toe_head2001 Posted December 7, 2022 Share Posted December 7, 2022 2 minutes ago, Rick Brewster said: You're not setting the property though? Correct. Only reading. 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 7, 2022 Author Share Posted December 7, 2022 K I'll rush out a new build that re-publics the getter Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 7, 2022 Author Share Posted December 7, 2022 Ok done Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
kuenzign Posted December 9, 2022 Share Posted December 9, 2022 (edited) I'm getting the following exception when trying CodeLab 6.7 on the new Paint.NET Beta 5.0: System.AccessViolationException: Attempted to read or write protected memory. This is often an indication that other memory is corrupt. at ScintillaNET.Scintilla.DirectMessage(Int32 msg, IntPtr wParam, IntPtr lParam) Crash log is attached. pdncrash.12.log Edited December 9, 2022 by kuenzign Added crash log Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted December 9, 2022 Share Posted December 9, 2022 @kuenzign, do you have any steps to reproduce the crash? Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
kuenzign Posted December 10, 2022 Share Posted December 10, 2022 (edited) I just opened CodeLab and it crashed with that exception. Although I just updated to the second beta and now it appears to no longer occur. Edited December 10, 2022 by kuenzign Quote Link to comment Share on other sites More sharing options...
sergiopedri Posted December 10, 2022 Share Posted December 10, 2022 @BoltBait would you consider publishing CodeLab in the Microsoft Store? Not only you'll get an easier way for people to get it and to receive installs, but also you'll get the Store to sign the application for you for free 🙂 A developer license costs 19$ (just once) and gives you unlimited code signing use 😄 Quote Link to comment Share on other sites More sharing options...
_koh_ Posted December 14, 2022 Share Posted December 14, 2022 Tiny problems. Auto update tries to update CodeLab v6.7 to CodeLab v6.6. Theme: Auto doesn't reflect PDN setting, need to set CodeLab theme separately. PDN v5.0 build 8382 / CodeLab v6.7 Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 14, 2022 Author Share Posted December 14, 2022 On 12/10/2022 at 9:37 AM, sergiopedri said: @BoltBait would you consider publishing CodeLab in the Microsoft Store? Not only you'll get an easier way for people to get it and to receive installs, but also you'll get the Store to sign the application for you for free 🙂 A developer license costs 19$ (just once) and gives you unlimited code signing use 😄 I believe Paint.NET-in-the-Store has to be set up for this first. That is, having a secondary plugin catalog that comes from Store-installed packages. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
toe_head2001 Posted December 14, 2022 Share Posted December 14, 2022 (edited) 8 hours ago, _koh_ said: Theme: Auto doesn't reflect PDN setting, need to set CodeLab theme separately. Yes, this has already been fixed for the next release. 8 hours ago, _koh_ said: Auto update tries to update CodeLab v6.7 to CodeLab v6.6. Good thing there's nothing "Auto" about the update check; it's just a notification to download. 😉 You're right though, this can be improved. EDIT: update checking has been improved for the next release of CodeLab. Edited December 15, 2022 by toe_head2001 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
ReMake Posted December 21, 2022 Share Posted December 21, 2022 I'm trying to compile an example for Double Vector from @BoltBait's Sample Code for User Interface Elements. Spoiler // Author: Curtis #region UICode PanSliderControl Amount1 = Pair.Create(0.0,0.0); // Position #endregion void Render(Surface dst, Surface src, Rectangle rect) { Rectangle selection = EnvironmentParameters.SelectionBounds; ColorBgra PrimaryColor = EnvironmentParameters.PrimaryColor; int width = selection.Right - selection.Left; int height = selection.Bottom - selection.Top; // converts the Pair values to between 0 and 1 // where 0 is the left/top and 1 is the right/bottom. double px = (Amount1.First + 1) / 2; double py = (Amount1.Second + 1) / 2; // we can now convert these to actual pixel co-ordinates. int column = (int)Math.Round(px * width); int row = (int)Math.Round(py * height); for (int y = rect.Top; y < rect.Bottom; y++) { for (int x = rect.Left; x < rect.Right; x++) { if (x == column || y == row) { dst[x,y] = PrimaryColor; } else { dst[x,y] = src[x,y]; } } } } I replaced Amount1.First and Amount1.Second with Amount1.X and Amount1.Y . Is this replacement correct? Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted December 21, 2022 Share Posted December 21, 2022 3 hours ago, ReMake said: I replaced Amount1.First and Amount1.Second with Amount1.X and Amount1.Y . Is this replacement correct? Yes, but you also need to change the Amount1 declaration. PanSliderControl Amount1 = new Vector2Double(0.000, 0.000); // Position 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
ReMake Posted December 27, 2022 Share Posted December 27, 2022 Is there currently a solution for using the Black-and-White Clouds effect in CodeLab v6.7? Spoiler // Clouds // Use this line instead of the next for Black-and-White clouds: cloudsEffect.EnvironmentParameters = new EffectEnvironmentParameters(ColorBgra.Black, ColorBgra.White, 0, EnvironmentParameters.DocumentResolution, EnvironmentParameters.GetSelectionAsPdnRegion(), src); //cloudsEffect.EnvironmentParameters = EnvironmentParameters; cloudsProps = cloudsEffect.CreatePropertyCollection(); Replacing EffectEnvironmentParameters() with CreateFrom() requires a using directive or an assembly reference? Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted December 27, 2022 Share Posted December 27, 2022 You if only care about Black for Primary and White for secondary, you can use the DefaultParameters. cloudsEffect.EnvironmentParameters = EffectEnvironmentParameters.DefaultParameters; @Rick Brewster In Pdn v5, the EffectEnvironmentParameters constructor was marked as obsolete. Since it's part of the Legacy effect system, are you willing to roll back that change until the entire legacy effect system is killed off? 1 Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 27, 2022 Author Share Posted December 27, 2022 You're trying to create an EEP who's primary/secondary color are specifically set to Black and White? (a better pattern here is that the Clouds effect should just take the colors as property values -- but we can't go back in time and change that!) Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
ReMake Posted December 28, 2022 Share Posted December 28, 2022 6 hours ago, toe_head2001 said: You if only care about Black for Primary and White for secondary, you can use the DefaultParameters. It works. Thank you, @toe_head2001. I am currently rebuilding my effects for PDN5 (so far these are 'cosmetic' changes). Quote Link to comment Share on other sites More sharing options...
BoltBait Posted Monday at 06:41 AM Share Posted Monday at 06:41 AM CodeLab v6.8 Released This is only for Paint.NET 5.0+! Quick update today... Just a release of random stuff before we start tackling support for Paint.NET 5.0+ (UI tabs and GPU acceleration) Changes: ▪ Fix crash in UI Designer preview screen (toe_head2001)▪ Minor code refactoring and bug fixes (BoltBait and toe_head2001) Grab the CodeLab DLL here: https://www.boltbait.com/pdn/CodeLab/ 4 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
