AndWeWereFlying Posted October 10, 2008 Share Posted October 10, 2008 I just did a ton of work on my project, but the layers switched on me and now I did about half my project in the wrong layer...is there anyway possible to retrieve it or move it to a new layer? Quote Link to comment Share on other sites More sharing options...
Simon Brown Posted October 10, 2008 Share Posted October 10, 2008 Do you need to be able to use the content you have overwritten or simply seperate one set of content from another? Quote Link to comment Share on other sites More sharing options...
Simon Brown Posted October 10, 2008 Share Posted October 10, 2008 If the project is still open and has not been closed since, save it and then keep pressing Ctrl-Z until the work you have done on that layer has been undone, then save under a different name. Open the first image, use the selection tools to delete all other content on that layer, save just that layer (under a seperate name) and combine this with the image you saved after Ctrl-Z. Quote Link to comment Share on other sites More sharing options...
asian_skillz Posted October 10, 2008 Share Posted October 10, 2008 If the project is still open and has not been closed since, save it and then keep pressing Ctrl-Z until the work you have done on that layer has been undone, then save under a different name. Open the first image, use the selection tools to delete all other content on that layer, save just that layer (under a seperate name) and combine this with the image you saved after Ctrl-Z. Wow I never knew this either. I made this same mistake the other day and had to start all over. Thanks simon. Quote Link to comment Share on other sites More sharing options...
AndWeWereFlying Posted October 11, 2008 Author Share Posted October 11, 2008 Ah...I see now! but, after I select it, because the work was done on the background (which is a sketch) it's not getting rid of the stuff I already did.... Is there no way to just undo the work, undo the part where I switched layers, and then redo all the work without actually doing it all by hand again? Quote Link to comment Share on other sites More sharing options...
