Interface Orbs - Long and Image Heavy
-Expiration-
Nice result there Fuffuloo, glad you enjoyed my tutorial! :P
Thanks. Yeah, your tutorial was awesome. It wasn't something simple like, "doyawanna no hoto mek clouds? :D:):( :o you haveto start pdn and thenclik onteh clouds button. sometimes icnat' find the button doe. :x ykou have to look rillyhard inteh renderlist so ya," but at the same time it was easy to follow. Keep em up!
  • 3 weeks later...
  • 7 months later...
I need some help here please
In Step 12 by “Draw a white filled circle…” you mean to select the Ellipse Select (shortcut key: S) tool draw a circle and fill it with white or to select the Ellipse (shortcut key: O) tool on “Draw filled shape”, draw a white circle like you instructed in Step 2 “using the Ellipse tool on "Draw filled shape", draw a dark gray circle”
In Step 13 “Using a transparency gradient, draw a linear gradient …” how do I do this?
Thank you “Call me expired. Please.” I got it.
But in Step 13 “Then set the Transparency to about 50% Transparent.” setting Adjustments/Transparency 50% was a mess. So I double clicked the Layer Properties and set the Opacity to 100 (there is no % in that setting window) and it worked perfectly.
Thanks again.
Call me expired. Please. Your tut is one of the greatest.
Your place is on mount Olympus. But please think of us mortals.
It took me ages to figure out what I was doing wrong between “Draw a white filled circle…” and “Using a transparency gradient, …” I kept forgetting to change :AllColorChannels: to :AlphaChannel: and vice versa. Another thing that confused me was the Transparency % which for me newbie would have been better with the minus sign i.e. Then set the Transparency to about -50%
Well here is my try :)
26942_ddc37e3933c28fb258992cae07339b7b
Well i just had a bit of a go using this method to make an avatar 4 my self attached to the bottom is my effort
i had some troubble when it came to the rectangle reflections so i skiped that and i got totaly lost on the shadows so i improvised a little
29351_7cec6d84884ab117ed8a745d6c648475
