null54 Posted January 22 Share Posted January 22 I am trying to convert my Content Aware Fill plugin to a BitmapEffect. The effect creates a new PdnRegion representing the area outside of the selection that the plugin uses for sampling, this region is then converted to a mask bitmap. private PdnRegion CreateSampleRegion() { if (this.sampleSize < 0) { throw new ArgumentOutOfRangeException(nameof(this.sampleSize), "The sample size cannot be negative."); } Rectangle[] expandedScans = this.selection.GetRegionScansInt(); for (int i = 0; i < expandedScans.Length; i++) { // Expand each scan rectangle by the specified number of pixels. expandedScans[i].Inflate(this.sampleSize, this.sampleSize); } PdnRegion sampleRegion; using (PdnGraphicsPath path = new()) { path.FillMode = System.Drawing.Drawing2D.FillMode.Winding; path.AddRectangles(expandedScans); sampleRegion = new PdnRegion(path); } // Clip the expanded region to the surface bounds and exclude the original selection. // Excluding the original selection prevents sampling from the area that is to be replaced. sampleRegion.Intersect(this.sourceBounds); sampleRegion.Exclude(this.selection); return sampleRegion; } What would the equivalent IGeometry code be? ID2D1GeometrySink does not have an AddRectangle method, so I assume that the rectangles would have to be converted to lines. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 22 Share Posted January 22 You're using this for a mask bitmap? If so then I would create an Alpha8 bitmap and draw into it using FillRectangle() calls. Geometry operations can be quite slow for a complicated selection, but deviceContext.DrawRectangle(RectInt32.Inflate(rect, this.sampleSize, this.sampleSize), brush) should be reasonably fast for this scenario. IImagingFactory imagingFactory = this.GetService<IImagingFactory>(); IDirect2DFactory d2dFactory = this.GetService<IDirect2DFactory>(); IBitmap<ColorAlpha8> maskBitmap = imagingFactory.CreateBitmap<ColorAlpha8>(width, height); using (IDeviceContext deviceContext = d2dFactory.CreateBitmapDeviceContext(maskBitmap)) { using ISolidColorBrush fillBrush = deviceContext.CreateSolidColorBrush(Colors.White); using (deviceContext.UseBeginDraw()) { deviceContext.Clear(Colors.Black); foreach (RectInt32 rect in selectionRects) { deviceContext.FillRectangle(RectInt32.Inflate(rect, this.sampleSize, this.sampleSize), fillBrush); } } } Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
null54 Posted January 22 Author Share Posted January 22 1 hour ago, Rick Brewster said: You're using this for a mask bitmap? Yes, but my mask bitmap is custom MaskSurface type a not a WIC Bitmap. This avoid having to lock and unlock the bitmap when using it. One issue that I see with your proposed code is that the original selection rectangle is not excluded, but that could be solved with a second FillRectangle call. Does FillRectangle already handle clipping the rectangle to the image bounds? I also need the bounds of the expanded region, but I can get that from the scan rectangles. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
null54 Posted January 23 Author Share Posted January 23 @Rick Brewster I got your FillRectange code sample working, but Direct2D ignores the second FilllRectangle call that I am trying to use to mask out the selection. IBitmap<ColorAlpha8> sourceMask = this.imagingFactory.CreateBitmap<ColorAlpha8>(this.environment.Document.Size); IDirect2DFactory d2dFactory = this.serviceProvider.GetService<IDirect2DFactory>(); RectInt32 maskBounds = RectInt32.Empty; using (PaintDotNet.Direct2D1.IDeviceContext deviceContext = d2dFactory.CreateBitmapDeviceContext(this.sourceMask)) { using (ISolidColorBrush selectedRegionBrush = deviceContext.CreateSolidColorBrush(Colors.White)) using (ISolidColorBrush unselectedRegionBrush = deviceContext.CreateSolidColorBrush(Colors.TransparentBlack)) using (deviceContext.UseBeginDraw()) { IReadOnlyList<RectInt32> selectionRects = this.environment.Selection.RenderScans; RectInt32 surfaceBounds = this.sourceMask.Bounds(); deviceContext.Clear(Colors.TransparentBlack); foreach (RectInt32 rect in selectionRects) { RectInt32 expandedRect = RectInt32.Inflate(rect, this.sampleSize, this.sampleSize); RectInt32 selectedArea = RectInt32.Intersect(expandedRect, surfaceBounds); deviceContext.FillRectangle(selectedArea, selectedRegionBrush); // Exclude the pixels in the original selection. // Direct2D ignores this command. deviceContext.FillRectangle(rect, unselectedRegionBrush); maskBounds = RectInt32.Union(maskBounds, selectedArea); } } } The alternative approach I have been considering is drawing the mask outline using 4 rectangles, but I would like to avoid that if possible. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 23 Share Posted January 23 3 hours ago, null54 said: @Rick Brewster I got your FillRectange code sample working, but Direct2D ignores the second FilllRectangle call that I am trying to use to mask out the selection. That's because it's transparent and blending is enabled by default -- you need to set the PrimitiveBlend property to PrimitiveBlend.Copy. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
