Help with editing objects in a monogram
I'm new to the forum and I tried to search for the answer to this question, but I couldn't find it. Sorry if this is a duplicate!
I've been trying to make monograms using different layers. When I go back to an object in a layer, how can I move it (or in case of the text, change the color?) Once the box you use to drag an object around the screen is gone, I can't seem to get it back.
Also, how can you change the order of the layers?
Thanks for your help.
