Power Reactor? (Stuff with hexagrid...)
MadJik
This tutorial was inspired by the following tutorial:
viewtopic.php?f=31&t=26987
It basically puts steps 1-6 (of that tutorial)in a script and then tells you the rest of the steps in my easy to understand revision.
1.Okay first download the script for scriptlab.
(Located at bottom of page.)
2.Then run it in scriptlab.
3.Then duplicate the layer and set it to darken.
4.Horizontally flip the layer.
5.Flatten the image.
6.Play with the curves.
7.Duplicate the layer.
8.Set the blend mode to lighten.
9.Zoom blur deluxe on that layer.
Amount: 4th Notch
Rest: default
10. Repeat step 9 until the image is to your liking.
Power Reactor Script:
http://www.mediafire.com/download.php?nednuoky2gk
Always post updates to tutorials as replies to that tutorial, unless you make major changes.
  • 3 weeks later...
Hey great tutorial here is what I came out with after playing with it a bit.
On a new layer:
I used Julia Fractal with a Factor-10, Zoom -1, Angle - 0.00, Quality-5
Then Zoom Blur Deluxe with the Amount Full, (Center: X- 46, Y- 52), Quality - Low
Hope you like!! :)
"A hero is no braver than an ordinary man, but he is brave five minutes longer." -Ralph Waldo Emmerson
"A single enduring statement can grant immortality." -Author Unknown (This is what we call "Irony")
On a new layer:
Hope you like!! :)
I've tried this tut, and I'm not going to upload my original outcome, because it almostly looks the same like the one in the tut itself :) .
I've been using the effect very frequently, and a few of this works:
Hexagonwallplanetwallpaper
Christmas Snowflake-like sig
An banner for an pokemon radio website(Combee combination :o )
Cool Big-art the hexagonplanet thingy no 2:
Wich I used to make my current Ava and sig from:
Note: this is my first post here, this works were earlier uploaded at another forum. But I was using the tuts from here :wink: .
  • 3 weeks later...
