geist_ Posted January 6 Share Posted January 6 // Name: // Submenu: // Author: // Title: // Version: // Desc: // Keywords: // URL: // Help: #region UICode #endregion class MyForm : Form { public MyForm() { this.InitializeComponent(); } System.ComponentModel.IContainer components = null; protected override void Dispose(bool disposing) { if (disposing && (components != null)) { components.Dispose(); } base.Dispose(disposing); } private void InitializeComponent() { //UI stuff this.components = new System.ComponentModel.Container(); this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font; this.ClientSize = new System.Drawing.Size(800, 450); this.Text = "MyForm"; } } void Render(Surface dst, Surface src, Rectangle rect) { global::System.Windows.Forms.Application.EnableVisualStyles(); global::System.Windows.Forms.Application.SetCompatibleTextRenderingDefault(false); global::System.Windows.Forms.Application.SetHighDpiMode(HighDpiMode.SystemAware); Application.Run(new MyForm()); } Tried it like this, and it works only the first 3-4 times you call the effect, after the 3-4 time, paint.net crashes the it displays the following exception: Quote Exception details: System.InvalidOperationException: SetCompatibleTextRenderingDefault must be called before the first IWin32Window object is created in the application. In the code above I am calling Application.SetCompatibleTextRenderingDefault() before i call Application.Run, so why is it not working if you keep using the effect more than 3 or 4 times? I am running this in a Single Render Call effect plugin Quote the usual Link to comment Share on other sites More sharing options...
midora Posted January 6 Share Posted January 6 Your are developing a plugin and not an application. Derive you effect plugin from PaintDotNet.Effects.Effect and override CreateConfigDialog. There you should return a new dialog derived from EffectConfigDialog. This is the dialog you can populate with your own controls. 1 Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted January 6 Share Posted January 6 What @midora said. Those calls into System.Windows.Forms.Application are not for plugin use. Paint.NET already configures those at application startup. You do not use Application.Run() in a plugin. Paint.NET calls your CreateConfigDialog() method and then displays the Form you return. 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 7 Share Posted January 7 Seen these? I'm not sure if @toe_head2001 is maintaining them, but they are a great starting point to creating effects with a custom UI. 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
toe_head2001 Posted January 7 Share Posted January 7 57 minutes ago, Ego Eram Reputo said: I'm not sure if @toe_head2001 is maintaining them They haven't been updated in a long time. It's been a low priority. And they need to be rewritten for the brand new Effect system in Paint.NET 5. 2 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
geist_ Posted January 11 Author Share Posted January 11 On 1/7/2023 at 5:13 AM, Ego Eram Reputo said: Seen these? I'm not sure if @toe_head2001 is maintaining them, but they are a great starting point to creating effects with a custom UI. Thank you! This is exactly what I needed, I have been struggling til now to get ConfigDialog and ConfigToken to work. Quote the usual Link to comment Share on other sites More sharing options...
