Bert Speggly Posted January 25 Share Posted January 25 Is there a way to divide the circumference of a circle into 32 parts? Thanks Bert Quote Link to comment Share on other sites More sharing options...
BoltBait Posted January 25 Share Posted January 25 If you have my plugin pack installed, you can Effects > Render > Polygon/Stars a shape with 32 verticies: My plugin pack can be downloaded here: https://forums.getpaint.net/BoltBaitPluginPack Hope this helps! Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
BDP Posted January 25 Share Posted January 25 I wonder if Bert Speggly really meant a circle like a pie chart, like this one I drew quickly with the Spoked Wheel effect? Brian Quote Link to comment Share on other sites More sharing options...
MJW Posted January 25 Share Posted January 25 Another method, if radial lines are what are wanted, is to use Red Ochre's Gears plugin. Run the plugin (in the Iterative Lines subfolder), and set Tooth height, Shaft hole radius, and Collar Rim width to zero. Set Number of spokes to 32. 1 Quote Link to comment Share on other sites More sharing options...
BoltBait Posted January 25 Share Posted January 25 3 hours ago, BDP said: I wonder if Bert Speggly really meant a circle like a pie chart If the OP wanted a Pie Chart, I would highly recommend using my Effects > Render > Chart plugin: 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
