Hummel Posted June 15 Share Posted June 15 Hotkey Ctrl+Alt+V does not work. No new image created. From menu it works fine. Version - Stable 5.6.8544.33530 Quote Link to comment Share on other sites More sharing options...
BoltBait Posted June 15 Share Posted June 15 Check to see if your keys are working correctly: https://www.onlinemictest.com/keyboard-test/ 1 Quote Download: BoltBait's Plugin Pack | CodeLab | and a Computer Dominos Game Link to comment Share on other sites More sharing options...
Pixey Posted June 15 Share Posted June 15 2 hours ago, Hummel said: Version - Stable 5.6.8544.33530 Perhaps update to v 5.0.6 here: https://www.getpaint.net/ Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 15 Share Posted June 15 It does work, I use it every day. Your keyboard is probably failing and needs to be replaced. I'm not even joking, I'm not trying to be condescending, that's literally always the problem when someone reports something like this. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 15 Share Posted June 15 54 minutes ago, Pixey said: Perhaps update to v 5.0.6 here: https://www.getpaint.net/ They are using 5.0.6. 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Pixey Posted June 15 Share Posted June 15 8 minutes ago, Rick Brewster said: They are using 5.0.6. Ahh - I wasn't sure with all of those numbers 😁 Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Hummel Posted June 17 Author Share Posted June 17 On 6/15/2023 at 7:52 PM, BoltBait said: Check to see if your keys are working correctly: https://www.onlinemictest.com/keyboard-test/ Checked. Keyboard works fine. Quote Link to comment Share on other sites More sharing options...
Hummel Posted June 17 Author Share Posted June 17 On 6/15/2023 at 9:32 PM, Rick Brewster said: It does work, I use it every day. Your keyboard is probably failing and needs to be replaced. I'm not even joking, I'm not trying to be condescending, that's literally always the problem when someone reports something like this. In older versions it was working. I used it very often. In newer versions it does not. Keyboard checked https://www.onlinemictest.com/keyboard-test/ Maybe I should try it in some other programms to be sure? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 17 Share Posted June 17 We've also had at least one case where someone had another program that was intercepting the shortcut key and doing something else (or nothing) with it Ctrl+Alt+V does definitely 100% absolutely positively work though. Like I said, I use it every day Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Lemonade Posted June 17 Share Posted June 17 Try On-Screen Keyboard (press Win key > type "onscr", it will show up first in the menu list) and while paint.net is opened click on CTRL, ALT, V. Quote Link to comment Share on other sites More sharing options...
Hummel Posted June 21 Author Share Posted June 21 On 6/17/2023 at 8:51 PM, Lemonade said: Try On-Screen Keyboard (press Win key > type "onscr", it will show up first in the menu list) and while paint.net is opened click on CTRL, ALT, V. Nothing happens. Quote Link to comment Share on other sites More sharing options...
Disk4mat Posted June 22 Share Posted June 22 (edited) Are there any other shortcuts not working? Any other key combos related to the clipboard that wont work? CTRL + Shift + C CTRL + Shift + V Edited June 22 by Disk4mat Quote Link to comment Share on other sites More sharing options...
Pixey Posted June 22 Share Posted June 22 A couple of things to try: 1. Change the batteries in your keyboard? 2. Try another keyboard. 3. Try on another computer. Other programs that use this: What does the Ctrl + Alt + V keyboard shortcut? ‒ defkey Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
NinthDesertDude Posted June 22 Share Posted June 22 I've had this issue once on an older version of Paint.net; I solved it by being on a different computer. I think it might be my laptop that does that? I don't use it much though. In the meantime, Ctrl+N and Ctrl+V Edit: oh I remember what it was. It was key interception, and it was by John's Background Switcher. It has a shortcut for Ctrl+Alt+V. Quote Link to comment Share on other sites More sharing options...
Hummel Posted June 24 Author Share Posted June 24 On 6/22/2023 at 3:02 AM, Disk4mat said: Are there any other shortcuts not working? Any other key combos related to the clipboard that wont work? CTRL + Shift + C CTRL + Shift + V Other shortcuts work fine. Quote Link to comment Share on other sites More sharing options...
Hummel Posted June 24 Author Share Posted June 24 On 6/22/2023 at 4:04 PM, Pixey said: A couple of things to try: 1. Change the batteries in your keyboard? 2. Try another keyboard. 3. Try on another computer. Other programs that use this: What does the Ctrl + Alt + V keyboard shortcut? ‒ defkey 1) There are no batteries in my keyboard. 2) This was the first thing I tried. 3) This was the second. Please, do not post "dummy" solutions. Quote Link to comment Share on other sites More sharing options...
Hummel Posted June 24 Author Share Posted June 24 On 6/22/2023 at 6:30 PM, NinthDesertDude said: I've had this issue once on an older version of Paint.net; I solved it by being on a different computer. I think it might be my laptop that does that? I don't use it much though. In the meantime, Ctrl+N and Ctrl+V Edit: oh I remember what it was. It was key interception, and it was by John's Background Switcher. It has a shortcut for Ctrl+Alt+V. I think some program intercepts it in my case too. But I don't know how to find it. Quote Link to comment Share on other sites More sharing options...
Pixey Posted June 24 Share Posted June 24 49 minutes ago, Hummel said: Please, do not post "dummy" solutions. For this you will receive your first warning point and I hope you will learn some respect. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
