welpmixes Posted February 26, 2023 Share Posted February 26, 2023 (image quality lowered due to file limitations) i tried to create a drop shadow by duplicating the layer and making the color similar to a drop shadow of PS (i've used photoshop before but then my laptop stopped working so i borrowed one from my mother, it's running windows 7 which is why i'm using version 3.5.0) if anyone has any plugins for version 3.5.0 it would be amazing if you could share it with me. (context for image: its for my discord server, wip image) Link to comment Share on other sites More sharing options...
Rick Brewster Posted February 26, 2023 Share Posted February 26, 2023 No support is provided for old versions. You must install the latest version, which is currently 5.0.2 and which has a built-in drop shadow effect. You may need to update your PC first. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
