kdg130202 Posted June 10 Share Posted June 10 (edited) help! I tried several times, In the picture below you can see the original. I painted the background, but the seaweed was also painted. Please tell me how to fix it Edited June 10 by kdg130202 Quote Link to comment Share on other sites More sharing options...
Tactilis Posted June 10 Share Posted June 10 It's hard to know where to start trying to answer your question "Please tell me how to fix it" because it's not clear what you are actually trying to achieve. Nor is it clear what "It's all bordered" in your title really means. I'd suggest that you start by reading the Documentation (click the blue question mark icon top right in Paint.NET) which takes you here https://www.getpaint.net/doc/latest/ To help with your problem, I think you need to understand how to use layers so that you can keep the different elements of your picture separate and only merge them together when you are finished. See https://www.getpaint.net/doc/latest/WorkingWithLayers.html 1 Quote Link to comment Share on other sites More sharing options...
Disk4mat Posted June 10 Share Posted June 10 This looks like it is either 2 or 3 layers? The seaweed is on one layer, you filled another layer black and the inside of the seaweed also turned black? You didnt give us much to go on. But I am curious on one point. Why not change the primary color in your palette to the green (using the color picker tool) and just paint your seaweed back to how you want it? A brush size of 12 could mop that up in seconds. Quote Link to comment Share on other sites More sharing options...
