zaphodikus Posted August 13 Share Posted August 13 I'm struggling today with learning to use this program, the tooltips on the "selection rectangle" for move selection and move pixels are M and Mx2 or SHIFT+M , but the MM and SHIFT+M don't do anything at all for some reason - I'm clearly missing something basic. Quote Link to comment Share on other sites More sharing options...
Pixey Posted August 13 Share Posted August 13 I just tested those shortcuts and they are working fine When you say they don't do anything, do you mean that when you press those keys, they don't switch back and forth to their respective positions? Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 14 Share Posted August 14 The two shortcuts switch betweed the two tools in the upper right corner of this image. Clarification: Mx2 means press M twice. The same as M M. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Tactilis Posted August 14 Share Posted August 14 12 hours ago, zaphodikus said: I'm struggling today with learning to use this program... I'm clearly missing something basic. What you seem to be missing is the comprehensive Documentation. Click the blue ? icon top right in Paint.NET which will take you here https://www.getpaint.net/doc/latest/index.html For the Tools, see here https://www.getpaint.net/doc/latest/ToolsWindow.html then look at the Move tools https://www.getpaint.net/doc/latest/MoveTools.html You'll soon get the hang of it and find that using the keyboard shortcuts help speed things up greatly. 1 Quote Link to comment Share on other sites More sharing options...
zaphodikus Posted August 31 Author Share Posted August 31 Hmmmm. Thanks for the pointers to persevere, my main aim is to get more efficient, and just re-reading the docs has uncovered a few organiser tips. I'll have to do a screen recording or some-such to show how this is not working. I think part of the issue is that if you tap a toolbar to set focus to it, that the behaviour changes. The hotkeys work on this computer (version 5.9.8621) but not on my other desktop. So I'll have to go back to that computer to repro and update. Pretty sure it's just that computer. Quote Link to comment Share on other sites More sharing options...
Tactilis Posted August 31 Share Posted August 31 1 hour ago, zaphodikus said: I think part of the issue is that if you tap a toolbar to set focus to it, that the behaviour changes. In what way does the behaviour change for you when you tap a toolbar? Quote Link to comment Share on other sites More sharing options...
