This just started happening. I have built several plugins in codelab, so I know what I am doing.
I was building the HSVInvert plugin from Boltbait's tutorial and found this anomaly (another one). Before building the DLL, I created the 150X200 HSVInvert.png and placed it in the same folder as the CS file. When I selected File/Build DLL I got the first error message telling me the .png must be 16X16. Clicking OK took me to the build screen, but no 150X200 .png was showing. I double checked to ensure it was in the same folder. It was. At this time the icon started showing up next to my selection in the drop down menu next to HSVInvert. How can that happen if I haven't built the DLL?
Here's a pic to show you what I am seeing.
Flames.cs also shows up and has a 150X200 .png built, but it doesn't show up as an icon. That was the last DLL I built. I haven't even built the HSV Effect.
Edited by AndrewDavid
Removed pic
Here's the code used for icon detection.
string imagePath = Path.ChangeExtension(scriptPath, ".png");
if (File.Exists(imagePath))
    recentItem.Image = UIUtil.GetBitmapFromFile(imagePath);
As you can see, your .png file will be used if it has the same name as your .cs file.
https://forums.getpaint.net/topic/880-codelab-v63-for-advanced-users-released-september-27-2021/?do=findComment&comment=535123
  • Thanks 1
My Gallery  |  My Plugin Pack
Layman's Guide to CodeLab
3 hours ago, BoltBait said:
CodeLab v6.4 is released to support version 4.3.3+ of Paint.NET.
Tested, Tried and True. Created a codelab build with a RTF file - exported to VS2022 - cleaned up the code (12 Issues), built the DLL, tested in Paint.
You would almost think I know what I'm doing.
Now - I would imagine adding Form Based to Codelab is practically impossible or a monumentis challenge
I have so many issues trying to build a Forms based plugin in VS.
I know they are a challenge, but they shouldn't be this difficult without a Template (Hint Hint)
Could someone create 1 small form based plugin in VS2022/Net 6.0 to experience some of the issues I have encountered.
It doesn't have to really do anything, just get it to display properly. I'll put it on my XMas wish list. :)
I wouldn't say blindly. Issues like simplifying, value is null, removing unnecessary references. The yellow warnings.
I have one example that I didn't modify.
       private void OnWindowHelpButtonClicked(IWin32Window owner, string helpContent)
Severity    Code    Description    Project    File    Line    Suppression State
Message    IDE0060    Remove unused parameter 'owner'    ZoomBlurDeluxeEffect    C:\Users\Andrew\Desktop\MyVS2022Plugins\ZoomBlurDeluxe\ZoomBlurDeluxeEffect\ZoomBlurDeluxe.cs    160    Active
Removing owner just leads to more issues. Project compiles and works correctly.
The issue with this method is that it's called via reflection. paint.net should provide a method to override.
In the moment the compiler guesses that this method is just a private one in your code and nobody calls it. And if owner is not used in the implementation of the method the compiler proposes to remove it. But that's not a good idea because the reflection code will try to set this parameter and fail.
So to get rid of the warning you should use the owner parameter.
Typically OnWindowHelpButtonClicked shows a dialog or a message box. The Show method of these objects allows to provide an owner as first parameter. I.e.
    MessageBox.Show(owner, ...
This is a good idea because setting this parameter add the dialog to the dialog stack of the application.
If the code doesn't use a dialog then try to assign the parameter to itself:
    owner = owner;
(but this may generate an other warning).
  • Thanks 1
I have just installed the latest paint.net (4.3.3) in 'tandem' with v4.2.16 and v3.5.11 (perhaps that's a tricycle 😄). I decided to name the program folders 'pdn4.3.3', 'pdn4.2.16' and 'pdn3.5.11'.
Unfortunately this prevents the codelab v6.4 installer from detecting the installation.... I've just tried renaming the pdn4.3.3 folder back to 'paint.net' - the installer still tells me I have version 0.0 and asks if I want to proceed anyway. I aborted the installer.
Is it possible to get the codelab v6.4 .dll without an installer?... or does the 'install anyway' choice allow me to specify a path?
Many thanks
  • Rick Brewster changed the title to CodeLab v6.4 (for advanced users) Released November 20, 2021
Many thanks
Bump... Is there any way to safely extract the .dll from the installer or could someone share it, please?
Would changing the program folder name have messed up a setting in the registry?
@AndrewDavid Needing to install VS2022 and work out how to compile from Github seems like overkill! - but thanks anyway.
The installer reads installation path from registry but it can't find it. You should only specify installation path during PDN installation and not change it afterwards. It'll break all plugin installers that tries to detect version/location and it can also mess up your PDN file associations. You can use portable versions.
For extracting Codelab.dll,
You can use ILSpy to extract the resource. https://github.com/icsharpcode/ILSpy
The resource name you'd want to extract is Install.Attachments.Codelab.dll
So I've discovered. 🙄
Thanks for the other advice. I've never used ILspy - I should, when I get the time.
@AndrewDavid This issue doesn't seem to be related to CodeLab or maybe I'm missing something?
In explorer, right click column header and select "Date modified". This setting is for per folder. If you want it to be default for all folders, click "View menu"->"Options"->"View tab"->"Apply to all Folders"
See here for detailed explanation:
https://www.guidingtech.com/add-columns-folders-windows-10-file-explorer/
Edited by otuncelli
  • Thanks 1
2 hours ago, AndrewDavid said:
I am trying to get "Arial" as the default selection. Yes I have Arial installed. Adamas is the first font I have installed. I have tried running Lesson 4 from Codelab, but the results are the same. I suspect the code to change the default Font selection has changed.
That has never worked in CodeLab. You'll have to take the code generated by CodeLab, and manually edit it.
We should probably fix that though.
  • Thanks 1
I tried to fix this on my fork here:
https://github.com/otuncelli/CodeLab
Changes:
https://github.com/BoltBait/CodeLab/compare/master...otuncelli:master
I can create a PR if all seems OK and you're not planning to do something else?
Edited by otuncelli
Awesome; less work for me.  I'll review the changes later tonight.
Changes:
You haven't done anything to the UI Builder screen.
Check to see how the Color Wheel control looks/works as far as a default value is handled.  Also, how a default of "None" is handled.
I'd say, you're about 50% there.
Yes, this is a partial fix. My intention was to fix the issue @AndrewDavid reported without breaking anything else. UI Designer seems to require more work that I can not afford currently.
Edited by otuncelli
CodeLab v6.5 Released
This is only for Paint.NET 4.3.8+!
Quick update today...
Changes:
 Fix default font name for font control (otuncelli and toe_head2001)
Add support for new Folder Chooser control in Paint.NET v4.3.8 (toe_head2001)
Add filter toolbar to AutoCompleteBox (toe_head2001)
 Minor code refactoring and bug fixes (toe_head2001)
Grab the CodeLab DLL here:
https://www.boltbait.com/pdn/CodeLab/
  • Like 2
  • BoltBait changed the title to CodeLab v6.5 (for advanced users) Released February 19, 2022
For those curious, the filter toolbar behaves similarly to one in Visual Studio.
When the AutoCompleteBox is opened, the toolbar will display the different groups available.
Example 1
Without scrolling through the whole list, we can see there are only Properties and Methods available on this object.
And if we click the Properties icon, the other items are hidden:
(this filtering already existed in CodeLab, but required keyboard hotkeys)
Example 2
Let's only show Enums and Delegates... Easy peasy.
Did you notice that black scrollbar?
  • 2 months later...
  • 5 weeks later...
CodeLab v6.6 Released
This is only for Paint.NET 4.3.11+!
Just a release of random stuff before we start tackling support for Paint.NET 4.4+ (UI tabs and GPU acceleration)
Changes:
 Fix auto braces (toe_head2001)
Add option to disable auto-complete (toe_head2001)
 Minor code refactoring and bug fixes (BoltBait and toe_head2001)
  • Like 2
  • Upvote 2
  • BoltBait changed the title to CodeLab v6.6 (for advanced users) Released August 9, 2022
The behavior of the Auto Complete box is designed to match the one found in Visual Studio.
There are two reasons someone might want to disable it:
  • The person is not accustom to the C# Auto Complete in Visual Studio, and thinks the behavior is annoying (for example, people that normally code in a language other than C#)
  • Bugs in CodeLab that cause the behavior to deviate from the behavior found in Visual Studio.  If you encounter bugs like this, please report them with repro steps!
  • Upvote 2
