CodeLab v6.8 for Paint.NET 5.0 (Updated January 22, 2023)
Hmmm... that gives me an interesting idea...
I wonder if a file type plugin could be written that would "open" a dll file by copying it to the effects folder.
This would allow someone to right-click on an effects dll and choose "open with Paint.net" to install the effect.
Then you'd be screwed if you set PdN as the default program for handling .dll's!
What is the symbol you use at the end????
I don't understand your question. Could you be more specific?
The "end" of what, exactly? What error are you seeing?
type or namespace definition, or end of file expected (CS1002)
Do you know what this is?
Broken toaster =
(Rushes to HomeBase!)
Show me your code.
Click to play:
{ // How big is your box of chalk?
double BaseColors = 72; // 1-360, step 1, Default = 72
PdnRegion selectionRegion = EnvironmentParameters.GetSelection(src.Bounds);
Rectangle selection = this.EnvironmentParameters.GetSelection(src.Bounds).GetBoundsInt();
ColorBgra CurrentPixel;
double Q = 360 / BaseColors;
double H = 0,S = 0,V = 0;
		if (selectionRegion.IsVisible(x, y))
			CurrentPixel = src[x,y];
			; (CurrentPixel.R,CurrentPixel.G,CurrentPixel.B,ref H,ref) S,ref V); (CS1026)
			H = Q*(double)Math.Round(H/Q); // Normalize Hue
			if (S > .15) // Compress Saturation
				S = ( (0.35*(S-0.15)) / (1.0-0.15) ) + 0.15;
			if (V > 0.05) // Compress Value
				V = ( (0.15*(V-0.05)) / (1.0-0.05) ) + 0.85;
			else // Near Black Pixels
				S = 0; // turn them gray
				V += 0.75;
			EvanHSVtoRGB(H,S,V,ref CurrentPixel.R,ref CurrentPixel.G,ref CurrentPixel.;
			dst[x,y] = CurrentPixel;
Broken toaster =
void Render{Surface dst, Surface src, Rectangle rect}
PdnRegion selectionRegion = EnvironmentParameters.GetSelection{src.Bounds};
Rectangle selection = this.EnvironmentParameters.GetSelection{src.Bounds}.GetBoundsInt{};
for(int y = rect.Top; y < rect.Bottom; y++}
for {int x = rect.Left; x < rect.Right; x++}
if {selectionRegion.IsVisible{x, y}}
; {CurrentPixel.R,CurrentPixel.G,CurrentPixel.B,ref H,ref} S,ref V}; {CS1026}
H = Q*{double}Math.Round{H/Q}; // Normalize Hue
if {S > .15} // Compress Saturation
S = { {0.35*{S-0.15}} / {1.0-0.15} } + 0.15;
{V > 0.05} // Compress Value
V = { {0.15*{V-0.05}} / {1.0-0.05} } + 0.85;
V += 0.75;
EvanHSVtoRGB(H,S,V,ref CurrentPixel.R,ref CurrentPixel.G,ref CurrentPixel.B};
Just made more errors :sad:
Can you correct all the errors then send back to me?
Broken toaster =
Code without error message BUT still not working due to bad programing:
int Amount1=72; //[1,360]How big is your box of chalk?
 double BaseColors = (double)Amount1;
       H = Q * (double)Math.Round(H / Q); // Normalize Hue
       if (S > 0.15) // Compress Saturation
         S = ((0.35 * (S - 0.15)) / (1.0 - 0.15)) + 0.15;
         V = ((0.15 * (V - 0.05)) / (1.0 - 0.05)) + 0.85;
         V += 0.75;
       //EvanHSVtoRGB(H,S,V,ref CurrentPixel.R,ref CurrentPixel.G,ref CurrentPixel.;
1. Never use {} for function, it's only needed for groups of instructions.
2. Use () for all the functions.
3. Semi-column ';' is needed at the end of an instruction
4. S, V are always at 0! You need to affect them a value somewhere!
5. EvanHSVtoRGB isn't a built-in function, to use it, you have to add its code at the end.
6. I have added Amount1, that will allow you to have a slider when you will build the DLL.
Now please go on...
         V += 0.75;
Now please go on...
Ok the code is now perfect thanks to madjik ( thanks dude! ) the only thing is that access to my effects folder is denied and im on my administrator account... :cry:
Broken toaster =
Hey hey hey BoltBait! I've gone and found a bug!
When you use the Delete key to make a change to the code, it does not seem to realize that the code has changed and therefore does not recompile... Minor, I know, but I just thought I'd let you know.
ambigram signature by Kemaru
[i write plugins and stuff]
Page one called... they want their bug report back... :D
http://paintdotnet.12.forumer.com/viewt ... =4617#4617
Click to play:
Owned :D
  • 2 months later...
  • BoltBait changed the title to CodeLab v6.8 for Paint.NET 5.0 (Updated January 22, 2023)
  • Rick Brewster changed the title to CodeLab v6.8 for Paint.NET 5.0
  • Rick Brewster pinned this topic
  • Rick Brewster unpinned and featured this topic
