kilbanne Posted May 26 Share Posted May 26 (edited) Hi there, For the past 2 months, i've been editing and adjusting artistic photos for a portfolio. This work is tiresome and i have to do the same thing over and over again. What i do is create a new empty layer, than set it to Filter/Screen, and put opacity on 30. Then i'm all set to do all kinds of illuminations and play around with this layer, the problem is, creating this layer, and set the opacity to 30, for over 2000 images, is really anoying and time consuming. I have codelab on my plugins, but i'm no programmer. Can anyone help me with a quick script for Codelab, to make this repetitive task into an effect, so i can just Ctrl+F and repeat it for every image i edit? If this is asking to much, i apologize in advance. God bless you. Edited Tuesday at 08:40 PM by kilbanne Quote Link to comment Share on other sites More sharing options...
null54 Posted May 26 Share Posted May 26 25 minutes ago, kilbanne said: Can anyone help me with a quick script for Codelab, to make this repetitive task into an effect, so i can just Ctrl+F and repeat it for every image i edit? Plugins cannot create layers or change the layer opacity. 2 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Lemonade Posted May 26 Share Posted May 26 (edited) 4 hours ago, kilbanne said: What i do is create a new empty layer, than set it to Filter, and put opacity on 30. Then i'm all set to do all kinds of illuminations and play around with this layer, the problem is, creating this layer, and set the opacity to 30, for over 2000 images, is really anoying and time consuming. Hey @kilbanne, try Auto Hotkey (https://www.autohotkey.com/) to speed up the process. Here is a set of steps to set active layer opacity to 30, instead of Ctrl + F (by default in paint.net is mapped to apply last filter) it is set to Ctrl + Alt + F. Create new file (Notepad is enough) and save as .ahk extension, then paste inside: ; paint.net #HotIf WinActive("paint.net") ^!f:: ; Ctrl+Alt+F hotkey - Set active layer opacity { Send "{f4}" ; Open layers window Send "{Tab down}{Tab up}" ; Switch to opacity slider Send "{Tab down}{Tab up}" ; Switch to opacity input SendText "30" ; Set opacity number Send "{Enter down}{Enter up}" ; Confirm changes and close layers window } Double click on saved file should run the script (check taskbar for green H icon), and while paint.net is opened Ctrl + Alt + F should set layer opacity. I don't understand what do you mean "...than set it to Filter," part. Is it Blend mode? Edited May 26 by Lemonade Ctrl + Shift + F is for flatten, changed to Ctrl + Alt + F 1 Quote Link to comment Share on other sites More sharing options...
kilbanne Posted Monday at 07:53 PM Author Share Posted Monday at 07:53 PM (edited) Hey @Lemonade, Thank you for spending your precious time to help me with my problem, i appreciate it. I'll use your suggestion, i didn't know plugins coudn't create layers like this. And yes, i meant Filter = Screen blend mode. Godspeed my friend. Edited Tuesday at 08:39 PM by kilbanne On my language, filter = screen. Sorry about that Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted Tuesday at 07:59 PM Share Posted Tuesday at 07:59 PM There's no blend mode named "Filter" though 🤔 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Lemonade Posted Tuesday at 09:42 PM Share Posted Tuesday at 09:42 PM On 5/29/2023 at 9:53 PM, kilbanne said: And yes, i meant Filter = Screen blend mode. Ah, now I understand I was confused if Filter is applied Effect or layer Blend mode. Or maybe a new empty layer named Filter. Quote Link to comment Share on other sites More sharing options...
Lemonade Posted Tuesday at 10:08 PM Share Posted Tuesday at 10:08 PM Here is a modified script (well, not really a script, just a set of hotkeys for execution), where layer blend mode is set to Screen and opacity to 30: ; paint.net #HotIf WinActive("paint.net") ^!f:: ; Ctrl+Alt+F hotkey - Set active layer opacity { Send "{f4}" ; Open layer window Send "{Tab down}{Tab up}" ; Switch to opacity slider Send "{Tab down}{Tab up}" ; Switch to opacity input SendText "30" ; Set opacity number Send "{Tab down}{Tab up}" ; Switch to blend mode Send "{s}" ; Set blend mode to Screen Send "{Enter down}{Enter up}" ; Confirm changes and close layer window } Open your image in paint.net CTRL + SHIFT + N (default paint.net hotkey to create new empty layer) CTRL + ALT + F (apply layer opacity and blend mode with Autohotkey), use this while new layer is selected (active) in the layers panel I tried including Add new layer in the "script" too, but there is some weird behavior in Windows (didn't check what the reason for that is). Quote Link to comment Share on other sites More sharing options...
