Hotkey for Hue/Saturation does not work.
Go to solution Solved by D4rkCl0uds,
"Ctrl + Shift + U" does not apply "Hue/Saturation". This is infuriating, as I sometimes have to apply effects to about 25+ images in a row. I use all the other hotkeys to do this task very quickly. Not sure if there's a reason, I'm just pointing it out.
That hotkey is working for me in PDN 5.0.1.
Are you running the English version of Paint.NET?
Are you running the English version of the OS?
Are you using an English keyboard?
Are you using some "funky" laptop keyboard that requires holding down an FN key for some functionality that a normal keyboard doesn't need?
Click to play:
  • Solution
Sorry you guys, I forgot about this.
I tested my keyboard, turns out it registers all the other input combinations, except that one... The problem is my keyboard.
Thank you.
Edited by D4rkCl0uds
Solution
