Rick Brewster Posted December 9, 2022 Author Share Posted December 9, 2022 25 minutes ago, midora said: Accessibility: Mouse Pointer Size If paint.net could adjust is cursors using the multiplier provided in HKEY_CURRENT_USER\SOFTWARE\Microsoft\Accessibility\CursorSize then this would help some users. In the moment only the standard arrow and move selection adjusts its size. Size is 16 * (CursorSize + 1). CursorSize [1..15]. BTW: I'm getting the system move cursor for Move Selection and Move Selected Pixels. I thought that earlier they looked more like the icons in the tool window but it's the same in 4.2.16 (win 10) so maybe I'm wrong. I've filed an issue over on GitHub and I'll look at it for a 5.0.x release. The cursor you're seeing for the Move tools is correct. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 9, 2022 Author Share Posted December 9, 2022 New build with new fixes: The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Pixey Posted December 10, 2022 Share Posted December 10, 2022 I know this is locked, but thought I'd post a glitch I had in this version when I used Ctrl Z (no, I clicked back to Merge layer down) to go back a few layers after a flatten. I've tried to reproduce it, but it's not happened again. It may be a problem my end. 1 How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 11, 2022 Author Share Posted December 11, 2022 Yeah I’m able to get that to happen too. I should be able to fix it for the next build 1 The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 12, 2022 Author Share Posted December 12, 2022 Okay I managed to fix that bug, @Pixey. As it turns out, it's been there since December but we never ran into it! I was able to reproduce it easily with the following actions: New Layer, Delete Layer, New Layer, Duplicate Layer, New Layer, Move Layer (top to bottom), Move Layer (bottom to top), Merge Layer Down, Delete Layer, Delete Layer. Then, clicking between the final Delete Layer and that first Delete Layer would cause the glitch to show up every single time. 1 The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
