Hardwood Flooring [Rewritten]
jerkfight
F. 1. New Layer
2. Paint the new layer brown, you can use my hex if you want.
3. Play with the layer proprities (F4)
4. Merge Layer down
G. 1.Depending on image size, you may want to play with these settings.
2.Press the jumble button untill you get a nice balence of dark and light wood.
3. Press OK when ready
H. Select every second line of wood like below.
I. Using the panelling effect move the selection horizontal by an amount of your choice.
J. Rotate/Zoom (Play with the selections that are boxed)
This is a common setting I use.
There we go.
Made the floor of this with the same method above.
Thanks for reading.
Jerkfight
At The Top
Check out my website at http://pspcenter.6.forumer.com
you must be fogetting to merge the layer down after playing with the layer properties.
I never did play w/ the layer properties. What Layer properties did u select?
i cant remember, but you must play with it or the whole thing will stay brown
try with other blending methods and you should get even better results
  • 4 months later...
I just wanted to show you this halfway finished tabled that i made.
Instead of Jumbling i just left the texture as it was and edited it a little and voila a table without legs(they are on there way i hope).
This is not finished yet i still need some work done on the bowl and maybe add some more details.
BTW nice tutorial Jerkfight
The Necroposting rule is suspended in the Tutorials forum. :-) Don't worry about it.
