PaintNetBeginner01 Posted August 31 Share Posted August 31 Sorry for picking the wrong topic, i wasnt able to pick the "Plugin Troubleshooting" one, so i have this problem where DropShadow just appears as a big ol' rectangle in my screen, does someone have an explanation? Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted August 31 Share Posted August 31 Which of these are you using? Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
PaintNetBeginner01 Posted August 31 Author Share Posted August 31 Here's some proof. Quote Link to comment Share on other sites More sharing options...
PaintNetBeginner01 Posted August 31 Author Share Posted August 31 @toe_head2001 The plugin/bottom one, sir. Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted August 31 Share Posted August 31 You are trying to run the effect on a completely opaque layer; which will never work. It looks like you're trying to add a shadow to some text. You should create a new layer, and add the text to that new layer. Then run the effect. Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
PaintNetBeginner01 Posted August 31 Author Share Posted August 31 Thanks, i'll try. Quote Link to comment Share on other sites More sharing options...
PaintNetBeginner01 Posted August 31 Author Share Posted August 31 It worked! Thannk you so much man, your a pal. Quote Link to comment Share on other sites More sharing options...
