Palm Leaf -- Basic Beginners -- Moderate difficulty.
oma
you do know there are always workarounds. the bars plugin you have can be used, but it is better to upgrade.
the way to use the one you currently have is to rotare the layer using the right mouse button until your leave is at an upright angle, or just draw the leave in an upright position.
but really strongly suggest you update the plugin you will open many new avenues for your work to progress in.
ciao look forward to seeing how you make out with making a leaf.
OMA
Well I`ve finished `making out' with my first palm leaf and here is the result. Hope you like it. If you can see anything I might have done better or differently please say so.
The one thing I did do different was with the stem.I instead of using the Bevel plug in I drew a thin white line along the top of the stem and used Gaussian blur on a low setting.
And my Alternatives to PDN
well after all that making out, the leaf is not bent, or even curved!? wow. thats subtle.
it looks wonderful goon. good job
You should get the Win7 theme for XP. Then get the rest of Win7. Then uninstall XP. Then it'll really look nice. ~ David Atwell
Is there a smilie for the hip hip horay! this is very very well done.
ciao
  • 4 weeks later...
Hi! Im a new members here and also new to paint.net..
I tried to follow the tutorials made here but i found there's a some of the effect or tools that i dont have..so,i cant finished my project.
This is the tools that i dont have:
- gradient bars
- bevel selection
- power stretch
Maybe i dont have several tools but not fine it yet.. :( I appreciate if someone can tell me what happen to my paint.net.Thanks!
hello welcome to Paint.Net
these would be added plugins
here is the topic dealing with adding plugins
viewtopic.php?f=16&t=2023
read thru the whole topic page 1 to the end (26 pages.) and all questions re adding plugins will be answered.
then go to these to download the plugins.
viewtopic.php?f=16&t=22701&hilit=powerstretch
viewtopic.php?f=16&t=22819&hilit=bevel
viewtopic.php?f=16&t=21706
Wow OMA - that's an amazing tutorial (thanks) which taught me to use things I didn't know were possible with Paint.NET. Unfortunately I could not get the 'bend' to happen on the leaves :( Perhaps on my next attempt!
  • 3 weeks later...
:D go, Oma, go :D
Absolutely one of the best tutorials I've seen!
Took the idea a bit farther..
Everyone is getting unbelievably fine results :shock:
But eeeeh.. Opinions on this one?
Please forgive my possible complaints. I'm but an annoying little perfectionist when it comes to using english...
"I tremble in the presence of your terrifying skills of gardening."
you've done a fair job on that as a beginner. try some other tuts now and then come back. The bend portion is about the most unbegginner friendly item here. Its all where you place that x in the bulge or how you position your circle outline for power stretching. It takes practice but you are off to a real nice start in drawing. Remember this tut is to give you the basics only. It mainly teaches how to wand outside your outline drawing so you don't get cartoon outlines on things. That's the real secret to getting more realistic drawings.
:D go, Oma, go :D
well I don't think this is eeeeh at all. reminds me of a bunch of little christmas trees....lol! I think what you are not seeing is the little tiny stems on the individual leaves where they join to the bigger middle stem.
you are off to a fine start on drawing. glad you liked my little tut. I don't write many of them... but do often put little notes in with my pictures in my gallery, when I'm asked how did I do something.
welcome to you both will be watching for some fine art from you both.
ciao
OMA
sorry didn't notice yu asked a question till this morning.
now are you speaking of the first fill green gradiant?
there are several reasons this could be happening.
1) you've wand outside the leaf shape and have not then hit control + i (inverted your selection)
2) you may have the :AlphaChannel: set when it should be :AllColorChannels:
3) check your colors if you are using same color as the background it will not show up.
4) check you haven't set any colors as transparent opacity
last
don't laugh now anyone I did this when I first started.
5) my selection was correct on correct layer but I just cliked the two buttons and thought it would fill automatically with the gradiant.
you need to position your cursor where you want the one color to start left clik and drag your mouse in the direction the gradiant is to go.
off hand those are the things I can think of
If you check all of these things and its not still working upload a picture of your screen at the point where you clik the gradiants. I'm not sure what it is.
ciao
OMA
that would be because it is an additional plugin written to go with the basic Paint.Net. this tut requires 3 plugins.
I've added the links in the first part of the tut so you can find these add ons. also there is a link about how to add plugins that I added. you should read that entire thread.
I know I know its a lot of reading when you want to just jump in and make things. beleive me it will make your useage of this program a lot easier if you read those things first. Understanding will give you a better chance at making exceptional art.
ciao OMA
