mdrejhon Posted December 7, 2022 Share Posted December 7, 2022 (edited) Hello, I have a workflow that requires me to convert screenshots into R,G,B layers (Blend: Additive). I simply clone into 3 layers and convert each one by one to R/G/B via curves, and use Blend: Additive. It works. (There are times where I need to shift a specific color channel by a pixel left or right, for a special compensation purpose, which is why I am doing things in Paint.net, since it has a great live preview) Normally, I use Ctrl+A followed by Ctrl+Shift+M to bring the Curves up, go RGB, and quickly deselect one and clamp the rest down. But if I've edited Layer Properties and dismissed it, and now I need to change curves, Ctrl+Shift+M doesn't work after I dismissed the Layer Properties window by hitting Enter (type new layer name, tab, tab, hit "A" for Additive, then hit Enter to dismiss Layer Properties). So I am forced to click on the image, often while I have a specific part of the image selected (for pixel shifting only part of an image for only one color channel) But when I click the next layer in Layers, I can no longer Ctrl+Shift+M until I click on the window (which sometimes causes me to accidentally click something or move the image a few pixels around, if I'm rushing through the steps). Question/Suggestion: --> Is there a hotkey that instantly refocuses keyboard back to the image, rather than the Layers window? (So that I can hit Ctrl+Shift+M afterwards) --> Or can the software be fixed to passthrough unrecognized keypresses (e.g. Ctrl+Shift+M is not used by Layers window) back to the main window? (Or simply refocus the main window after dismissing Layer Properties) Since I am whipping through dozens of images, eliminating accident-prone clicks (especially if I have something selected), is favourable and would speed up my workflow by about 25% since I have found hotkeys to go most of everything -- except this non-responsive Ctrl+Shift+M step right after dismissing Layer Properties window by hitting Enter. Edited December 7, 2022 by mdrejhon Quote Link to comment Share on other sites More sharing options...
BoltBait Posted December 7, 2022 Share Posted December 7, 2022 Can you try your workflow on the Paint.NET v5.0 beta posted below: https://forums.getpaint.net/topic/121430-paintnet-50-beta-build-8376/ Let us know if the keyboard shortcuts are still a problem. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 7, 2022 Share Posted December 7, 2022 Yes, this is something that should be fixed in the 5.0 beta, so be sure to try it there Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
