FuzzyFerrets Posted May 3, 2008 Share Posted May 3, 2008 I'm having trouble with this part... Move this layer above the black box layer. Then select the black box layer and use the magic wand to select the box. You can then use the "move selection" tool to elongate the box so that it creates a white frame around the picture. I selected the box and used the move selection tool to elongate, but when I deselect it doesn't leave a white box around the picture. Please guide me a little more on this. Quote Link to comment Share on other sites More sharing options...
FuzzyFerrets Posted May 3, 2008 Share Posted May 3, 2008 At last I finished one and am elated. Here it is. Quote Link to comment Share on other sites More sharing options...
oneluvnmama Posted May 7, 2008 Share Posted May 7, 2008 ok so i am lost and i have been reading all these replies closely and i am not understanding... i get to the black box and then i get everything around it deleted so now i have three layers...ok... so now where do i get the forth layer from with the box with the pic in it that wasnt deleted. that way all together ihave four layers.... man i am so lost.... add yahoo to my name and you can PM me if you have time to help me step by step becuase i am so lost.... Quote Link to comment Share on other sites More sharing options...
Uneyed Posted May 12, 2008 Share Posted May 12, 2008 Here is my stab at it. Thanks for the tutorial. Quote Link to comment Share on other sites More sharing options...
WatcherSenior Posted May 20, 2008 Share Posted May 20, 2008 I like it... Here is my go.. for some reason the frame didn't do right. I kinda like it without it though. Quote Wait...What? Link to comment Share on other sites More sharing options...
Simon Brown Posted May 20, 2008 Share Posted May 20, 2008 You may also want to use feather on the image. Welcome to the forums. Quote Link to comment Share on other sites More sharing options...
amberdenver Posted May 21, 2008 Share Posted May 21, 2008 Here is my second attempt at a pop out. Quote Link to comment Share on other sites More sharing options...
Saabo Posted July 25, 2008 Share Posted July 25, 2008 "Select the black box and then select the second picture layer. Invert the selection and hit delete so all that remains is the picture that is in the shape of the box." I really dont get how to do this ... I select the black box layer then invert it then click the second picture layer and press deleate but them nothing happens... Please tell me the solution as id love to be able to do this. Quote My Gallery Link to comment Share on other sites More sharing options...
Kat Posted July 27, 2008 Share Posted July 27, 2008 The tut has had some little traps for me, but I think I found the solution(s) to them all okay. Here's what I did: ~~~~~ Then I thought it might be nice to add some bevel: Quote Link to comment Share on other sites More sharing options...
Saabo Posted July 30, 2008 Share Posted July 30, 2008 Sigh when ever i try i get the same problem Quote My Gallery Link to comment Share on other sites More sharing options...
Kat Posted July 30, 2008 Share Posted July 30, 2008 Saabo, I have an idea what connects wrong in your brain... First you work on the level where you have this black box ... then you select the box (meaning: you have the ants running around it). Then you change to the other level and on that other level you hit delete. That should solve your problem! Good luck, I'm looking forward to your result! Quote Link to comment Share on other sites More sharing options...
claire-babee Posted July 31, 2008 Share Posted July 31, 2008 i just cant seem to get the hang of this at all Quote Link to comment Share on other sites More sharing options...
Kat Posted July 31, 2008 Share Posted July 31, 2008 At which point do you get stuck? :?: Quote Link to comment Share on other sites More sharing options...
claire-babee Posted July 31, 2008 Share Posted July 31, 2008 i get stuck right from the beginning well i can get the duplicate layer and the new layer but its from the box i get stuck im new to this only got the program last night Quote Link to comment Share on other sites More sharing options...
rocknroll93 Posted July 31, 2008 Share Posted July 31, 2008 good tut! here is my stab... or should i say slash:?: i know i screwed up with the hair, but, im too lazy Quote Link to comment Share on other sites More sharing options...
LFC4EVER Posted July 31, 2008 Share Posted July 31, 2008 Batman on his bike, coming out the TV to get you! Original stock is on the official Dark Knight movie site. Quote ☆★☆★Merry Christmas★☆★☆ .::.My Gallery.::.Make Gold Text!.::. Link to comment Share on other sites More sharing options...
claire-babee Posted July 31, 2008 Share Posted July 31, 2008 i think i may finally have it although i missed a bit at the top of the bairns head but apart from that what do you think Quote Link to comment Share on other sites More sharing options...
ccll Posted August 5, 2008 Share Posted August 5, 2008 I must not be new anymore since I did exactly as David Atwell suggested to use the filled rectangle with rotate/zoom to get the right angle on the box. As I have stated previously, I am not good at using the lasso tool which I am sure is very effective in some instances, so I used the Cutting out images tut. What took the longest, to me, was find the right picture for this. As I work on the tut more and more, I am sure I will find it easier to pick out fabulous pics to use. Here is my attempt and I am very proud of the results: Quote Isn't Life A Dream? Pages I have worked on using paint.Net Link to comment Share on other sites More sharing options...
JJgunz Posted August 14, 2008 Share Posted August 14, 2008 heres my go at it Quote Xfire:lilchris254 My Gallery Link to comment Share on other sites More sharing options...
lanky11 Posted August 27, 2008 Share Posted August 27, 2008 after the black box I could not understand it as I am very new and just learning so I made this I know it is not good but I am just starting I made face using wingdings Quote Link to comment Share on other sites More sharing options...
someone93 Posted August 30, 2008 Share Posted August 30, 2008 My try with it... Quote Link to comment Share on other sites More sharing options...
rtargo20 Posted September 10, 2008 Share Posted September 10, 2008 This is a great tut. It's amazing how the results look. Here's my try. These old shakey hands have a problem getting the selection better. I tried Feather many, many times but it didn't clean up the edges very good. Would Blur be better? This is a Fish Out of Water...... Quote Is it me --or do buffalo wings taste like chicken? Link to comment Share on other sites More sharing options...
kwasko Posted September 18, 2008 Share Posted September 18, 2008 Here's my attempt using Jack Harkness from Torchwood. Quote Link to comment Share on other sites More sharing options...
dleonseng Posted September 18, 2008 Share Posted September 18, 2008 first try my favourite car of all times, now my favourite wallpaper Quote Link to comment Share on other sites More sharing options...
JagWire Posted September 20, 2008 Share Posted September 20, 2008 Here's my try: **hint: he's trying to imitate a 'liger' lol Quote Link to comment Share on other sites More sharing options...
