FoolCoyote Posted October 11, 2008 Share Posted October 11, 2008 Hiya! I'm very new to this program, and am wondering if it is possible to make a solid color, semi transparent (as in 50% 60% transparent and so on). The reason I ask, is that I am working to design some profile pages for my site, and I can't make the table transparency codes I have found work at all, so what I am hoping to do, is insert them directly into existing table codes. So basically here's my question, I am wanting to learn to take a square, rectangle etc, of a solid color, red, black, or green for examples, and make them transparent, so that once they are inside the site code, they will be transparent enough to support font color, and still not kill the background image. Any help will be insanely appreciated! Thanks! Slan Quote Link to comment Share on other sites More sharing options...
jiZer Posted October 22, 2008 Share Posted October 22, 2008 Not sure what you mean, but you can make it on a new layer and press propities and change the opacity or use THIS plugin. Quote Simplicity ftw! Link to comment Share on other sites More sharing options...
