1344 (WinBuild.160101.0800)
    wldp.dll                                               C:\WINDOWS\SYSTEM32\wldp.dll, version=10.0.22621.2070 (WinBuild.160101.0800)
    cryptbase.dll                                          C:\WINDOWS\SYSTEM32\cryptbase.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    wintrust.dll                                           C:\WINDOWS\System32\wintrust.dll, version=10.0.22621.2361 (WinBuild.160101.0800)
    imagehlp.dll                                           C:\WINDOWS\System32\imagehlp.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    d2d1.DLL                                               C:\WINDOWS\SYSTEM32\d2d1.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    clbcatq.dll                                            C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800)
    UIAnimation.dll                                        C:\WINDOWS\System32\UIAnimation.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    PaintDotNet.PropertySystem.dll                         .\PaintDotNet.PropertySystem.dll, version=5.11.8685.3093
    System.ComponentModel.TypeConverter.dll                .\System.ComponentModel.TypeConverter.dll, version=7.0.1223.47720
    gdiplus.dll                                            C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.22621.1778_none_57fe2016ce1542ec\gdiplus.dll, version=10.0.22621.1778 (WinBuild.160101.0800)
    System.Xaml.dll                                        .\System.Xaml.dll, version=7.0.1223.47802
    CRYPTSP.dll                                            C:\WINDOWS\SYSTEM32\CRYPTSP.dll, version=10.0.22621.2361 (WinBuild.160101.0800)
    WindowsCodecs.dll                                      C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.22621.1635 (WinBuild.160101.0800)
    rsaenh.dll                                             C:\WINDOWS\system32\rsaenh.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    XmlLite.dll                                            C:\WINDOWS\SYSTEM32\XmlLite.dll, version=10.0.22621.608 (WinBuild.160101.0800)
    PaintDotNet.Effects.Core.dll                           .\PaintDotNet.Effects.Core.dll, version=5.11.8685.3093
    System.IO.Packaging.dll                                .\System.IO.Packaging.dll, version=7.0.1223.47720
    PresentationCore.dll                                   .\PresentationCore.dll, version=7.0.1223.47802
    DirectWriteForwarder.dll                               .\DirectWriteForwarder.dll, version=7,0,1223,47802 @Commit: c94bac748138456f4feef271b3dc18e4b46453e6
    nvgpucomp64.dll                                        C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_4eef80c06561d01a\nvgpucomp64.dll, version=31.0.15.4584
    dwrite.DLL                                             C:\WINDOWS\SYSTEM32\dwrite.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Runtime.Extensions.dll                          .\System.Runtime.Extensions.dll, version=7.0.1223.47720
    System.Diagnostics.Debug.dll                           .\System.Diagnostics.Debug.dll, version=7.0.1223.47720
    System.Runtime.CompilerServices.VisualC.dll            .\System.Runtime.CompilerServices.VisualC.dll, version=7.0.1223.47720
    System.Collections.NonGeneric.dll                      .\System.Collections.NonGeneric.dll, version=7.0.1223.47720
    comctl32.dll                                           C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.22621.2361_none_2712ced57382f843\comctl32.dll, version=6.10 (WinBuild.160101.0800)
    Accessibility.dll                                      .\Accessibility.dll, version=7.0.1223.47803
    UIAutomationTypes.dll                                  .\UIAutomationTypes.dll, version=7.0.1223.47802
    nvwgf2umx.dll                                          C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_4eef80c06561d01a\nvwgf2umx.dll, version=31.0.15.4584
    WINMM.dll                                              C:\WINDOWS\SYSTEM32\WINMM.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.IO.Hashing.dll                                  .\System.IO.Hashing.dll, version=7.0.22.51805
    PaintDotNet.Effects.Gpu.dll                            .\PaintDotNet.Effects.Gpu.dll, version=5.11.8685.3093
    PaintDotNet.Effects.dll                                .\PaintDotNet.Effects.dll, version=5.11.8685.3093
    System.Threading.Tasks.Parallel.dll                    .\System.Threading.Tasks.Parallel.dll, version=7.0.1223.47720
    System.Reflection.Metadata.dll                         .\System.Reflection.Metadata.dll, version=7.0.1223.47720
    System.IO.MemoryMappedFiles.dll                        .\System.IO.MemoryMappedFiles.dll, version=7.0.1223.47720
    System.Reflection.MetadataLoadContext.dll              .\System.Reflection.MetadataLoadContext.dll, version=7.0.22.51805
    System.Numerics.Vectors.dll                            .\System.Numerics.Vectors.dll, version=7.0.1223.47720
    nvspcap64.dll                                          C:\WINDOWS\system32\nvspcap64.dll, version=3.27.0.112
    ntmarta.dll                                            C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    MessageBus.dll                                         C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_4eef80c06561d01a\Display.NvContainer\MessageBus.dll, version=
    WS2_32.dll                                             C:\WINDOWS\System32\WS2_32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    IPHLPAPI.DLL                                           C:\WINDOWS\SYSTEM32\IPHLPAPI.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Runtime.Loader.dll                              .\System.Runtime.Loader.dll, version=7.0.1223.47720
    NSI.dll                                                C:\WINDOWS\System32\NSI.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    dhcpcsvc.DLL                                           C:\WINDOWS\SYSTEM32\dhcpcsvc.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    TextShaping.dll                                        C:\WINDOWS\SYSTEM32\TextShaping.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    CSVFiletype.dll                                        .\FileTypes\CSVFiletype.dll, version=1.0.0.0
    PhotoShop.dll                                          .\FileTypes\PhotoShop.dll, version=2.5.0.0
    Jpeg2000Filetype.dll                                   .\FileTypes\Jpeg2000Filetype.dll, version=1.0.0.6
    ImXCF.FileType.dll                                     .\FileTypes\ImXCF.FileType.dll, version=1.4.0.95
    OptiPngFileType.dll                                    .\FileTypes\OptiPngFileType.dll, version=8.11.30.0
    IcoCur.dll                                             .\FileTypes\IcoCur.dll, version=3.7.0.0
    ImAGIF.FileType.dll                                    .\FileTypes\ImAGIF.FileType.dll, version=1.4.0.0
    ImAPNG.FileType.dll                                    .\FileTypes\ImAPNG.FileType.dll, version=0.3.0.19
    mscorlib.dll                                           .\mscorlib.dll, version=7.0.1223.47720
    System.dll                                             .\System.dll, version=7.0.1223.47720
    System.Drawing.dll                                     .\System.Drawing.dll, version=7.0.1223.47803
    mfplat.dll                                             C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    RTWorkQ.DLL                                            C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.22621.1 (WinBuild.160101.0800)
    CompPkgSup.DLL                                         C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.22621.2215 (WinBuild.160101.0800)
    Windows.StateRepositoryPS.dll                          C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.22621.1928 (WinBuild.160101.0800)
    System.IO.FileSystem.dll                               .\System.IO.FileSystem.dll, version=7.0.1223.47720
    wtsapi32.dll                                           C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    WINSTA.dll                                             C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.22621.1635 (WinBuild.160101.0800)
    AvifFileType.dll                                       .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.26.0
    WebPFileType.dll                                       .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.20.0
    DdsFileTypePlus.dll                                    .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.12.8.0
    D3D10Warp.dll                                          C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.22621.1194 (WinBuild.160101.0800)
    windows.staterepositoryclient.dll                      C:\WINDOWS\SYSTEM32\windows.staterepositoryclient.dll, version=10.0.22621.1928 (WinBuild.160101.0800)
    windows.staterepositorycore.dll                        C:\WINDOWS\SYSTEM32\windows.staterepositorycore.dll, version=10.0.22621.1928 (WinBuild.160101.0800)
    Mono.Cecil.dll                                         .\Mono.Cecil.dll, version=0.11.5.0
    netstandard.dll                                        .\netstandard.dll, version=7.0.1223.47720
    UIAutomationCore.dll                                   C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.22621.2428 (WinBuild.160101.0800)
    PaintDotNet.Effects.Legacy.dll                         .\PaintDotNet.Effects.Legacy.dll, version=5.11.8685.3093
    PaintDotNet.Plugins.Compatibility.dll                  .\PaintDotNet.Plugins.Compatibility.dll, version=5.11.8685.3093
    System.Console.dll                                     .\System.Console.dll, version=7.0.1223.47720
    CalliColour.dll                                        .\Effects\CalliColour.dll, version=1.0.1.0
    AA's_Assistant.dll                                     .\Effects\AA's_Assistant.dll, version=1.1.4329.33034
    AlphaToDots.dll                                        .\Effects\AlphaToDots.dll, version=1.0.4675.19955
    AlphaBlur.dll                                          .\Effects\AlphaBlur.dll, version=2.0.0.0
    AverageEdgeBlur.dll                                    .\Effects\AverageEdgeBlur.dll, version=1.0.3991.32409
    AveragedColorBlur.dll                                  .\Effects\AveragedColorBlur.dll, version=1.0.0.0
    BandWPlus.dll                                          .\Effects\BandWPlus.dll, version=6.0.8407.21940
    Alphalizer.dll                                         .\Effects\Alphalizer.dll, version=2.0.5434.24240
    BasicPhotoAdjustments.dll                              .\Effects\BasicPhotoAdjustments.dll, version=2.1.4020.485
    CellTexture.dll                                        .\Effects\CellTexture.dll, version=1.0.0.0
    Bars.dll                                               .\Effects\Bars.dll, version=1.1.0.0
    BlendModesPlus.dll                                     .\Effects\BlendModesPlus.dll, version=3.1.0.0
    BBOutlinedGradientText.dll                             .\Effects\BBOutlinedGradientText.dll, version=6.0.8426.37652
    BoldBrush.dll                                          .\Effects\BoldBrush.dll, version=2.0.8470.26873
    Bidirectional Blur.dll                                 .\Effects\Bidirectional Blur.dll, version=1.0.0.0
    CircleText.dll                                         .\Effects\CircleText.dll, version=1.4.4415.32488
    ClipWarpNew.dll                                        .\Effects\ClipWarpNew.dll, version=1.0.1.0
    ClipDisplace.dll                                       .\Effects\ClipDisplace.dll, version=1.0.5763.42010
    Cobweb.dll                                             .\Effects\Cobweb.dll, version=1.0.1.0
    coloraberation.dll                                     .\Effects\coloraberation.dll, version=1.0.3859.18981
    System.Runtime.Serialization.Formatters.dll            .\System.Runtime.Serialization.Formatters.dll, version=7.0.1223.47720
    ColorBalance.dll                                       .\Effects\ColorBalance.dll, version=6.0.8407.22111
    ColorCount.dll                                         .\Effects\ColorCount.dll, version=1.0.0.0
    CodeLab.dll                                            .\Effects\CodeLab.dll, version=6.10.8685.36729
    voronoi.dll                                            .\Effects\voronoi.dll, version=1.0.0.0
    ColorZoomBlur.dll                                      .\Effects\ColorZoomBlur.dll, version=1.1.3873.36417
    ColorMixer.dll                                         .\Effects\ColorMixer.dll, version=1.3.0.0
    Contour.dll                                            .\Effects\Contour.dll, version=1.0.1.0
    VignettePlus.dll                                       .\Effects\VignettePlus.dll, version=6.0.8407.22549
    ConvolutionEffect.dll                                  .\Effects\ConvolutionEffect.dll, version=1.0.0.2
    ContentAwareFill.dll                                   .\Effects\ContentAwareFill.dll, version=1.5.1.0
    CreativeTextPro.dll                                    .\Effects\CreativeTextPro.dll, version=6.0.8407.22165
    Cuboids.dll                                            .\Effects\Cuboids.dll, version=1.0.0.0
    CycleHSV.dll                                           .\Effects\CycleHSV.dll, version=1.0.4909.35068
    dpyColorBalance.dll                                    .\Effects\dpyColorBalance.dll, version=1.1.4330.37850
    Diffuse.dll                                            .\Effects\Diffuse.dll, version=1.0.3254.27766
    Curves+.dll                                            .\Effects\Curves+.dll, version=4.0.6119.31044
    Dryad.dll                                              .\Effects\Dryad.dll, version=1.0.1.0
    Dream.dll                                              .\Effects\Dream.dll, version=6.0.8414.36727
    DistortThis.dll                                        .\Effects\DistortThis.dll, version=2.10.0.0
    Edge Shader.dll                                        .\Effects\Edge Shader.dll, version=1.0.1.0
    EdHarvey.Edfects.dll                                   .\Effects\EdHarvey.Edfects.dll, version=5.0.0.0
    velc.SlabText.dll                                      .\Effects\velc.SlabText.dll, version=1.1.8174.32156
    AlphaMask.dll                                          .\Effects\AlphaMask.dll, version=2.0.3574.41943
    EigenBlur.dll                                          .\Effects\EigenBlur.dll, version=1.3.3555.24648
    EOEffects.dll                                          .\Effects\EOEffects.dll, version=1.10.16.12
    Erode.dll                                              .\Effects\Erode.dll, version=1.0.0.0
    Facet.dll                                              .\Effects\Facet.dll, version=1.0.3.0
    ErodeDilate_v0.2.dll                                   .\Effects\ErodeDilate_v0.2.dll, version=1.0.0.0
    FillFromClipboard.dll                                  .\Effects\FillFromClipboard.dll, version=6.0.8407.22397
    FindEdges.dll                                          .\Effects\FindEdges.dll, version=1.2.0.0
    FloydSteinbergDithering.dll                            .\Effects\FloydSteinbergDithering.dll, version=5.2.8174.39918
    Flip.dll                                               .\Effects\Flip.dll, version=4.6.7358.36953
    FurBlur.dll                                            .\Effects\FurBlur.dll, version=1.0.1.0
    F_AdjustHSLuv.dll                                      .\Effects\F_AdjustHSLuv.dll, version=1.0.8717.41948
    F_ColorVectorCross.dll                                 .\Effects\F_ColorVectorCross.dll, version=1.2.8710.30670
    F_ColorVectorRotation.dll                              .\Effects\F_ColorVectorRotation.dll, version=1.2.8710.28036
    F_FastAlpha2Gray.dll                                   .\Effects\F_FastAlpha2Gray.dll, version=1.0.8716.30768
    F_ColorVectorRotationAxAng.dll                         .\Effects\F_ColorVectorRotationAxAng.dll, version=1.2.8710.27976
    F_FastAlphaRemove.dll                                  .\Effects\F_FastAlphaRemove.dll, version=1.0.8716.30758
    Vandermotten.PaintDotNetEffects.ObjectAlign.dll        .\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll, version=5.0.3.0
    F_FastClipboard2AlphaMultiply.dll                      .\Effects\F_FastClipboard2AlphaMultiply.dll, version=1.0.8716.34503
    F_FastClipboard2AlphaOverwrite.dll                     .\Effects\F_FastClipboard2AlphaOverwrite.dll, version=1.0.8716.34508
    Vandermotten.PaintDotNetEffects.dll                    .\Effects\Vandermotten.PaintDotNetEffects.dll, version=5.0.3.0
    F_FastGray2AlphaPrimary.dll                            .\Effects\F_FastGray2AlphaPrimary.dll, version=1.0.8716.30765
    F_FastGray2AlphaRetain.dll                             .\Effects\F_FastGray2AlphaRetain.dll, version=1.0.8716.30762
    F_SeamlessSimplexClouds.dll                            .\Effects\F_SeamlessSimplexClouds.dll, version=1.0.8713.9300
    F_SeamlessVoronoi.dll                                  .\Effects\F_SeamlessVoronoi.dll, version=1.0.8715.42222
    GaussianBlurPlus.dll                                   .\Effects\GaussianBlurPlus.dll, version=4.2.5691.27401
    Gossamer.dll                                           .\Effects\Gossamer.dll, version=1.0.1.0
    Gmic.dll                                               .\Effects\Gmic.dll, version=3.3.2.0
    Gradient Bars.dll                                      .\Effects\Gradient Bars.dll, version=4.0.5152.23084
    Gradient Blocks.dll                                    .\Effects\Gradient Blocks.dll, version=4.0.4642.26658
    Gradient Blur.dll                                      .\Effects\Gradient Blur.dll, version=1.0.0.0
    Grain.dll                                              .\Effects\Grain.dll, version=1.0.3854.25523
    GridMaker.dll                                          .\Effects\GridMaker.dll, version=4.0.0.0
    Helix.dll                                              .\Effects\Helix.dll, version=1.0.1.0
    System.Net.Http.dll                                    .\System.Net.Http.dll, version=7.0.1223.47720
    HexaGrid.dll                                           .\Effects\HexaGrid.dll, version=1.2.0.0
    Grid Warp.dll                                          .\Effects\Grid Warp.dll, version=4.0.6544.34496
    HueSatPlus.dll                                         .\Effects\HueSatPlus.dll, version=5.2.8174.40274
    System.Net.Primitives.dll                              .\System.Net.Primitives.dll, version=7.0.1223.47720
    IrisBlur.dll                                           .\Effects\IrisBlur.dll, version=1.0.8690.21381
    IncreaseLocalContrast.dll                              .\Effects\IncreaseLocalContrast.dll, version=1.0.1.1
    Jitter.dll                                             .\Effects\Jitter.dll, version=4.0.4642.26986
    Kuwahara.dll                                           .\Effects\Kuwahara.dll, version=1.0.0.0
    kb_lens.dll                                            .\Effects\kb_lens.dll, version=0.0.0.0
    System.Core.dll                                        .\System.Core.dll, version=7.0.1223.47720
    Line Tracer.dll                                        .\Effects\Line Tracer.dll, version=1.0.4911.29141
    LavEnt.Effects.Mosaic.dll                              .\Effects\LavEnt.Effects.Mosaic.dll, version=1.1.0.0
    LaplacianPyramidFilter.dll                             .\Effects\LaplacianPyramidFilter.dll, version=1.0.0.1
    LocalContrast.dll                                      .\Effects\LocalContrast.dll, version=3.0.0.0
    Liquify.dll                                            .\Effects\Liquify.dll, version=4.0.5873.25113
    LocalNoise.dll                                         .\Effects\LocalNoise.dll, version=1.0.4674.29909
    Magnifier.dll                                          .\Effects\Magnifier.dll, version=1.1.0.0
    MirrorRotateMenu.dll                                   .\Effects\MirrorRotateMenu.dll, version=2.0.2
    Morphologic.dll                                        .\Effects\Morphologic.dll, version=1.0.0.0
    MultiSpline.dll                                        .\Effects\MultiSpline.dll, version=1.0.3.0
    NoiseChoice.dll                                        .\Effects\NoiseChoice.dll, version=1.0.1.0
    Norm_Render.dll                                        .\Effects\Norm_Render.dll, version=7.3.4484.27012
    ObjectBevel.dll                                        .\Effects\ObjectBevel.dll, version=1.0.6.0
    System.Resources.Extensions.dll                        .\System.Resources.Extensions.dll, version=7.0.1223.47720
    Objectedge.dll                                         .\Effects\Objectedge.dll, version=1.0.1.0
    ObjectTools.dll                                        .\Effects\ObjectTools.dll, version=6.0.8428.8314
    Oblique.dll                                            .\Effects\Oblique.dll, version=1.0.0.0
    IniFile.dll                                            .\Effects\IniFile.dll, version=2.0.2
    Panelling.dll                                          .\Effects\Panelling.dll, version=1.1.0.0
    OilPaintingPlus.dll                                    .\Effects\OilPaintingPlus.dll, version=5.2.8141.27893
    PasteFill.dll                                          .\Effects\PasteFill.dll, version=2.0.0.0
    Pastel.dll                                             .\Effects\Pastel.dll, version=5.2.8174.40506
    Perspective.dll                                        .\Effects\Perspective.dll, version=2.1.4415.36116
    phips_fill_gaps.dll                                    .\Effects\phips_fill_gaps.dll, version=1.0.3307.18956
    PhotoAdjustments.dll                                   .\Effects\PhotoAdjustments.dll, version=6.0.8416.38377
    Pixelate+.dll                                          .\Effects\Pixelate+.dll, version=4.0.4642.26940
    PointBlur.dll                                          .\Effects\PointBlur.dll, version=1.0.0.0
    Polar.dll                                              .\Effects\Polar.dll, version=1.1.1.0
    QuadrilateralCorrection.dll                            .\Effects\QuadrilateralCorrection.dll, version=1.3.0.0
    Random lines.dll                                       .\Effects\Random lines.dll, version=1.1.0.0
    QuantDith.dll                                          .\Effects\QuantDith.dll, version=1.5.8260.29377
    Random Maze1.dll                                       .\Effects\Random Maze1.dll, version=1.1.0.0
    Random Shape Fill.dll                                  .\Effects\Random Shape Fill.dll, version=4.0.4642.26910
    RemoveDust.dll                                         .\Effects\RemoveDust.dll, version=6.0.8407.22513
    Random Maze2.dll                                       .\Effects\Random Maze2.dll, version=1.1.0.0
    RGB_Remap4.dll                                         .\Effects\RGB_Remap4.dll, version=1.0.3538.24311
    Rosaces.dll                                            .\Effects\Rosaces.dll, version=1.1.0.0
    Scribble.dll                                           .\Effects\Scribble.dll, version=1.0.1.0
    SeamCarving.dll                                        .\Effects\SeamCarving.dll, version=5.2.8176.39366
    PSFilterPdn.dll                                        .\Effects\PSFilterPdn\PSFilterPdn.dll, version=2.0.6.0
    Selection2Clear.dll                                    .\Effects\Selection2Clear.dll, version=1.0.1.0
    SelectionTools.dll                                     .\Effects\SelectionTools.dll, version=6.0.8412.38725
    Sharpen+.dll                                           .\Effects\Sharpen+.dll, version=4.0.0.0
    SinWaves.dll                                           .\Effects\SinWaves.dll, version=1.1.0.0
    Slinky.dll                                             .\Effects\Slinky.dll, version=1.0.1.0
    Smudge.dll                                             .\Effects\Smudge.dll, version=4.0.5873.25097
    silhouetteplus.dll                                     .\Effects\silhouetteplus.dll, version=1.1.3131.17586
    Splashes.dll                                           .\Effects\Splashes.dll, version=1.1.1.0
    Splatter.dll                                           .\Effects\Splatter.dll, version=4.0.5873.25083
    SpiroGraph.dll                                         .\Effects\SpiroGraph.dll, version=1.1.0.0
    StringAndPin.dll                                       .\Effects\StringAndPin.dll, version=1.0.1.0
    TextFactory.dll                                        .\Effects\TextFactory.dll, version=1.0.8702.17604
    Vandermotten.PaintDotNetEffects.MakeTransparent.dll    .\Effects\Vandermotten.PaintDotNetEffects.MakeTransparent.dll, version=5.0.3.0
    TR'sColorizerHMS.dll                                   .\Effects\TR'sColorizerHMS.dll, version=1.0.4937.30626
    TextureShader.dll                                      .\Effects\TextureShader.dll, version=1.0.5655.35781
    TerraFX.Interop.Windows.dll                            .\Effects\PSFilterPdn\TerraFX.Interop.Windows.dll, version=10.0.22621.2
    Transparency.dll                                       .\Effects\Transparency.dll, version=6.0.8407.22532
    TRs Scatter.dll                                        .\Effects\TRs Scatter.dll, version=1.3.4949.23250
    System.Runtime.Intrinsics.dll                          .\System.Runtime.Intrinsics.dll, version=7.0.1223.47720
    TRsCustomPaletteMatch.dll                              .\Effects\TRsCustomPaletteMatch.dll, version=1.0.5.0
    TRsPasteFrame.dll                                      .\Effects\TRsPasteFrame.dll, version=1.3.20.9613
    TRsKaboom.dll                                          .\Effects\TRsKaboom.dll, version=1.0.5118.21464
    TRsFilaments.dll                                       .\Effects\TRsFilaments.dll, version=1.0.15.11399
    TRsPasteWarp.dll                                       .\Effects\TRsPasteWarp.dll, version=1.0.0.0
    TubeOblique.dll                                        .\Effects\TubeOblique.dll, version=1.0.0.0
    Tweaktrans2.dll                                        .\Effects\Tweaktrans2.dll, version=2.0.4252.27152
    Tweaktrans.dll                                         .\Effects\Tweaktrans.dll, version=1.0.4193.41856
    Twist.dll                                              .\Effects\Twist.dll, version=4.0.5873.25056
    Vandermotten.PaintDotNetEffects.Blurs.dll              .\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll, version=5.0.3.0
    MessagePack.dll                                        .\Effects\PSFilterPdn\MessagePack.dll, version=2.5.124.21940
    Vandermotten.PaintDotNetEffects.DropShadow.dll         .\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll, version=5.0.3.0
    Vandermotten.PaintDotNetEffects.Gradient.dll           .\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll, version=5.0.3.0
    System.Threading.Tasks.dll                             .\System.Threading.Tasks.dll, version=7.0.1223.47720
    dwmapi.DLL                                             C:\WINDOWS\SYSTEM32\dwmapi.DLL, version=10.0.22621.2428 (WinBuild.160101.0800)
    dataexchange.dll                                       C:\WINDOWS\system32\dataexchange.dll, version=10.0.22621.2070 (WinBuild.160101.0800)
    twinapi.appcore.dll                                    C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Windows.Forms.Legacy.dll                        .\System.Windows.Forms.Legacy.dll, version=1.0.0.0
    System.Text.RegularExpressions.dll                     .\System.Text.RegularExpressions.dll, version=7.0.1223.47720
    amsi.dll                                               C:\WINDOWS\SYSTEM32\amsi.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Xml.XDocument.dll                               .\System.Xml.XDocument.dll, version=7.0.1223.47720
    USERENV.dll                                            C:\WINDOWS\SYSTEM32\USERENV.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.Private.Xml.Linq.dll                            .\System.Private.Xml.Linq.dll, version=7.0.1223.47720
    MpOav.dll                                              C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.23100.2009-0\MpOav.dll, version=4.18.23100.2009 (8fcbd1c22d82af16ba34560e1a70591413e88d17)
    MPCLIENT.DLL                                           C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.23100.2009-0\MPCLIENT.DLL, version=4.18.23100.2009 (8fcbd1c22d82af16ba34560e1a70591413e88d17)
    System.Security.Cryptography.Primitives.dll            .\System.Security.Cryptography.Primitives.dll, version=7.0.1223.47720
    System.Security.Cryptography.dll                       .\System.Security.Cryptography.dll, version=7.0.1223.47720
    gpapi.dll                                              C:\WINDOWS\SYSTEM32\gpapi.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    System.IO.Compression.dll                              .\System.IO.Compression.dll, version=7.0.1223.47720
    System.Runtime.Numerics.dll                            .\System.Runtime.Numerics.dll, version=7.0.1223.47720
    System.Security.Cryptography.Algorithms.dll            .\System.Security.Cryptography.Algorithms.dll, version=7.0.1223.47720
    textinputframework.dll                                 C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.22621.2361 (WinBuild.160101.0800)
    CoreMessaging.dll                                      C:\WINDOWS\SYSTEM32\CoreMessaging.dll, version=10.0.22621.1635 (WinBuild.160101.0800)
    CoreUIComponents.dll                                   C:\WINDOWS\SYSTEM32\CoreUIComponents.dll, version=10.0.22621.2215
    powrprof.dll                                           C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    UMPDC.dll                                              C:\WINDOWS\SYSTEM32\UMPDC.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    Newtonsoft.Json.dll                                    .\Newtonsoft.Json.dll, version=13.0.3.27908
    System.Linq.Expressions.dll                            .\System.Linq.Expressions.dll, version=7.0.1223.47720
    PaintDotNet.SystemLayer.Native.x64.dll                 .\PaintDotNet.SystemLayer.Native.x64.dll, version=5.11.8685.3093
    explorerframe.dll                                      C:\WINDOWS\system32\explorerframe.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    PROPSYS.dll                                            C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.22621.2428 (WinBuild.160101.0800)
    PresentationFramework-SystemXmlLinq.dll                .\PresentationFramework-SystemXmlLinq.dll, version=7.0.1223.47802
    System.Xml.Linq.dll                                    .\System.Xml.Linq.dll, version=7.0.1223.47720
    ComputeSharp.Core.dll                                  .\ComputeSharp.Core.dll, version=2.1.0.0
    d3dcompiler_47.DLL                                     C:\WINDOWS\SYSTEM32\d3dcompiler_47.DLL, version=10.0.22621.608 (WinBuild.160101.0800)
    Cabinet.dll                                            C:\WINDOWS\SYSTEM32\Cabinet.dll, version=5.00 (WinBuild.160101.0800)
    PhotoSauce.MagicScaler.dll                             .\PhotoSauce.MagicScaler.dll, version=0.13.2.0
    dcomp.dll                                              C:\WINDOWS\SYSTEM32\dcomp.dll, version=10.0.22621.2361 (WinBuild.160101.0800)
    ParallelLines.Effect.dll                               .\Effects\ParallelLines.Effect.dll, version=1.6.0.575
    PointerToolkit.TerraFX.Interop.Windows.dll             .\PointerToolkit.TerraFX.Interop.Windows.dll, version=10.0.22621.2
    Interop.WIA.dll                                        .\Interop.WIA.dll, version=1.0.0.0
    wiaaut.dll                                             C:\WINDOWS\System32\wiaaut.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    wiatrace.dll                                           C:\WINDOWS\SYSTEM32\wiatrace.dll, version=10.0.22621.2070 (WinBuild.160101.0800)
    sti.dll                                                C:\Windows\System32\sti.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    apphelp.dll                                            C:\WINDOWS\SYSTEM32\apphelp.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    Windows.FileExplorer.Common.dll                        C:\Windows\System32\Windows.FileExplorer.Common.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    edputil.dll                                            C:\WINDOWS\SYSTEM32\edputil.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    urlmon.dll                                             C:\WINDOWS\SYSTEM32\urlmon.dll, version=11.00.22621.2428 (WinBuild.160101.0800)
    netutils.dll                                           C:\WINDOWS\SYSTEM32\netutils.dll, version=10.0.22621.674 (WinBuild.160101.0800)
    srvcli.dll                                             C:\WINDOWS\SYSTEM32\srvcli.dll, version=10.0.22621.1928 (WinBuild.160101.0800)
    iertutil.dll                                           C:\WINDOWS\SYSTEM32\iertutil.dll, version=11.00.22621.2428 (WinBuild.160101.0800)
    cldapi.dll                                             C:\Windows\System32\cldapi.dll, version=10.0.22621.2134 (WinBuild.160101.0800)
    SspiCli.dll                                            C:\WINDOWS\SYSTEM32\SspiCli.dll, version=10.0.22621.2215 (WinBuild.160101.0800)
    virtdisk.dll                                           C:\WINDOWS\SYSTEM32\virtdisk.dll, version=10.0.22621.2361 (WinBuild.160101.0800)
    appresolver.dll                                        C:\Windows\System32\appresolver.dll, version=10.0.22621.2428 (WinBuild.160101.0800)
    Bcp47Langs.dll                                         C:\Windows\System32\Bcp47Langs.dll, version=10.0.22621.608 (WinBuild.160101.0800)
    OneCoreUAPCommonProxyStub.dll                          C:\Windows\System32\OneCoreUAPCommonProxyStub.dll, version=10.0.22621.2361 (WinBuild.160101.0800)
    sxs.dll                                                C:\WINDOWS\SYSTEM32\sxs.dll, version=10.0.22621.1 (WinBuild.160101.0800)
    System.CodeDom.dll                                     .\System.CodeDom.dll, version=7.0.1223.47720
    K4os.Compression.LZ4.dll                               .\K4os.Compression.LZ4.dll, version=1.2.16
    setupapi.DLL                                           C:\WINDOWS\System32\setupapi.DLL, version=10.0.22621.2428 (WinBuild.160101.0800)
  • Solution
Yeah the Windows Print Wizard thing is very poorly behaved and super buggy. It hangs if you press ESC too quickly. It also hangs in certain error scenarios. Really really bad stuff. It's honestly just a big pile of garbage.
That's why I recently (v5.0.8) punted it to be out-of-process. I'd rather have a harmless zombie process than a hung Paint.NET window.
You can run "tskill paintdotnet" to wipe them all out. I'd like to have Paint.NET kill the print UI automatically when you exit the app, but I can't tell if it's a zombie process or if it's still in the middle of printing, which I'm loathe to meddle with.
