Sign in to follow this
Hannah Prower
Making Backgrounds of Images Transparent
I have no clue if some of you know how to do this already, but I will show you how to make the backgrounds of images with solid white backgrounds transparent.
Step 1: Go to File-->Open :FileOpen: and open the image in which you want to make the background transparent.
  • Before:
Step 4: Select the Magic Wand tool :MagicWandTool: and set the Tolerance level to 25% (or anything depending on your image. I would recommend 25% for sprites/pixel images.). Click somewhere on the background.
Step 5: Go to Edit-->Cut. :EditCut: You should see a "checkerboard" pattern where the image is now transparent.
Step 6: File-->Save As... :SaveAs:
Select a file type of PNG or GIF before clicking the Save button.
  • After:
This is a good tut for newbies who want to learn how to do this.
I'm really struggling to make this work, although it looks so simple. The area I want to make transparent is checker-boarded in Paint.NET, I save the image, but when I subsequently use the image, the white background is still there. Any help appreciated.
Share this post
Link to post
  • Before:
  • After:
i knew how to do this. but instead of leaving the background blank i put a splattered paint background =]
Share this post
Link to post
The only reason I tried PDN was for transparent backgrounds then I found this tut. Then I saw the other tuts and I figured out you can do so many cool things with PDN. So if any newbies are reading this, don't give up on PDN you can do very cool things with it. Try looking at other tuts and mess around with it.
Share this post
Link to post
Thanks for the tutorial =)
Do you play MapleStory? Because your sig and stuff look just like the peoples from it.
Yup =) , I play MapleStory x)
Cool :D I used to but I got banned :cry: I got banned because I bought NX cash at a sleep over >_> Anyways what world? I was in Bellocan when I played. I wish I could see my guild again....
Share this post
Link to post
Hi all, I am new to this game, I am trying to make a splashscreen, I have the background I want and I have a template (which is text) and I would like to know how to make template appear on top.
Share this post
Link to post
I have been waiting all week for help with my problem, the whole thread seems to gone dead......... :?: :cry::cry:
Share this post
Link to post
oo thanks this helped me out :)
me.gif hehe i made that after i took the old white background out then i added the girl to the polka dot background and used one of the effects
Share this post
Link to post
First off, Paint.NET isn't a game. If you had the program you would probably know that.
If you're speaking of a 'computer game' search that game and visit a fan site, I'm sure they tell you how to make a splash screen there. :wink:
Share this post
Link to post
Sometimes when people say : game...it doesn't always mean game.
I'm new to this game could mean I'm new to PDN.
@Maurice1940: Others might not understand what you are asking for, so no answer.
Try to ask in Questions & General Discussion with more info and maybe some pic.
Share this post
Link to post
Thanks Ash, I always forget that other may not interpret things as the same as I do, but you have got it right I am new to, not just PND but to the painting system entirely, I. to offend those who were offended.........
Share this post
Link to post
I wonder if anyone could help me at all? Following one of the tutorials, I made a planet which I have on one layer. I used the magic wand tool to cut away the background, and I can see the checkerboard pattern mentioned before. In another layer I have the background I want to use. What I can't seem to do is find a way to make the planet sit on top of the background. If I try to merge the two layers, all I see is the background layer. Help!
Edit: I found a way to do it, with selecting the gap around the planet, copying it onto the background, inverting the selection, then deleting that part... but surely there must be an easier way that doesn't mean having to delete large chunks of background?
Share this post
Link to post
Use the arrows on the Layers window to move the background to the bottom of the stack.
Does that help?
It does something, but not what i was trying to do lol... the background is black with pinpoints of pale colour (my attempt at stars), and the planet is blue. If the background is first on the list of layers, the stars show their original colours. If I move it down the list, the blue of the planet shows through them. I was trying to get the planet on top of the whole of the background.
Share this post
Link to post
Two things...first, make sure the planet layer is on top (think of layers as sheets of paper). Secondly, double click on the planet layer and make sure that the opacity (how clear is your paper) is set all the way up to 255 and the blend mode is set to normal. Any luck?
Share this post
Link to post
Hi Hannah or anyone who can help, ok I did as Hannah said and used the magic wand after doing all she said I saved it to both PNG and GIF but when I open the file up again it still has the checker board background. So how to I make the checkerboard background disappear and just leave me the image.
Many thanks
Blu
9242_6388599be92046f1538744a5a9205471
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
